Question about Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure Washer 020489
Motor starts but shuts down immediately - Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure Washer 020489
  • 7,482 Answers
Hi ted6565
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 23, 2013
At night its shuts down when the therm is satisfied,but trys to restart right away and when it does start it shuts down right away and just keeps doing this
The thermostat has a differential built into the temperature sensing operation. The differential is normally a degree or more. If the stat shuts down at 72 degrees it should not start the unit again until the temperature in the room reaches 73. If the AC runs and cools properly until it shuts down, I would check the thermostat. The AC can not restart immediately after it shuts off because the pressures in the system are too high at the compressor. It takes a few minutes for the pressures equalize allowing the compressor to start. If the stat tells the unit to start under high pressure, the compressor will shut down on overload. It will start and run after the pressure falls enough for the compressor motor to run.
Jun 04, 2015 | Dometic Rooftop RV Air Conditioner
The Target wet saw TA10100 is shutting down immediately after starting up. Anyone know the part that is causing this. We have replaced the off/on switch and repaired a wire to the switch with new conn
check where your power cord goes inside the saw to the motor. All that wrapping the cord around to pack it up sometimes works it loose. Other wise id take it to a elec motor shop for a new motor, Last one i got i think it was $40 installed. Targets arent' cheap so its worth just putting a new elec motor in it.
Oct 27, 2014 | Saws
Yamaha V Star 1300 starts but immediately shuts down went put into gear with clutch in
clutch plates stuck keep motor off put in high gear like 4th and push back and forth till plates unstick make sure kick stand is up
Jul 19, 2014 | 2007 Yamaha V Star 1300
Radiator fluid leaking down back of engine. Car started smelling real bad, then minutes later began to overheat. Immediately pulled over and shut car off. The only visible signs of anything wrong is r
There are welsh plugs in the block and head/s at the rear of the motor. They are prone to rusting out . I would say that there was a leak and the coolant under pressure started squirting out causing the overheat. Boiling water escaped under the cap or the hose or tank split . Unfortunately to replace the welsh plugs the motor has to come out as there is no room to work in. So while the motor is out replace all of them as they will all be rusty on the inside. At this point and from your description of immediately shutting down I would not expect and problems with the engine but to be on the safe side it would not hurt to have a compression test done to check head gasket and for cracks.
Mar 22, 2014 | 1998 Subaru Legacy
Engine just died
Replace the hose that burst and refill with coolant. If the motor shut down almost immediately then the cpu may have shut down the system to save the motor. Use a code reader to read for faults and also to reset the cpu.
Jul 26, 2013 | 1999 Plymouth Breeze
My dryer starts the first time with no problem, but after about an hour it starts to make a kind of buzzing sound. If I don't shut it off at this point it shuts itself off after another minute or two....
You are absolutely correct that the motor is the problem and needs to be replaced. The motor is overheating and its thermal overload protector trips off causing the dryer to shut down. Thermal overload protector resets and allows the motor to run again only when it has cooled down. It is the reason why the dryer is not turning on immediately after it shuts off. Replacing the motor will definitely solve the problem.
Aug 11, 2010 | Maytag Dryers
My Simpson Water Shotgun shuts down about a minute into the wash
Have you checked the oil level? Some engines have a sensor that shuts it down if the oil is too low
Jul 16, 2009 | Simpson PS2600 PowerShot Commercial-Duty...
Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure Washer 020489 Logo
118 people viewed this question
Top Troy-Bilt XP Garden Experts
CrisO
Ron Durham
Bill Boyd
Are you a Troy-Bilt XP Garden Expert? Answer questions, earn points and help others
