Question about Garden
Oil fill briggs and stratton 500e series - Garden
kel1guy2002
  • 3740 Answers
SOURCE: Does the Briggs & Stratton 650 series have an
Hi and welcome to FiXya. I am Kelly.
The 650 series engines are a splash oil lubricating system 6.5 Hp engine. There is not an oil filter on this engine.
The manufacturer specs on this engine state to do the first oil change after 5 - 8 hours of use and then at 50 hour intervals there after.
You should use SAE 30W oil for your engine and if you use "synthetic" oil, it does NOT change the interval period.
Here is the actual engine operators manual:
http://www.briggsandstratton.com/pdf/owners_manual/100%5C277039-Domestic.pdf
Oil change procedure is on page 10 of the manual.
Thanks for choosing FixYa.
Kelly
Posted on Jul 31, 2010
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
  • 41 Answers
SOURCE: Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Posted on Aug 04, 2009
smartr10U
  • 1305 Answers
SOURCE: what type of oil for a 650 series briggs and
B/S webpages show that they recommend a Synthetic 5w-30 oil for their small motors...
K
Posted on Aug 29, 2009
mowerman1857
  • 389 Answers
SOURCE: how much oil to put in a 6.25 briggs and stratten
They hold APPROXIMATELY 20 ounces. Put in around 18 oz and start checking the dipstick and adding a little until it gets to the full or MAX or whatever it says on your particular engines stick. Each time you ad a little, give it a chance to drain down or you will get a false reading
Posted on Sep 20, 2009
What is the coil gap on a Briggs and Stratton 500e series 140 cc engine
If you are replacing the magneto with a new one it should have come with a shim to use. If it is lost or you're resetting the old one a gap of .010" will work.
Apr 06, 2016 | Garden
How to change the oil on a Briggs & Stratton 450
Sandy you can either drain the old oil from the spark plug socket which would be easier or the oil fill point. Remove the spark plug and tilt mower foward getting someone to hold a pot under it. When it's finished draining only put the same amount of oil back in (fresh) When you have done leave the mower somewhere level for a few hours and then start it. It may smoke for a few minutes.
Jul 21, 2013 | Garden
How to change oil for briggs and stratton lawnmower
There a plug on right side of engine close to bottom. Remove it
to drain old oil.
Nov 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
What oil to use 148cc briggs & stratton 450 series
main jet clogged and use plain 30 weight oil in it not not 10w30
May 02, 2012 | Briggs & Stratton Briggs Stratton...
Pull cord wont pull,briggs 500 series
Pull the spark plug out and see if it isnt hydro locked. Someone might have overfilled the oil or the carb float may have stuck open and filled the intake with gas!
If the recoil is still stuck you can remove it from the mower and try it without any load on it. Still stuck? The unit might be rusted solid!
You can spray a little penetrating oil into it but be careful.....the oil will soak the pull cord which should be cleaned and degreased immediately following using the penetrating oil.
Jun 22, 2010 | Briggs & Stratton Briggs Stratton...
What kind of oil does the 22 hp briggs stratton take
from briggs site:
For optimum performance, you should change the oil in your small engine after the first five hours of use and then annually, or every 50 hours of use (whichever comes first).
  • Use Briggs & Stratton SAE 30W Oil above 40°F (4°C) for all of our engines.
  • Check oil level regularly.
  • Air-cooled engines burn about an ounce of oil per cylinder, per hour.
  • Fill to mark on dipstick. DO NOT OVERFILL.
Apr 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
108 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
