Question about Takagi Tankless Water Heater Flow Adj Valve / Flow Sensor EKK0T
I have no water flow at all - Takagi Tankless Water Heater Flow Adj Valve / Flow Sensor EKK0T
    New Friend:
  • 23 Answers
Is the filter clogged?
Posted on Jun 06, 2014
Water heater
Most instant-on tankless water heaters require at least 10 psi of water pressure to start the heating process. The flow of water determines how hot the water will be, within the heating range. An electric 110 volts heater will increase the water temperature about 25 degrees F. A gas water heater will increase the water temperature about 45 degrees F.
Too much flow will not allow the water time to heat. Too little flow will not allow the heating system to work. Each heater must have the outflow water flow adjusted for the best heating outcomes. The best way to find the ideal flow is to turn the hot water facet on and adjust it (open or close) until the water reaches the balance of producing hot water.
Apr 25, 2016 | Water Water Heaters
Water pouring out of flow pipe on buttom of tank water appears to be flowing continuosly through unit
Hi Denis seems like you have a faulty over flow valve, Try pulling and releasing the leaver on the over flow valve to get it to close... Maybe you'll need to replace it..... CHEERS..
Mar 26, 2016 | Water Water Heaters
I installed a dhc tankless heater, but when I open only the hot water everything is ok, but when I open the cold water at the same time the heater turns off.
Hi and welcome to FixYa, I am Kelly.
What is happening is that your cold water flow is greater in volume (gals per min) than your hot water. So when you open the cold water it is mixing with the hot water inside the faucett or shower plumbing and actually reverse flowing back into the hot water heater plumbing. The reverse flow slows the water flow sensing turbine inside the heater and it is thinking that there is not any water flow. (There isn't actually due to the equalization of water pressure when you open the cold water faucett) Since this is a safety feature of the tankless heater to keep it from overheating, it shuts off.
Somewhere in the hot water plumbing there is a major restriction. It may very well be the internal plumbing of the tankless hot water heater or the flow detector design.
There are 2 ways to correct this. The easy way would be to restrict the available cold water flow. You can do this by installing another shut off valve inline with the cold water plumbing and just not open the valve all the way. You would have to adjust the setting so that the hot and cold water can be on at the same time and the hot water heater stays on. The hard way is to locate the hot water flow restriction and eliminate it.
It is possible.... if you have a flow restrictor in a shower head or a screen in a faucett areator that they are partially clogged. Clean any flow restrictors and screens then see how the hot water heater performs before you start modifying plumbing.
Thanks for choosing FixYa,
Kelly
Apr 10, 2011 | Stiebel Eltron DHC-E 8 Tankless Electric...
My kitchen facet will not activate the hot water buner now and it takes two hot water facets in the bathroom to activate hot water. Is there a maintenance pronlem I need to do? Where are instructions how...
There is a minimum water flow required to operate your Bosch tank-less water heater. It is around .75 gallons a minute. There are three things you can do to help the flow.
1.Turning the temperature down will help increase the flow.
2. Installing higher flow aerators on your faucets.
3. Clean the Bosch tank less water heater.
You are not alone in having this issue. The most common problems are low flow faucet aerators and low flow shower heads.
Aug 31, 2010 | Bosch Water Heaters
I have a nortiz 063-s tankless, and it won't stay on...I'm thinking it's the computer, please help
There are several things I would look for:
-Flashing burner light (indicates an error code)
-Trying flowing more hot water. In the summer alot of times you'll flow less hot water because your cold water is warmer. If you flow additional hot water at your shower, it will ensure the unit stays firing
-If the unit doesn't fire at all, you may have debris in your cold water filter or a stuck flow sensor. Call tech support to help you with cleaning a flow sensor.
May 29, 2010 | Noritz 6.3 Gallon Residential Tankless...
Why doesn't cold water flow into the washer through the Smartwater filter? When my Maytag Performa's Wash/Rinse temperature dial is set on Cold/cold no water flows into the tub. But when I set it on...
Hi .. I would first check the supply valve at the washer to be sure that it is open. if it is open , you can check the flow by shutting it off, removing the supply hose, opening the valve slowly and observing the flow. You might need a small bucket here. If you have water flow here at the washer supply valve, then the problem is inside the washer control.
Apr 18, 2010 | General Electric GE SmartWater Household...
Rinnai R50LS- water doesn't heat, even though there is good flow.
If it's a new install: the water is going backwards through the heater and you need to check that your cold water IN is actually hooked up to the cold water IN spot on the heater. they don't register flow if the flow goes backwards through the heater.
If it's not a new install: something is stuck in your flow sensor, drain the unit and take it out to check.
Apr 16, 2010 | Rinnai Water Heaters
After water to house was shut off, my Noritz tankless water heater is on but won't produce hot water. On the unit, the light indicating that the burner is on stays off now.
you probably had debris get into the filter or flow sensor when the water was turned back on. I'd recommend checking the filter first and if that doesn't work, call Noritz Tech support to help you with the flow sensor.
the filter is a black plug located on the cold water line (labeled cold on the bottom of the unit). It points torwards the left.
Apr 14, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Water becomes ice cold in the middle of a shower
Sounds like you have a problem with water flow. Since your ground water is warmer in the summer, you mix less hot and more cold in order to get the same warm temperature. If your hot water flow gets low enough, your tankless will start to "short cycle" in order to prevent scalding. Use one of these three methods to increase your water flow at the shower:
1) Clean your shower head and descale
2) Widen the hole in the showerhead's flow restrictor
3) Remove your flow restrictor entirely
Jan 24, 2010 | Noritz NORTIZ Outdoor Propane Tankless...
When i turn on the cold water to adjust the temperature of water - the hot water turns completly off. I cannot turn on the cold water at all. It is either all hot water or all cold.
It might be a question of inadequate flow. All tankless water heaters have a minimum flow rate that must be met, typically .5-.9 gpm, before the heater will operate. In the summer time the incoming ground water temperature is higher, causing you to mix more cold water and less hot water to get a lukewarm temperature. This can reduce your flow rate near or below the minimum flow rate.
Here's a test for you, try running running a sink while taking your next shower. If the hot water remains mostly constant throughout, then your problem is with flow at the showerhead. The flow at a shower head can be reduced by buildup of scale and sediment. Also all showerheads have a flow restrictor that limits flow to 2.5gpm (some even less). Removing the restrictor will increase the showerhead flow rate as well.
Also look for any error code displayed on the digital read out of the heater. Some heaters will flash on their burner indicate light as well.
Aug 17, 2009 | Water Heaters
Takagi Tankless Water Heater Flow Adj Valve / Flow Sensor EKK0T Logo
Top Takagi Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Takagi Water Heater Expert? Answer questions, earn points and help others
