Question about Eureka The Boss SmartVac Upright Vacuum Cleaner 4870MZ
Eureka burning smell
When upright, the brushroll spins fine. As soon as I start to vacuum carpet, the brushroll stops as the friction with the carpet increases. I have installed a new belt so that doesn't appear to be the problem.
    Master:
  • Eureka Master
  • 894 Answers
Hi, it's Cindy from Crucial Vacuum.
Since you have replaced your Eureka 4870MZ 9200 Proheat 2x vacuum's belt, the issue may either be caused by your roller or the position of your belt. It sounds like as soon as your vacuum is lowered, the belt is either slipping or wear on the end caps is causing your roller to stop. This will cause the burning smell since your motor is now straining against the abrupt stop. Try taking off your roller and checking the conditions of the end cap or try to reinstall your belt. I have included an instructional video: http://youtu.be/rji0fl9hytY
You can purchase direct your replacement brushroll from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com viewers, use code: FIXYA10
http://www.crucialvacuum.com/eureka-smart-vac-roller.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Posted on Apr 28, 2014
    New Friend:
  • 57 Answers
Could be electric fire, or just the nornal smell of it.
mine smells like bakon
Posted on Apr 20, 2013
yeroc
  • 397 Answers
SOURCE: Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Posted on Jan 20, 2008
  • 30 Answers
SOURCE: Burning smell and smoke
I ran into a scenario similar to this at work. With the burning smell and smoke combined, it leaves only one problem remaining; the motor. The motor and the pulley that enables the belt to spin could be malfunctioning (causing friction between the 2 parts) and thus causes the burning smell and the smoke. I'd highly advise not to touch either part after having the unit on (YOU WILL BURN YOURSELF).
The only other likely possibility is to make sure there aren't any hairs caught in or around the motor and the bearings of the agitator.
Posted on Mar 08, 2008
SOURCE: Eureka 4870 vacuum brushroll control doesn't work
Use two hands to presscontroll button upward until it snaps in place.
Posted on Jan 06, 2009
SOURCE: The brush does not spin when making contact with carpeting
I tried the electrical-tape-around-the-wooden-spindle technique. After a minute or so, it's back to functioning normally.
Posted on Mar 14, 2009
  • 5 Answers
SOURCE: eureka 4870 roller only spins in upright
if the belt has been slipping it may have pollished the moteror brush shaft and it just slips. take a small piece of sand paper or enery cloth and ruffen up the shaft to give it some grip.
if the metal shaft of the motor has been heated up due to slippage it will take some doing to ruffun it as the shaft will be hardend due to heat
Posted on May 14, 2009
What is wrong...My Eureka commercial vacuum C2094g smells like burning rubber, replaced belt (style RD) but it was smaller in size and very hard to put on. Am I using the wrong belt? it looks like the...
Replace the Roller Brush. Sounds like bearing in it is locking up and the the belt is slipping and not turning the Roller Brush as it has a locked up bearing. You will need to go ahead and get a replacement belt just in case you have stretched the older belt to a bigger size. I had this same experience with a Hoover and it solved my problems of "rubber burnt smell".
Apr 27, 2014 | Hoover S3765-040 WindTunnel Bagless...
The vacuum roller won't turn but the belt is fine Eureka Whirlwind Litespeed
The belt may look fine but it's probably stretched out. Rubber belts are usually good for about 1 year. The tension of the belt is what allows it to turn under the strain of the carpet. Make sure the brushroll spins freely when held out of the machine. Eureka brushrolls are prone to melt down on the end caps. If that has happened you will need a new one.
May 01, 2010 | Eureka Whirlwind Litespeed 5840 Bagless...
No suction, burning smell, expells dust
If by "suction" you mean it's not picking up dirt and debris on carpet, odds are your belt needs replacement, and the belt has burned, causing the burning smell. Ensure that your brushroll spins free, and replace the belt. (Belts should be replaced in any vacuum with a rubber belt every 3-6 months, regardless of use.)
If you mean that you are not having any airflow at the end of the hose, you most likely have a clog in the main hose and the burning smell is caused by your motor overheating. Ensure that there is nothing blocking the hoses.
If you have suction in the hose, and your brushroll is turning, there may be a clog in the head area behind the brushroll. Look in the hose that your wand plugs into, and ensure that it is also clear.
-R
Aug 05, 2008 | Eureka Vacuums
Eureka Altima is smoking!
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618889&thid=606496
Posted by saysay on May 18, 2008
Help! My vacuum is smoking. It won’t work anymore and starts to smoke as soon as it gets turned on.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Eureka Altima Upright Vacuum Model #2996AVS – it is probably doing 2 things, it could be the belt and or brushroll and the easiest ay to check is to remove the belt and see if the motor smokes, if the motor is fine then buy a new belt and check the brushroll to see if the brushroll spins freely, there are bearings in the brushroll and thread and hair get bound up in the ends and needs to be cleaned out. So #1, check the belt – no smoke from the motor then check the brushroll to see if it spins freely then changed the belt. If the motor smokes check your purchase date it may still be under the one year factory warranty from the dop. #2. Either clean or replace the brushroll and belt. If you have any further questions, feel free to contact your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don The Vac Man
Go Ahead. Use Us.
May 18, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Agitator brush wont spin once vacuum is placed on floor
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618889&thid=573865
Agitator brush wont spin once vacuum is placed on...
Posted by coral7980 on May 05, 2008
This vacuum has given me nothing but problems!!! The newest problem is the brush. I have changed the belt several times, it is a new one now. The brush spins, but as soon as you set the machine in place to start cleaning, it stops and burns up the belt. I need help. I don't want to buy another vacuum!!!
The problem that I can see id that you may have a bad brushroll that doesn’t spin freely, and has either bushings or bearings, a simple test is that take the brushroll out of the vacuum, set in on end and spin the brush, does it spin freely or does it stop, the next thing is to turn the motor pulley on the motor, it should spin freely as well, if either one is not spinning freely or easy then there is your problem, or make sure you have the correct belt size and that is a genuine eureka belt instead of a replacement belt for that model, those are the 3 things that should work for you, if the vacuum is less than a year old – take it to a factory authorized vac dealer and if it is the motor and pulley, it is covered, usually the belt and the brushroll are wear items and are NOT covered, some places however might cover the brushroll as a courtesy to the customer. So feel free to contact your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service Phone Number
1-800-282-2886 Hours of Operation
Monday thru Friday 8:00 am to 7:30 pm CST
Saturday and Sunday 10:00 am to 6:30 pm CST
Don – The Vac Man
Go Ahead. Use Us.
May 05, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
When you turn it on....is the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Smell/suction
The brushroll may spin when looking at it but stops when pressure of the floor is applied. The belts stretch, so they look fine but are not. The smell - if it's a rubber smell - would also be the belt. Some, or most, brushrolls can get hair in the ends that could also cause a smell and belt problem.
Dec 17, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Burning smell/lost suction
Is the brush roll turning while on the carpet. If the belt is old, then it has stretched and will slip causing a rubber smell. But if it is an electrical smell, then your motor is failing and will need to be replaced.
Dec 15, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Eureka The Boss SmartVac Upright Vacuum Cleaner 4870MZ Logo
476 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
