My computer is failing to automatically restart. Why?
I just paid ITOK $75.00 to give my computer a complete tune-up. So, this shouldn't be happening!
  • 27,725 Answers
Check to see if there are any keys stuck/depressed. If so, use a paperclip and fit it underneath the key and gently pry the end that is stuck. Make sure the laptop is off before attempting this. Observe where the boot process ends and starts over. In most cases, this will give an indication where the problem occurs. If the laptop reboots early on in the process, for example when it is detecting the hard drive, chances are good it is a hardware issue. If the reboot occurs further along in the process, like when it is loading operating system files, there may be an issue with operating system software. Test all power and data leads that attach to your hard drive SATA the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty. even something as small as faulty fan lead can cause you problems computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly. Motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working Check your computer ram modules for secure dust free seating you might even remove the ram modules to check for dirt on modules and in the module socket and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in If your computer runs long enough scroll to bottom toolbar (bottom of screen) right click select task manager applications you will see whats running if you see anything you dont need running select end now and you might uninstall that specific program if you or computer does not require it to run and some unnecessary programs that could be running your computer over its limits causing memory dumps also under processes see what is ticking over in the background you might have a virus again if you see something you dont need to be and users you will see who is using your computer
You might need to add more computer ram if you're not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system You should always ask for a guarantee on the compatibility of the ram before making any purchase Might be getting hot check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Capacitors look like small metallic canisters and they are found in many different computer components including computer monitors, computer motherboards, video cards, power supplies and a variety of other consumer products. A bad capacitor can cause a variety of computer problems, but if you can identify the faulty capacitor you may be able to replace it and save your computer.
Capacitor
Capacitors, sometimes also called condensers, are used to store energy in an electric field. In the context of computing, capacitors are used to block the direct current being circulated around the motherboard. A typical capacitor should last up to 15 years, but some computer manufacturers use substandard capacitors resulting in shorter lifetimes. Computer Problems b> When a capacitor has gone bad on a computer you may experience a large range of problems. The computer may have trouble booting up, or it may shut down without notice after running for only a short period of time. The most common problems associated with faulty capacitors are that they cause unexpected computer crashes and general reliability issues ranging from read/write issues to distorted screen images. b> Identifying a Bad Capacitor b> To identify a bad capacitor you will need to open your computer case and locate the capacitors on your motherboard. A bad capacitor may exhibit swelling at the top or the base of the capacitor or it may sit at an awkward angle with the motherboard, so compare the various capacitors in your computer in terms of and placement. Additionally, a bad capacitor may have a funny smell or it may have a brownish residue leaking from the top or the base. b> Prevention b> Manufacturers claim that capacitors may go bad because a computer is not receiving enough power from a power supply, because of an overclocked processor or because a computer is operating in an environment with too much heat or humidity. However, some capacitors prematurely fail due to faulty work on the part of the manufacturer. If you have a bad capacitor be sure to do research as to the lifespan of other products made by your manufacturer. Identifying bad capacitors http://www.youtube.com/watch?v=ngA4k32jLGc Capacitor replacement http://www.youtube.com/watch?v=s0Pn2tEjY04 How to check a capacitor http://www.youtube.com/watch?v=U4tnHA0phcc Replacing a leaking capacitor http://www.youtube.com/watch?v=s0Pn2tEjY04 Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/
Posted on Apr 20, 2013
2 Suggested Answers
carloadrian
  • 571 Answers
SOURCE: after automatic updates and a restart, diagonstic lights A & C were yellow and D & B green, nothing comes up on screen, this happen before after an update but i got it to start after several a
If all diagnostic lights are on, then that means that it has something with the software of your computer. The update has affected some of the programs inside your computer thus it's booting up fine.
I suggest that you access safe mode and do a system restore from there. If you don't know how to access safe mode, then follow these:
1. Turn off your computer.
2. turn it on and keep tapping F8 until you see the options. You should see safe mode.
3. Use the arrow keys to select safe mode, then press enter.
4. Your computer should boot up to safe mode.
5. Access the system restore. You can find it in accessories, system tools, system restore. or you can search.
6. restore your computer to the known good date where your computer was still working fine.
7. After completing the on screen procedures, let your computer restart by itself (it may take minutes or more). It will restart and it should boot to the normal windows.
Good Luck!
I hope this helps.
Carlo
Posted on Nov 17, 2012
Itok complaints
Welcome to the Legion of the Scammed
Mar 25, 2017 | Computers & Internet
Advent roma 1000 will not start up.
Hard disk drive has failed. Replace it.
Mar 03, 2017 | Advent Computers & Internet
How give a full tune up
Other than Spark Plugs there is no tuning to be done &
hasn't for some 25 years
You could do air filter,gas filter,clean maf sensor,& such
There is no such thing a a complete tune-up or master tune-up
those are advertising gimmacks to get you into the shop,just like
free topping off of fluids. No fluid are consumed,so it makes sense
you would have a leak. But people are gullible & live in the 1950"s
Oct 13, 2012 | Cars & Trucks
What should a complete tune-up with new hoses cost for a 2005 Buick La Sabre?
No...your BiL is OOHM (out of his mind) if he thinks they're comparable.
A tune-up shouldn't cost more than $200 - but depends on what all is being done.
What all does his 'tune-up' include? What are the hoses for?
Sell the F150 yourself.... even w/high miles it's worth $$. Go to KBB.COM and look up the Private Party value. Probably $5,000+
GL,
TD
Oct 03, 2012 | Cars & Trucks
Bell & Howell DNV900HD Drivers?
have you tried to restart the computer since installing the software on the disc? also when you say the drivers failed to update are you trying to say that windows update failed to download new drivers? you shouldn't need to install updated drivers if the oem disc has them.
May 02, 2012 | Computers & Internet
Tried to adjust my HP620 screen brightness using "fn" f3 failed
HP Support Assistant can perform an analysis of your computer to keep your computer up to date and give you alerts and tips from HP by using the Maintain tool. Click to download the latest version of HP Support Assistant . The Maintain tool can help you complete the following actions:
  • Health Analysis , examines the computer system and lets you know about the latest drivers to maintain the health of your computer.
  • Software Updates , gives you updates to you software to avoid any problems.
  • Usage Tips , updates you with the latest alerts and tips from HP.
  • Automated Tune-up , a tune-up can be scheduled periodically maintain your computer automatically.
Dec 06, 2011 | HEWLETT-PACKARD 620 XT964UT Notebook PC
I cannot sign into my yahoo mail account.
The internet going out temporarily shouldn't have had an effect on yahoo as the two are not connected. Unplug your router for about 5 minutes then restart it, then boot the computer and attempt to sign into yahoo.
Nov 17, 2011 | Computers & Internet
My Windows XP professional cannot be shut-down. How to shut-down without harm to my system or loss of data ??
Hard rebooting once *shouldn't* affect your data. But it's a good idea to check for a problem with the disk.
Open a command prompt by clicking Start->Run and typing in the box cmd
Click OK
In the black box, type chkdsk /r and hit Enter
It should tell you that a reboot is required. Restart (any method that you can). The system will boot up and begin checking for disk errors and automatically repairing them. When it's complete it will boot into Windows normally.
Nov 17, 2011 | Microsoft Windows XP Professional
Can't get an IP address to get on the internet
Make sure that DHCP is enabled for the network connection. You shouldn't need to 'set' an IP, almost all networks automatically assign these network settings.
May 05, 2011 | Sylvania G-Netbook
Computers & Internet Logo
David Payne
David Payne
