FURNACE WON'T TURN ON: I have a 1999 Fleetwood, Prowler RV. The furnace won't turn on.
The gas stove works fine. When I turn the thermostat to heat, I hear a click coming from the thermostat, but that's all. I reset the circuit breaker, rocker switch on the blower, but it didn't help. I checked all the fuses and circuit breakers and they're good. I charged the 12 volt marine battery. It powers everything when I disconnect the power to the RV. Please help! Thank you. Jeff
  • 31 Answers
Check the exhaust port of the furnace. Wasps like to build nests in there and it will not allow the furnace to ignite if blocked. You have a gas detector and it is turned on I assume? I forgot this many times.
Posted on Apr 23, 2013
SOURCE: I have a Carrier 38tra048340
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Posted on Jun 23, 2008
muttandjeff
  • 359 Answers
SOURCE: Furnace is not working, digital thermostat does not register
sounds as if your low voltage transformer might have bit the bullet will need replacing all of the devices you mention are powered by this one low voltage t-stat
Posted on Jan 01, 2009
  • 659 Answers
SOURCE: Furnace doesn't come on, no matter where thermostat is set
This sounds like the relay switch on the control board may be bad. I just replaced a control board last week on a Carrier unit doing the same thing. The relays are built into the control boards. To fix this you must call a luxaire dealer and they can be found at www.luxaire.com. I will ask though, if you put the tstat into fan on instead of auto, does it come on? If it does, it could be a tstat issue. How you find this out is to remove the thermostat and expose the terminals. Take a small "jumper" wire and touch either one of the r terminals to the w terminal and hold it there. If the unit fires up with no problems, then it's the stat and not the board. Try jumping first and if it still won't come on, you know it's the control board. Good luck to both of you!
Posted on Mar 22, 2009
james3751
  • 614 Answers
SOURCE: Heil Max Performance 10 Heat Pump not working
First check to see if you have afloat switch inside the air handler ar underneath the air handler. Its purpose is to shut the outside ac off if the drain stops up. Very common. If this is OK take cover off unit and with screw driver push in the contactor. It is located about the middle of the panel. It has main power at the bottom. If unit comes on you cave a control voltage problem. Meaning something is not allowing 24 volts to the contactor. If your out of Refrigerant the low pressure swich will have it off. Call a service tech. Rusty
Posted on Jun 09, 2009
motor1258
  • 6674 Answers
SOURCE: have atwood furnace and coleman mach thermostat
It may be your thermostat, but try this first to see if time delay relay may be sticking. When it won't shut off, turn propane off, and go outside and unscrew the 2 screws that hold your cover on, and lower the cover down. Look straight ahead, attached to the housing of the fan up near top you'll see a square relay (time delay relay) with 4 male spade connectors, and wires attached to each. It's usually held on with 2 Philips screws. Give it a little rap with the handle of a screwdriver or similar a couple of times, and see if fan stops running. While your there as well, pull the wiring connector off the ignition board, and put back on a couple of times, to clean the connections. Now try it again, and let me know what happens.
Posted on Apr 26, 2010
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Furnace burners won't ignite
Assuming this is a gas furnace, when the thermostat calls for heat the pilot heats an igniter to produce voltage that opens the burner gas valve. In your furnace, the igniter may have failed and the burner can't fire up
Mar 09, 2013 | Sport & Outdoor - Others
Furnace won't turn on
What is the make and model# of your Furnace? And is it a pilot light, or a hot surface Igniter?
Dec 29, 2012 | Heating & Cooling
Dual heat system, honeywell thermostat, auxiliary heat won't turn on
IT SOUNDS TO ME LIKE EITHER YOUR SYSTEMS LOW VOLTAGE WIRING IS INCORRECT, MOST LIKELY @ THE FURNACE. IT COULD ALSO SIMPLY BE THAT WHEN THE TECHNICIAN THAT INSTALLED THE T-STAT AT START-UP DID NOT GO THROUGH THE INSTALLER SET-UP & CHOOSE THE CORRECT SETTINGS FOR A DUEL FUEL SYSTEM. TRY THIS " SET THE THERMOSTAT TO EMERGENCY HEAT, WAIT A MINUTE OR TWO & SEE IF THAT TURNED GAS FURNACE ON. IF SO THEN IT'S A SIMPLE FIX IN THE WIRING OR PROGRAMMING & NOT SOMETHING MAJOR! GOOD LUCK!
Nov 25, 2012 | Honeywell VisionPRO Thermostat TH8110
Gas is going to cooking stove in camper. Stove lights. But can't get pilot to light for hot water heater. Don't smell gas coming to pilot area. Furnace is not turning on, but worked fine when...
Chances are good that the thermocouple is bad. It is a small probe that the pilot light keep hot. Take it out and get one at HDepot or at a RV store.
May 27, 2011 | Heating & Cooling
Recently purchased and did not come with owners manual and want to learn the trailers accomidations
You can order a Fleetwood Owner's Manual by sending a check or money order for $8.00 to the address listed below. If you require a chassis manual, you can contact the chassis manufacturer directly.
Fleetwood Service & Training Center
PO BOX 1007
Decatur, IN 46733
May 25, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Heating & Cooling Logo
315 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
