Question about ViewSonic Computers & Internet
TAKE THE BACK OFF VIEWSONIC VS11449
MODEL VS11449 ALL SCREWS ARE REMOVED
2 Suggested Answers
SOURCE: How do I get my Viewsonic VX922 LCD monitor apart?
in a similar situation the solution was an Ipod case opener used along the perimeter to release the plastic catches..
Posted on Mar 29, 2009
How to remove back cover of viewsonic VT2430
Download the service manual from here:
http://elektrotanya.com/viewsonic_vt2430-1m_vs12335-1m.pdf/download.html
Apr 28, 2015 | ViewSonic VT2430 24"" LCD TV"
How do I disassemble a Viewsonic VX2435wm monitor to get to the pcbs?
look closer I'm guessing there are more screws .
Jan 24, 2015 | Cars & Trucks
Removing back panel of a viewsonic monitor
There are almost always plastic clips along with the screws. I'd recommend buying a plastic pry bar. You can google for them online and they cost $1 or so.
Jan 30, 2013 | ViewSonic VG2230WM LCD Monitor
How do I remove the cover from the Viewsonic VA1912wb 19" monitor? I've removed the stand and the two hidden screws behind it but it won't come apart. Please advice, Anders
I was equally frustrated by this, but eventually figured it out. There are two finger-sized slots on the bottom of the panel covering the monitor's connections. Push them in (towards the top of the monitor) and lift the cover away from the back of the monitor.
Good luck,
-Brad
Sep 06, 2009 | ViewSonic VA1912wb 19" LCD Monitor
How do I get my Viewsonic VX922 LCD monitor apart? I have removed the 4 corner screws and the stand, but the back seems to be stuck solid.
Mar 29, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Troubleshooting
this screen do not use screws in the back all you need is a flat head screwdrive .
Dec 30, 2007 | ViewSonic VX900 19" LCD Monitor
Remove back panel
You have to remove the base at the bottom (4 screws), all the screws on the back, then use a thin flat-head screwdriver or other thin brybar and work around the back panel unlatching the snaps that are in place.
After the back cover is off, the metal cover over the board and power supply can be removed by removing the screws around the outside lip of the cover, along with the screws on the bottom and right hand lip of the raised area in the back.
Hope this helps.
Dec 06, 2007 | ViewSonic N3251w 32 in. LCD HDTV
Vx800 flickers when cold
I have repaired several Viewsonic VX800 monitors. The symptoms include a power light that flickers or flashed on and off or a screen that flashes on briefly or stays off. The problem is bad electrolytic capacitors on the power supply board. These bad capacitors do not look bad and do not swell but they do develop a high ESR (Equivalent Series Resistance). You need a ESR meter to check them. But if you have these problems, you should assume the capacitors are bad and just go ahead and replace them.
First you must open the monitor and gain access to the power supply board.
1. Remove the stand: It is held with 6 screws on the back. Also on the back are 2 black screws that must also be removed.
2. Remove the button bar from the front, bottom: It is pried off. This will expose the 2 screws holding the front plastic bezel.
3. Remove the silver plastic bezel from the front: First remove the 2 screws holding it, then you can pry the rest off. This will expose the 2 screws holding the screen to the plastic back.
4. Remove the screen and electronics from the plastic back: Remove the 2 screws holding it. The 2 speakers are glued to the plastic case. Cut the glue with a knife. The screen and electronics and speakers should lift out of the plastic back.
5. Remove the metal cover to expose the electronics: There are 2 screws holding the VGA connector and 2 screws holding the DMI connector. There are 9 screws holding the cover. These must all be removed. There is a black plastic sheet glued to the lower edge of the cover. It must be lifted. The cover should now come off.
6. Replace the bad capacitors. The power supply and signal processor are on the same board. It is marked VG800-2. The bad capacitors are surfaced mounted 100UF 25V. The bad capacitors are CM16, CM17, CM2 and CM165. The two most critical are CM16 and CM17, but they all read high ESR, so I just replace them all as long as I have them exposed.
Reassemble in reverse order.
Oct 18, 2007 | ViewSonic VX800 18" Flat Panel LCD Monitor
Disassembly of case
This is for a Viewsonic VX900. The bottom bezel with the button unclips.Unplug the connector, and put aside. ( Dont pull on the wires) Then there are two screws that are removed, and the grey frame around the monitor comes off next. Then remove the 4 bottom screws, and the two top tiny screws and the LCD comes away from the back. Remove the shielding, and replace your components. Good Luck !!
Sep 01, 2007 | ViewSonic VP920b 19" LCD Monitor
Computers & Internet Logo
27 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
