SOURCE: I have a Defy Laundromaid
Error E9 means a problem with your water pressure sensor. Check the sensor by pulling the hose attached to the
bottom part of the tub and blow on it and test the terminals of the
sensor if it will close or open.
Hope helps.
SOURCE: Defy - 13KG Laundromaid 1300
Here's a solution I've gotten from one of the experts..
"Clean the drain motor lint tray/filter. So many 'faults' are
caused by blocked filters. The motor is unable to drain all of the water
in the allotted time.
If you are unsure where the filter is, it is normally behind the front
lower (kick) panel (or in some machines at the rear in an awkward
position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the
drain motor and ensure it is not jammed by a foreign object such as a
needle or a toothpick. It should be able to be turned by hand/finger-
the power IS OFF!
At this point it is also possible to test if the motor works. No clothes
or water in the machine, select a spin cycle and put the power back on.
You should be able to see the motor turning at some point, possibly
straight away. If it doesn't work then the motor is malfunctioning!"
Hope this helps.. Good luck! :)
SOURCE: 1100 Defy laundromaid. hi, my
Either the washer is not balanced (see below) or if it is correctly balanced the technician has not fixed the problem!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is STILL malfunctioning. Recall the technician and do not expect to pay the full cost.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
SOURCE: my washer has an LE
'LE' stands for Lock Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor when there is vibration/movement from the drum turning, requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
John C
SOURCE: Defy Laundromaid 1300 has a
I had the same problem. Defy technician came out paid him and found nothing wrong., leak never stopped. opened machine myself and found the inlet water solenoid laeking. bought the part from Defy R203.00 and the leak is fixed. Waisted my money with Def technician. Hope this will solve your problem
I have a Defy Laundromaid 1300. I was getting an E9 message.How can I solve this?
