Question about Guillemot Hercules DJ Console RMX Mixer
Hercules djrmx console reset factory
Factory reset
  • steveojungleist Apr 26, 2013
    i am looking for instructions on how to reset the hercules rmx dj console to original factory preset.thanks
Patch not saving,write button is not working from the day i bought.i bought is 2nd hand.plez help
If you buy a second hand, it may have been damaged in mini switch (tact switch) under the WRITE button. You need to replace the tact switch. Easy and inexpensive, you can do yourself, only with a little knowledge of soldering
Tact Switch:patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-1.jpeg
You may also try the FACTORY RESET.
Restoring the GT-10 to the settings made at the factory is referred to as a "Factory Reset."
Not only can you return all of the settings to the values in effect when the GT-10 was shipped from the factory, you can also specify the range of settings to be reset.
If you do this"Factory Reset", all the setting on user memory (that you create) will be erased, so backup your setting before doing this steps.
patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-3.jpgpatch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-6.jpg
For more detail on "Factory Reset", read the GT10 user manual:
roland.com/support/article/?q=manuals&p=GT-10&id=1810803
Sep 16, 2015 | Roland Boss Gt-10 Guitar Effects Processor...
HOW TO CONNECT DJ CONSOLE RMX TO DEEJAY TRIM 4&6
The problem may not be your thermostat. The outdoor unit has a refrigerant reversing valve that maybe the problem. This valve changes position pending AC or Heating. The Aux on the thermostat energizes when the outdoor air temp drops below a certain set point set up by the installer or when the thermostat is set to it.
Nov 11, 2013 | Guillemot Hercules DJ Console 4-Mx
Reset to factory default settings
Directly from the manual:
Press [Soft A] + [Soft B] + [Flash 1] simultaniously
Scroll the wheel to 'Erase all?'
Say yes.
reset-factory-default-settings-byrfig4kuyy51fmb23vlbqsc-2-0.jpg reset-factory-default-settings-byrfig4kuyy51fmb23vlbqsc-2-2.jpg
Aug 31, 2013 | Behringer Eurolight Lc2412 24channel...
Password for hercules dj console setup???
their arent any passwords just download drivers etc
Jul 28, 2012 | Guillemot Hercules DJ Console RMX Mixer
Serial number dj console hercules
salve ho perso il numero seriale della mia console posso riaverlo in qualche modo?
Dec 07, 2011 | Guillemot Hercules DJ Console RMX Mixer
How would i connect a Behringer 1002B Xenyx to a hercules mk4 mixer
The main output jacks of the 1002 are PSUEDO balanced so you can use TS to RCA connections from the 1002 to the MK4. It is not hte best design, but it will work... with two cables go from the 1002 main outs to the stereo ins of the MK4.
Sep 19, 2011 | Behringer XENYX 1002B Mixer
RCA output connectors don't give a clear sound on the Hercules 4-MX. Even after updating the drivers. Too much backgroundnoise and hum !!! Does anybody know this problem. USB problem connections ???
Make sure ALL and I do mean ALL interconnected equipments such as this device, amps, players,computers are ALL powered from the same grounded receptacle. Make sure any lighting involving dimmers is kept seperate.
Jan 02, 2011 | Guillemot Hercules DJ Console 4-Mx
Guillemot Hercules DJ Console RMX Mixer Logo
138 people viewed this question
Top Guillemot Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Guillemot Music Expert? Answer questions, earn points and help others
