Question about General Electric Water Heaters
Stuck cap on ge smartwater RO cartridge - General Electric Water Heaters
  • General Elec... Master
  • 16,043 Answers
Get very large slip joint pliers and you may need 2 sets of them You have to get some leverage. The seals are sticking
Posted on May 05, 2013
Not enough hot water ge smartwater water heater gas
1) Copy following links:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Low temperature setting, extremely cold incoming water, Water leak or broken pipe running hot out of tank, crossover caused by bad faucet cartridge or bad recircirculation check valve,, bad gas control valve thermostat.
Feb 19, 2013 | General Electric GE SmartWater Household...
Water filter drain running all the time
Is this a new system? The should be a small restriction in the drain line. The size of the restriction is matched to the gallon per minutes of the R.O. system. Yours could be missing or not the right size, ie not enough restriction.
Jul 02, 2012 | General Electric GE SmartWater Household...
My GE Smartwater filtration system makes a whining sound
The system is most likely running to the drain. Bypass the water softener to see if the whining stops. If it is running to the drain it is either stuck in backwash cycle or the interior seals are bad and need to be replaced. If it is stuck in backwash the drive motor is probably bad and needs to be replaced.
Here is a link to GE website for manual
http://genet.geappliances.com/DocSearch/Dispatcher
RJ
Jun 17, 2011 | General Electric GE SmartWater Household...
The red pressure relief button on my GE Smartwater GXWH35F whole house water filter system doesn't seem to be relieving pressure. As a result I cannot turn the filter cartridge in order to replace the...
To replace the filter cartridge. Do the following;
1. Assuming that you have a pump in your water filter
system, shut it off.
2 Close the intake valve before your filter system.
3.To relieve the pressure, open the faucet after your
filter system. Any of your faucet for that matter.
4.Once the pressure is relieved, you can of course
replace the the filter cartridge.
Nov 26, 2009 | General Electric GE SmartWater Household...
GE SmartWater RO Filter Tank Leaking?
I had same system under my sink for same amount of time and have since then removed entirely for health reasons related to Ro Systems. Mainly the tanks becomes contaminated [alge build up]and my faimly had constant nagging stomach aches which took a long time to resolve untill we decided to disconnected and throw out our "beloved healthy RO System" and decided to install a bi annual disposable type filter system. If you are expereanceing this I would advise the same as for the leak ,There are so many connections under there and it is usually not the tank but the fittings in lines some where and the reason it looks like the tank is because that is the lowest point the leak has traveled. So check all your fittings and if you decide on simple water filter I will advise you.
Please rate. Thanks jj505
jthomefix
gmail.com
Mar 28, 2009 | General Electric GE SmartWater Household...
General Electric GE SmartWater heater problem
most units from GE come with a 3 year manufactures warantee and the home depot should have no probleme giving you a new one off the shelf with your receipt they will send it back and get there money back from GE so they pass it on to you. it would cost you the same amount to fix that one then to buy a new but yours is still under warantee untill july. hope it works out for you.
Jan 04, 2009 | General Electric GE SmartWater Household...
Water Heaters Logo
Top General Electric Water Heaters Experts
Paul Carew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
