Question about Jenn-Air 24 in. JDB1250AWS Stainless Steel Built-in Dishwasher
The 3 sprayers in my Jenn Air dishwasher do not spin.
I was able to trick the latch and look inside while it was running and noticed that none of the sprayers moved at all. There is also some kind of sprayer in the back where the top rack sits into the back side of the dishwasher, and that is squirting water. Maybe it is supposed to. Also the water is pretty warm, about 110. The water at my tap is much hotter than that. Maybe it's time for a new one, but I would like to try to save it, it matches the other appliances.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 52 Answers
Repairs should be preformed by an authorized service person. the flat tube in the rear is a manifold that allows water to flow from the main motor assembly. if there isn't enough or any water flowing to the manifold then the manifold is disconnected from the main motor or the main motor is not pumping efficiently. replace the main pump assembly or reconnect the manifold to the pump if dis connected.
Posted on Jun 04, 2017
pincer
  • 377 Answers
SOURCE: dishwasher arm not spinning
try to click in here..
Posted on May 04, 2008
SOURCE: Jenn-air Dishwasher won't drain water from base
This happened to me after installation. they had installed a one way valve backwards in the drain line and had to reverse it.
Posted on Jan 03, 2009
  • 338 Answers
SOURCE: JDB1100AWS not rinsing
if your filter assembly is clogged you are going to need to clean it. if it is really bad then it should be replaced. the part number is 99003292 and would probable cost about $30. the other thing is start your dishwasher on a rinse cycle and see if you have suds in the bottom do not put additional detergent in while checking this. if you have suds run vinegar in the dishwasher to help get rid of the suds as that can cause the same problem. Let me know if you need additional info
Posted on Jan 11, 2009
SOURCE: Jenn Air dishwasher door won't close
i had the exact same issue. it's a broken latch mechanism, and is a fairly common problem.
i bought the part at my local repair shop for $45 (you can find it online for $30). it literally took 10 minutes.
you need to right size bit to remove the 10 bolts on the interior of the door. once you have those out, the latch slides right out of the top. there are 2 electrical connectors (careful - you can get a shock. disconnect the 2 connectors, reconnect to the new one, and zip your 10 bolts back in. super easy
Posted on Oct 17, 2009
SOURCE: Our jenn-Air built in dishwasher smells foul and
We had similar type of problem (as well as residual water always left in bottom) and after pulling out the dishwasher, found that the drainage tube was incorrectly installed by contractor. It was laying on the floor behind it with a only a slight rise to the garbage disposal inlet. I suspect this contributed to sewer odors as well a water back flowing into the dishwasher. I disconnected drainage tube so that it went up 24+" and then connected to garbage disposal (creates a loop that blocks sewer odors and back flow conditions). I also cleared out the filter at bottom of inside the dishwasher. The Use & Care Guide suggested using baking soda in China/Crystal mode for 10 minutes, opening the front door and letting it sit overnight. I repeated that for 3 nights and it did clear up the remaining odor. Don't know if this will help your issue or not. Good luck!
Posted on Jan 10, 2010
My dishwasher runs but door is in locked position. it will now run with door open and the door wont close/lock
It sounds like your door latch got tripped into the closed position (even though your door is open). You MIGHT be able to use a screwdriver or some tool to be able to pull the latch lever back out to the open position, but it might also be necessary to take the door apart to get to the latch to be able to reset it. The real problem is that if it happened before, it will probably happen again. So the real solution is to replace the latch assembly.
May 31, 2015 | Jenn-Air 24 in. JDB2100AW Dishwasher
Dishwasher arm not spinning
can you please provide some details about your machine..
the model and the part # please..
Thanks
May 02, 2008 | Jenn-Air 24 in. JDB1080AW Built-in...
Won'Run Wash Cycle
JB, make sure the float assy. is not stuck inside the tub. On the motor harness, you have yellow-main, red-drain grey-wash and blue is the common. Check for power to the motor during the wash cycle. On this model I believe they installed a thermal cut out after series 11. I'll keep an eye peeled for any replies..Catriver.
Jun 06, 2007 | Jenn-Air JDB6510 Built-in Dishwasher
Top rack not cleaning dishes. model # FDB1050RES2
Hello, check the sprayer arm on the top of the dishwasher inside and to see if it spins. Don't block this spray arm with glasses or dishes that could block the operation of this sprayer cleaning arm.
Now, if it not spinning, check out the fitting arount hing bolt. If this wore out then you will have water pressure lose. Replace if need be. Also, check the feeder water spout that runs the upper spray army, it could be pluged. GB...stewbsion
Aug 31, 2011 | Maytag Dishwasher
I have a JDB1270AWY Jenn-Air dishwasher . I'm trying to fine the latch and pivot piece that holds the upper pair of convertible tines up write at 90 degrees.The dishwasher was bought and installed in...
Go to www.repairclinic.com and enter JDB1270AWY. With luck, you will be presented with a list of common replacement parts and may be able to identify the specific ones.
Aug 27, 2017 | Jenn-Air 24 in. JDB1270AW Built-in...
My dishwasher does not start
Check fuse located under top section near door latch, make sure motor is spinning freely.
Sep 28, 2010 | Jenn-Air Dishwashers
Our Jenn Air dishwasher leaks. We notice an
There are two possibilities here. First of all make sure the latch is adjusted to close the door tight. IF not, you can adjust it using a screw driver. next, you may have to replace the gasket as these do wear out.
Nov 03, 2009 | Dishwashers
After the dishwashing cycle, most of the soap tablet is lying in a mess inside the tub and the dishes are unwashed. This is a Jenn-air Quiet series dishwasher
hELLO THERE:
I would recommend first cleaning out all of the filters including the ones under the sprayer arms than i would check the pressure of the water going thru the system refer to the users manual or go to the manufactures website and view the pdf manual for troubleshooting
ok?
best regards michael
Sep 14, 2009 | Jenn-Air Dishwashers
Jenn air diswasher mod # JDB1100AWS
disassemble front door to get to the latch. Check if the latch is properly in place, sometimes the metal cylinder that hold it in place, slips out of position.
Jul 08, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Jenn_air model #JD8910AWS won't drain
I was having the following symptoms: If I hit the drain button, it would stay at 2 minutes and just click on and off. If I hit the rinse button, it would rinse all 9 minutes OK. It would always stick in the middle of a full cycle and just start clicking.
I just fixed it. I shut off the circuit breaker, opened the door up (all torx screws from inside of door) to get the the upper controls. One lead (of two) of a capacitor (square blue component) had actually worked itself out of the control board. I cleaned it up and resoldered it in. All better now - for now.
Aug 15, 2007 | Jenn-Air 24 in. JDB8910 Built-in...
Jenn-Air 24 in. JDB1250AWS Stainless Steel Built-in Dishwasher Logo
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
