Missing Instruction Manual
shared by 7 users
posted by True Aries on Aug 02, 2007
My family recently moved and I cannot seem to find my instruction manual to my daughter's car seat. I desperately need to know how to adjust the straps on my daughter's car seat. Any information that you can give to assist me is greatly appreciated.
Thank you.
Comment posted on Aug 02, 2007
Thaanks for taking the time to review/answer my question!
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Posted by NIKKIE1982 on Jan 06, 2009
I HAVE THE FERRARI CAR SEAT AND IT SEEMS THAT I CAN'T RELEASE THE STRAPS TO PUT IN THE APPROPIATE SLOTS AS THEY ARE JOINED TOGETHER CAN ANY ONE HELP
Posted by yrromo21 on Nov 20, 2008
haveing a hard time tring to adjust the harness
Posted by Guest on Sep 05, 2008
I need to put the straps back together
Posted by krystlehmc on Sep 02, 2008
We just had another baby and im using my infant carseat that my one year old had used, now i need to clean it and i dont know how to take it apart to put the cloth in th washing machine. I have spent a half an hour trying to take it apart please help.
Posted by Guest on Apr 21, 2008
manual
Best Solution
posted on Feb 05, 2008
FixYa! (100)
Gloria21
Rank:Apprentice Apprentice
Rating: 92%, 2 votes
Thanks for posting that answer. My husband and I spent almost an hour trying to figure out how to adjust those darn harnesses. So, I got on on the web to see if I could find any help. After about 15 minutes (and I was about to give up),, I located your posting....yaaaaayyyy. YOU ARE DEFINITELY APPRECIATED FOR THIS!!!!!!!!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Missing Instruction Manual:
I don't want to Accept this solution
Solution #2
Helpful (85)
sgregg
Rank:Guru Guru
Rating: 88%, 186 votes
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407
the above link is for the manual but here are the instructions.
If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Thank You!
Solution #3
posted on May 26, 2008
Not Rated (0)
vtara718
Rating: 0%, 0 votes
THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Airlines lost my seat and gave me this seat to use while they "look" for mine. No one there knew how to adjust the seat so I buckled my child in it and held on for dear life. Once I got home Imessed withit for an hour. Finally finding your directions this morning it is all taken care of now! Thanks for taking the time to help us all out!
Thank You!
Solution #4
posted on Jan 17, 2008
Not Rated (0)
christina555
Rating: 0%, 0 votes
Thanks for helping me win the wrestling match with the car seat! I was about to make matters worse by undoing the upper straps that are woven in and out of the plastic pieces on the top. Whew. U rock.-Christina
Thank You!
Can you Help with these Car Seats problems?
Evenflo Embrace
when ford installed the saftey strap anchor in the trunk...
Evenflo Embrace
We bought the Evenflo tandem stroller and we need the...
Evenflo Embrace
accedentally put care seat canopy in backwards and have no...
Evenflo Embrace
tether strap come out of th ecar seat. I need to put it...
Evenflo Embrace
How do I remove the car seat cover so i can wash it?
6 Other Users Have The Same Problem - Continued
Comment by mdaisy2006, posted on Apr 13, 2008
hi i have a ferrari car shown below but i have lost my instuctions and for the life of me cannot strap the seat into my car can someone please let me know if you know how to strap it in or a site where i can see the instruction manual thank you
car seats>highback boosters>Ferrari Advance SP highback booster seat with integral harness- Red\",\"Product\",\"Product:car seats\",\"event11\",\"scene 7\",\";870869\");"> car seats>highback boosters>Ferrari Advance SP highback booster seat with integral harness- Red\",\"Product\",\"Product:car seats\",\"event11\",\"scene 7\",\";870869\");">zoom Ferrari Advance SP highback booster seat with integral harness
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Top Repair Providers
X
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
