Question about Dryers
Dryer will not start,put a new start button,
Noticed the light will not come on when you open the door, and even with a new start button will not start,dont have a tester to check out any thing else,give me a clue or do i need a new dryer,yes its old,bout 10 years
  • Mark Van Skiver May 11, 2010
    Voltage please?
    You check make sure breaker not tripped?
    Guru:
  • 462 Answers
The dryer is electric? not gas? If so you may have 110 and 1 side and not on the other. Reset the breaker and make sure you have 110v on each hot leg. You say start button I assume you mean door switch for the light? Have you checked the bulb? If this is already yes to this point open the top up and look at the wires coming to the door switch 1 of them is most likely chewed into by a mouse or something. the light has to have power to it all the time the door is open no power no light because I dont believe it gets any power except from the main power terminals not the timer or anything else .
Posted on Mar 11, 2009
Have ptdn600emwt dryer when pressing start button makes noise but does not run
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Feb 27, 2015 | GE PTDN600EMWT Dryer
Tip
Dryer when start switch pressed no start but buzzes
on Mar 01, 2015 | Dryers
Door is ajar message when shut light comes on but doesnt run
That's because the door switch isn't getting pushed when you're closing the dryer door for some reason or another. Its located at the top of the door. Try pushing the switch by hand and seeing if the light shuts off when you manually push it.
Nov 27, 2013 | Samsung DV337 Electric Dryer
Dryer will not start when I push the start button. All I get is a loud buzzing.
The buzzing is a good sign that the motor is bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 11, 2010 | Maytag MDE9700AYM Electric Dryer
Kenmore electric dryer series 70 makes loud buzzing noice
Sounds like you have a motor problem draging and it can't get started I just replaced one same problem.
Apr 24, 2010 | Kenmore 63942 Dryer
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Dryers Logo
71 people viewed this question
Top Dryers Experts
