Question about Pantech Cell Phones
Pantech flex turns off on its own won't turn back on
Turns off and won't turn back on until I remove the battery and put it back in.
BillB-SA
  • 2761 Answers
SOURCE: turns off when taken off charger do i need a
You more than likely need a new battery, but try this free fix before you spend anything. Remove the current battery and wipe the metallic battery contacts and the phone contacts firmly with a dry cloth to remove any corrosion that may have built up on them. If you can see a buildup on the contacts (white or greenish deposits) you may need to get more serious with the cleaning (fine wire brush, steel wool, etc.). Once the cleaning is complete, make sure that the inside of the phone is clean of residue, then install and charge the battery. This may or may not work, but a no-cost solution can't be beat. If it doesn't work for you. eBay and BatteriesInAFlash.com are good sources for a replacement battery.
Posted on Dec 01, 2009
  • 320 Answers
SOURCE: wont turn on - goes to black screen w/ "Verizon Wireless" Logo
its the short circuit in main board chip ic number IC431 OR IC436 check out .that faulty ic needs replacement.
Posted on Mar 05, 2009
MobilityMan
  • 129 Answers
SOURCE: Env touch problems
Sounds like the software in the phone is corrupt. Take to a Verizon Wireless repair center and see if you can have it reflashed. Call ahead of time or visit verizonwireless.com to ensure that they can repair the phone.
You might also see if you're eligible for a new phone with a two year contract. That phone is an older model and it might be time for your upgrade.
Posted on Aug 24, 2009
onabelle
  • 30 Answers
SOURCE: my w960i while loading to boot on it turns black screen.Until I r
A month ago, it happened to my phone too. I got it reprogrammed at a local repair shop for only $10. The repair man says the problem is brought about by over charging of batteries or by downloading of certain apps which eat up a huge amount of the phone's 8GB internal memory. So he advised me to be careful so it won't happen again. I hope this helps. =)
Posted on Aug 06, 2010
  • 15 Answers
SOURCE: My pantech laser won't charge what's wrong
if you move the cable around just right will it charge?
if not u could have some kind of damage. did you drop it
i would just try buying a new battery on ebay they are usually pretty cheap online.
if you charge your phone alot and overnight. thats really bad for the battery
Posted on Sep 26, 2011
My at&t pantech flex will not turn on or show that it is charging what do i do
This happened to me too !! Its December and i just got this phone in July and its a piece of junk . i was on vine and it just shut off . i turned it back on and it stayed on for like 3 seconds and turned back off. i have no idea why . i took the battery out and put it on the charger and it wont even show that the phone was being charged. . i have no idea what to do . if you figure out how to fix this please tell me . . . it would really help because i dont think i wanna use my christmas money on a new phone /:
Jan 24, 2013 | Pantech Flex 4g Mobile Phone - Black at&t
I just bought the eclipse cld and it won't turn on after charging for hours
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Sep 30, 2012 | Eclipse Audio Players & Recorders
Pantech pocket wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jul 30, 2012 | Pantech Pocket
I have a Samsung PL100 digital camera. I dropped it while at beach, it was switched off. When I went to switch it on the lens came out but then it made a buzzing sound and switched itself off. The lens is...
I had the same exact issue.... try putting it on the charger, even if you think it's fully charged... If the light is red, leave it on the charger until it turns green, and then remove the battery for a second and then put it back in the camera before turning it back on..... try turning it on. If it still won't close, put it back on the charger. If the charger is automatically indicating a red light, that means you have exhausted your battery and will nee a new one... they cost about 5-11 dollars on amazon...... hope that helps...
Jul 20, 2012 | Cameras
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My Lg Remarq only works when it is plugged in. As soon as I take it out of the charger it turns off and won't turn back on until I plug it in. It is fully charged and I have tried taking out the...
The battery is deceiving you. This is actually a battery problem and you just need a new battery to fix it. Visit the store and get a new battery order. They will cost little to nothing.
-ex Sprint rep
Jul 15, 2011 | LG Cell Phones
I have a Windows CE Sylvania netbook that won't boot to the desktop. I can turn it on, but it seems to freeze right as it turns on. It shows the start up screen where it says "Loading OS Image...
One temporary solution is to remove the battery for a while until all the capacitors in the unit discharge. Upon replacing the battery, you get one good power up try. Notice that the date and time have reset. Once you turn off the unit and try to power it up again, the problem comes back and you must again remove the battery for a while. There may be a patch to fix the boot loader, but I have not found it yet.
Jun 15, 2011 | Computers & Internet
Pantech duo keeps shutting off
Sounds like you need a new battery, it may not be fully charging, although it may say so on device. I had a similar problem with my Lap Top, and Fixed it with a new battery.
Jan 22, 2018 | Pantech Duo Smartphone
Pantech Duo Won't Charge
go to any cell-phone dealer and ask for a replacement battery for your model pantech
Mar 22, 2009 | Pantech Duo Smartphone
Cell Phones Logo
348 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
