Question about Hampton Bay 46056 Callaway II Ceiling Fan
How to change the bulb on my hampton bay ceiling fan cant get dome off
Model 54 shrl cant figure out how to get light cover off
    Genius:
  • Hampton Bay Master
  • 1,617 Answers
Try using some WD-40
Posted on Apr 21, 2013
  • 10 Answers
SOURCE: Hampton Bay Ceiling Fan Windward II
There is a 4 position (dip) switch on both the fan housing and the remote. Make sure these switches are set exactly the same and the remote will control the light and fan separately. If not, the remote may be getting interference on the preset frequency - try CHANGING the dip switches to a different setting and the remote should work.
Posted on Oct 24, 2008
SOURCE: hampton bay ceiling fan , model # 55295
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
Posted on Feb 14, 2009
  • 7 Answers
SOURCE: changing light bulbs in Hampton Bay model AC 527 Ceiling fan
press up while turing it counter!
Posted on Mar 29, 2009
landsend
  • 1066 Answers
SOURCE: Broken glass cover for Hampton Bay Cruiser ceiling fan.
go to Home Depot, not only do they have replacements, but they can order for you what you need.  Hampton Bay is the Home Depot brand.
Posted on Mar 31, 2009
  • 8404 Answers
SOURCE: I HAVE A HAMPTON BAY CEILING FAN. MODEL FAN-2R
This is a universal suggestion, not specifically for your model. There should be a small switch just under the blades ... one position is for summer the other for winter. Move the switch up or down to change the direction of rotation.
Posted on Sep 07, 2009
Change upper light bulbs on hampton bay model 560-084
Please check the manual. If you dont have a manual you can download a free copy from here
Hampton Bay Lighting Manuals
These manuals are courtesy of Hampton Bay
Dec 02, 2016 | Hampton Bay 24002 Ceiling Fan
52" Vaxcel Fresco II Oil Burnished Bronze Finish Ceiling Fan cant change downlight
why not, cant you figure out how to change a light bulb? Look carefully at the way it is made, look for screws to remove a plastic or glass cover to get access to the downlight ,which i assume is a light that points down.
worst case senario is you have to read the owners manual under how to change the light bulb
or call up customer service and ask them how or at least how to call techinical service.
In all fairness , a down light may not be a light bulb that points down , but some kind of compact flouresent light bulb.
check if vaxcel has a web site. they might have instructions on how to change a down light bulb.
Feb 23, 2013 | Hampton Bay 24002 Ceiling Fan
I am looking for a Hampton Bay sauterne ceiling fan. Do you know where I can get one
Hi msslillylu...
Go to the following webage and purchase your Hampton Bay Sauterne Ceiling Fan.
Please take time to rate me thumbs up
http://www.kaboodle.com/reviews/hampton-bay-54-in.-sauterne-antique-umber
Sep 14, 2011 | Hampton Bay 24002 Ceiling Fan
Trying to remove cover that houses the ball and pipe that hangs the fan. There is no screw to hold the ceiling mount cover to the ceiling mount. I tried pushing up and twisting but no luck. Could someone...
There should be a couple of small screws at the very top on the side of the canopy...you will need to loosen these a few turns and then turn the canopy and drop it down...
This link will help you they had the same problem as you...
http://www.askmehelpdesk.com/electrical-lighting/hampton-bay-ceiling-fan-removal-25673.html
heatman101
Apr 29, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
We have a hampton bay ceiling fan model 54cvt. We cant figure out how to change the light bulb or change the direction of the blades. We dont have a manual for the fan.
This fan is also known as the Hampton Bay Covington 54 Ceiling Fan. You need to turn the globe anti clockwise until it comes out. The full instruction manual can be found here.
http://lightingworldbay.com/hampton-bay-covington-ceiling-fan-54-cvt-manual/
If you have another fan model other than the Hampton Bay 54CVT then try here
http://lightingworldbay.com/hampton-bay-ceiling-fan-manuals/
Jun 28, 2009 | Hampton Bay 52 In.Carriage House II in...
How do i remove the light to change a light bulb?
i looked it up online and they called it a:
Single Bowl Twist and Lock Light Kit.
Some things i would suggest:
  1. push it up and turn (like when you open a medicine bottle.
  2. try to look for a spring action peg that clicks in automatically around the glass dome that might be locking it...
please comment my solution :) thanks
May 31, 2009 | Hampton Bay 52 In. Indoor/Outdoor Tahiti...
Light bulb burned out in ceiling fan
THE FAN IS ACTUALLY A WINWARD II BY HAMPTON BAY. ACCORDING TO INSTRUCTION MANUAL YOU TURN THE GLASS BOWL COVERING THE LIGHT ASSEMBLY UNTIL IT MAKES CONTACT WITH A COUPLE OF GROOVES IN THE RIM AND THE GLASS ASSEMBLY SHOULD RELEASE. I DID NOT RECEIVE ANY HELP FROM "FIXYA" BUT MAYBE THIS INFO WILL HELP SOMEONE ELSE WITH THE SAME PROBLEM. THE MODEL # OF THE HAMPTON BAY FAN WAS 523 342. (I FOUND MY INSTRUCTION MANUAL AND THIS IS WHERE I GOT MY INFO)
Mar 27, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton Bay ceiling fan with pull chains not working
Whether there is a reset switch on this unit or not would depend on the model. If you no longer have the owners manual you should be able to get it from the hampton web site. Many fans have a thermal fuse inline that probably was blown when the bulb broke. The cheaper models do not and then I would guess you burned out the switch.
Feb 07, 2008 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Change light bulb
I have a fan just like that one to change a light bulb all you have to do is unscrew it from the fan itself and if that dosnt work then unscrew the plastic cover or unscrew a screw on the plastic cover
Dec 30, 2007 | Madison Avenue 04889 Hampton Bay Ceiling...
Hampton Bay 46056 Callaway II Ceiling Fan Logo
268 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
