Question about Dryers
How to replace a dryer belt on Amana model LE8317W2?
  • 94 Answers
SOURCE: Amana dryer belt
You will probably have to open it up from the top and/or back. If the belt looks alright (it probably won't, though), check the belt tensioner. Carefully observe how the belt goes on and around the tensioner before replacing.
Posted on Oct 07, 2007
  • 686 Answers
SOURCE: No heat coming from Amana Dryer
2 screws at the bottom of front panel if no screws there, then pry top off with wide flat screw driver then look inside toward top of front panel remove two more screws and the front should lift right out then remove screw/s in center of drum and lift out of cabinet there should be your heat element
Posted on Feb 27, 2009
  • 659 Answers
SOURCE: My Amana LE8317W2 works for 10-20 minutes then stops. There is a slight burning smell. It wont restart until it cools and when it does restart, it seems to take a lot more energy to get the drum rolli
Make sure your vent is clear of lint from inside the unit and to the termination point outside.
Posted on Apr 18, 2009
erpaalai
  • 999 Answers
SOURCE: I have Amana electric dryer, model number LEA30AW.
There are 2 screws along the bottom and the lower panal will drop down and off. You can look in from there.
Eric
Posted on Jun 10, 2009
Dirt Dobber
  • 253 Answers
SOURCE: My dryer has stopped drying and the model #is LE8317W2
probable broken heater element. you can call a repair service or pick up a new element at a retail a/c appliance store using the make and model number from inside the door and have a neighbor/friend/ you trust fix it with basic tools.
Posted on Jul 04, 2009
I want to connect a four prong onto my dryer model no. LE8317w2
Here is what it looks like:
Thanks for using FixYa
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 11, 2011 | Amana Dryers
Tip
Dryer Belt Replacement Replace Dryer Belt Admiral Amana Asko Crosley ...
If you need to replace your dryer belt and need a diagram to see how it goes, check out these diagrams.
For Admiral all models will look like this
154ceff.gif Style: Flat with ribs
Installation Tips: Ribs against drum
For Amana all models will look like this
Installation Tips: Ribs face toward drum
For Asko all models will look like this
For Crosley all models will look like this
Fridgidaire
1970 – 1985
1985 – 1995
1995 – present
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 02, 2010 | Dryers
My Amana Electric Dryer will not heat up. Model# LE8317W2. We have cleaned out the machine and the vent. I will be purching a heater element (as recommended) is that easy to replace? IS there anything else...
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.Here is a video for the element replacement.Here is a video for the thermostat replacement.
Nov 26, 2010 | Amana Dryers
My dryer is making a loud siren type noise and the drum turn is kind of clanky sounding too. It is producing heat and drying but I am concerned that something is wrong. I have an Amana LE8317W2 electric...
You will need to remove the top of your dryer and inspect the belt tensioner. If the idler roller has a bad bearing and sticks the roller will get a flat spot causing the noise you are hearing
May 08, 2010 | Dryers
Amana electric dryer model #LE8217W2 belt replacement
This will help:
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 08, 2009 | Amana Dryers
Jul 04, 2009 | Amana Dryers
Amana dryer
If you have voltage across the heating element and it does not heat, replace the element. If you have no voltage, trace it back to the thermostat and control board.
Oct 02, 2017 | Dryers
Amana dryer belt
Oct 06, 2007 | Dryers
Dryers Logo
82 people viewed this question
Top Dryers Experts
