Question about Hansgrohe HG06128830 Swing C Pull-Out Spray Kitchen Faucet, Polished Nickel
Why does hot water have very little pressure - Hansgrohe HG06128830 Swing C Pull-Out Spray Kitchen Faucet, Polished Nickel
  • Hansgrohe Master
  • 5,245 Answers
Why won't lp 125 shut off after you turn off faucet continues to burn then backflows hot water through cold supply line and melts it then pressures up and blows line
It sounds like there is too much pressure in the hot water pipes. You can try adjusting the pressure. Do it a little at a time to see how much hot water is coming out. The only other thing I can think of is that there is a large delay between the switch and the water flow. meaning you will need to stop the water a while before you actually want the water to stop flowing.
Elisa Jed ' http://www.mccreeryhvac.com
Jul 14, 2014 | Bosch & Tankless LP Hot Water Heater
Heater wont start. I replaced the pressure witch, doesnt work, I by passed the pressure switch and put the red and blue wire together and it will run until it gets hot. I remove conected wire and...
What water heater do you have?
Is this a tankless or tank-type water heater?
If tank-type, what gas valve is on the heater?
What does the water heater manual say?
Add a comment with more information for possible help, or possible re-direct to correct expert.
Sep 22, 2011 | RELIANCE ELECTRIC WATER HEATER
Just purchaced a 99 jamboree with an atwood G6a-8e water heater. while on a trip I lit the water heater, and after 30 minutes someone told me water was leaking from the side. I noticed the pressure relief...
It's gas operation only, but has electronic ignition for propane. ( just to confirm, if you look at back of water heater, it would have a metal or black plastic cover and hydro cable going in side or top of it.)
There are usually 3 things that may cause pressure relief to leak. 1) Faulty,corroded pressure relief valve, which usually needs to be replaced if it goes faulty. 2) water temperature is getting too hot, which could indicate a faulty thermostat. 3) If your hooked up to city water, the pressure may be too high, causing excess pressure build up in hot water tank, thus pressure relief opens. If your running off your on board pump, this is probably not the cause, as they are usually set at 40 psi.
Ist, - try pulling lever on relief valve slightly open ( careful it's hot !!) to clean out any calcium that may be logged on seal thus causing leak. If that doesn't do it, and the hot water isn't running out steady and appear to be under extreme pressure while leaking, then I'd change the pressure relief valve. Remember when you do, shut off water to system, and relieve pressure by opening a tap, and pressure relief as well after that. New one shouldn't be too expensive, just make sure you get same thread, 1/2"NPT or 3/4"NPT. Use a little teflon tape, or pipe dope whatever you prefer when re-installing as well as clean threads a little before.
If it really starts gushing out pressure relief when heating or heated, and water seems hotter than normal, it's more than likely a faulty thermostat. I'll wait for your reply on what condition your experiencing before I go in to how to change the thermostat.
Nov 17, 2010 | RTO Atwood Water Heater - 6 Gal LP
Little hot water flow with Grohe 1000 grohthern
Yes it sound like you have blockage in the mixer .
Jan 17, 2018 | Grohe Grohtherm Thermostatic Rough-In...
Water heater shuts off when the cold water is turned on
Not sure but check the inlet water at the heater, the filter may be clog up a little that restrict the flow. Did u use the heater at all during the winter? If not, the heat exchanger may be clogged with built up in there. U need to descale it. Good luck. Chinhcu
Mar 31, 2017 | Bosch Water Heaters
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Hot water does not come out
I pulled the water heater out of the rv and found the one way value broken and cloged.replaced with new one $9.12 and put back together.works great.
Mar 27, 2009 | Water Heaters
I have a Rinnai system. Good cold water pressure, little hot.
What type of pipes are install on this heater?
Mar 13, 2009 | Water Heaters
Hansgrohe HG06128830 Swing C Pull-Out Spray Kitchen Faucet, Polished Nickel Logo
32 people viewed this question
Top Hansgrohe Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Hansgrohe Water Heater Expert? Answer questions, earn points and help others
