Question about Dell Computers & Internet
My computer is failing to automatically reastart .
When my computer tells to restart, I click where I am told but nothing happens, so please tell me what to do,
  • Dell Master
  • 27,725 Answers
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. if this fails to fix the problem During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution restart back into safe mode you might need to select your operating system to load into safe mode To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Posted on Apr 20, 2013
3 Suggested Answers
parrotheadpc
  • 2600 Answers
SOURCE: Windows live care has stopped working: when i
You have malware and a nasty one at that. You need access to the internet from another computer. You will also need a portable flash drive or a USB drive to carry files back to the infected machine. Go to www.filehippo.com and in the center column under Malware, click on the view more text and scroll halfway down the column and download the latest version of MalwareBytes Anti-Malware Tool. Download this to the portable drive. Now, restart the infected computer by tapping the F8 key after you power it up. Keep tapping F8 until you see a multi-choice menu pop up. Choose "Safe Mode" and none of the others. When the computer loads in safe mode, insert the flash drive and wait for it to load and be recognized by the computer. Open the drive and view the files. Double click on the MalwareBytes installer and go through the installation process. Uncheck the box that states "update files". Click the box that states "Load MalwareBytes When Finished". Run the program after it installs and select "Quick Scan" and only the quick scan. After the scan completes, it will show you a button that states "Show Results", all the infections will appear in a list marked in red. Now click the button that states "Remove Selected". Click on this and all infections will be deleted. Restart the computer normally and it should be clean. Now, there have been changes done to the network settings that are not letting you get online...we are going to fix that now. Open your browser window and to the right top of the screen look for the "Tools" button and click on it. Scroll down to "Internet Tools", now click on the "Connections" tab. Look to the bottom of that window and if anything in the lower part of the window is checked...uncheck it and hit apply. Anything that references "Proxy Server" should be unchecked. Click on OK, and check to see if you can get online. If you still have trouble, get back to me. Good Luck...ParrotHead
Posted on Jun 28, 2010
SOURCE: My Lenovo e3200 thinkcenter restarts
Run a sweep on your computer for viruses, a freeware program like Avast (home edition mind you) or malware bytes to check and see if there is a virus causing this problem first.
If this is not the case check the hardware you have added to the computer recently, Is there anything that you have recently installed that has been around since this started (if so uninstall it and if it is needed reinstall it)
If none of these prove to be fruitful, This computer response tends to be a heat issue.
Check your fans to see if any of them are not going, if the CPU fan is not spinning, or any of the other fans are not spinning it will need to be replaced.
If that does not work, consider getting new thermal greas (personally I am partial to Arctic Silver)
To replace the thermal grease follow the instructions in this video: http://www.youtube.com/watch?v=BzoA-VdViZI
Posted on Feb 28, 2011
My acer laptop cdrom does not boot start at all
Try uninstalling and reinstalling the CDROM driver via the device manager.
Right Click on Computer. Click on Manage. Go to Device Manager.
Right Click on the CDRom driver. Uninstall. Restart the computer so that windows will generate the driver. Update it. You can either go to the website of the computer's manufacturer to get the updated version of the driver or do it automatically by using RadarSync.
I hope this helps!
David
Apr 12, 2013 | Acer Aspire Computers & Internet
One unable to restart
Software is corrupted. See if Tom Tom has software for you to recover your system.
Sep 11, 2017 | Tomtom ONE XL GPS
@rongeorgeremovals.com.auwhen I click facebook nothing happens it just wont connect
You need to report that to FACEBOOK. tell them you forgot your password and you will be told to answer some security questions and you would be told to change your password. please try that. thanks
Aug 12, 2011 | Computers & Internet
My laptop freez some time mouse and keboard nothing wor i have to switch off laptop and on again tell work
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive or
click startcontrol panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
defragment your hard drive will speed up your computer
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
hope this helps
Jan 19, 2011 | Fujitsu Fujistu ST1200 Notebook
Medieval Lords Installation error!
1st extract the contents of d virtual disc using POWERISO den run setup it wil install perfectly (directly instalin game by mounting image causes it 2 restart)
Jun 28, 2009 | Monte Cristo Medieval Lords for Windows
Acquiring Address Problem
you will need to make sure that DHCP is enabled within the routers settings as this will tell the router to assign ip addresses automatically, then go to network connections, right click on your network card>properties>TCP/IP line>properties and tick 'obtain an ip address automatically', click ok, close window and restart pc.
Sep 24, 2008 | HP PAVILION A6230N DESKTOP PC
Epson 1290 Printer
Yepperz... Here is your fix
1. Click on START, CONTROL PANEL, PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE).
2. Right click your printer, and select PROPERTIES. (If your printer is not listed, click on VIEW INSTALLED PRINTERS first).
3. Select the ADVANCED tab.
4. Select PRINT DIRECTLY TO THE PRINTER.
5. Click on APPLY (if applicable), then OK.
6. Restart your computer.
7. Try printing now.
Aug 21, 2008 | Epson Stylus Photo 1290 InkJet Printer
Keyboard
Can you please clarify this
  1. Do you keys not respond at all
  2. Do you get numbers when you want letters or otherwise letters to numbers
  3. Or does it respond only in one mode numbers only or letters only
My suggestions
  1. If its situation 1 then try reastarting your machine, and unblocking the num lock and vice versa
  2. If its situation 2 just try unblocking num and blocking back by turning on or off the num lock, its just num lock or FN + Num lock in some PC
  3. If its situation 3 just restart your computer.
Mar 25, 2008 | Acer TravelMate 361EV PC Notebook
Computer spontanious restarts when it is busy
I suspect the following:
1. Overheating
2. power supply failing
3. system error (blue screen)
I suspect the 3rd. to find out, you need to disable automatic restart. to do that, get on desktop and right click on my computer -> properties -> advanced properties or settings. Im not sure mine is in finnish. Make sure the following checkbox is unchecked: It reads automatic restart.
Now if you start geting blue screens type up what it reads and tell me. :)
In cases of 1 and 2.
1. open the pc case and clean the dust
2. not relevant yet.
Feb 13, 2008 | Adesso EKB-2100W c66656 Keyboard
Turn on computer sometimes it goes into Windows sometimes it doesnt
Right Click My Computer, Click Properties.
Click Advanced
Click Settings
Uncheck "Automatically Restart"
This will allow you to see the message that caused the restart.
Sounds like its memory, or the mainboard.
Oct 12, 2007 | Computers & Internet
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
