Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
Wish to remove bottom ofpowerhead-Kenmore Progressive 11629912990
Opps!!! Lost manual. I wish to remove the bottom of the powerhead of my Kenmore Progressive canister vacuum to remove the power brush to really scrub and clean the brushes, check the belt...etc...
Power Head: model number: 11659912990
Kemore vacuum: model number:11629912990
p.s. I looked at the bottom of the Power head and saw a notification: ''insert screw drive here...'' I think I'll wait for further instructions....
Thanks A Bunch for any help!!!!!!
  • 134 Answers
I have a whispertone vacuum, different model #, but maybe instructions will be the same. Turns out I didn't need a new belt, just clean out the crud and reset overload protector. The instructions in the manual tell you to remove the light cover and bulb first. To do this, press in and lift both sides. Push in and turn bulb counterclockwise to remove. (you need to do this because the next step involves turning the unit over). This takes you to
Step 2. Unscrew the cover screws ( on either side of bulb).
Step 3. Turn unit over. To remove cover, insert screwdriver at cover tabs on both sides and twist to release tabs.
Step. 4 Turn unit right side up. Press handle release pedal and lower the swivel. Tilt cover forward from back until front snaps free.
Step 5. Carefully insert and twist screwdriver at each brush support to free brush from base.
Step 6. Remove worn belt.
Step 7. Slide brush supports off to check and clean brush support areas.
To replace belt: slide washers and brush supports onto brush assembly.
Install new belt over motor drive, then over brush sprocket.
Snap brush supports into place on base. Be sure brush supports are not upside down.
Line up front of cover and base. Rest cover on front edge of base. Tilt cover to back. Press cover firmly until side tabs snap into place. Replace cover screws, light bulb and light cover.
Posted on Mar 12, 2009
On the Kenmore powermate the cover over the light can to be popped off, the directions for the base and brush removal are on that plate. Basically you take out the 2 philips screws and then the bottom can be pried off easily with a twist of the screwdriver. For easier removal and detailed cleaning the rubber around the base can also be taken off. The directions indicate it's necessary to put a flat head scewdriver between the bearing and the base to remove the roller.
Posted on Apr 27, 2009
Where can I get a manual for a powermate 4.1, model 116
You can either go to Sears.com and look up your model there for it. Or you can go to "Manuals Online" and find one there. They can provide almost any manual to any appliance you have there.Good Luck and I wish you success fixing your Vacuum.
Mar 14, 2011 | Kenmore 23612 Progressive PowerMate Bagged...
Powerhead is working - but not sucking up. When I click to Floor nothing is coming on
When you say the powerhead is working, I assume you mean the light comes on and the rotating agitator brush turns when you switch the unit fully on.
Please clarify what part exactly does not come on and when?
Do you mean the primary vacuum motor in the large main section of the unit is not coming on?
If you take off steel pipe part off from the handle and hose, are you getting any suction at the handle opening when you switch it on?
Have you checked or changed the collection bag recently in case it is full?
I will be pleased to assist you further if you can provide some additional details regarding your problem.
You may wish to unplug the power cord to your unit first and then check all of the electrical wiring connections between the handle and the power head. There are a few male / female 2 prong connectors that carry electrical power to the head unit. They are nooriously prone to corrosion and poor electrical contact leading to various intermittent malfunctions.
Just take a screwdriver or some sandpaper and scrape off / remove any dirt or corrosion from the electrical contact prongs in the connectors and then reconnect them securely.
Just comment back here to this page if you have questions or require further assistance.
Please remember to click on the 4 Thumbs Up icon if this was at all helpful.
Thank you very much.
Joe.
Feb 16, 2011 | Kenmore 23913 Progressive PowerMate Bagged...
How do I change belt in power head? Is there a
There could be 2 different ways to access the belt on the kenmore line of powerheads...
1) turn the powerhead over so that the bottom is facing up. IF there are screws on the bottom, remove them. There should be 2 either at the back where the rear wheels are, or one under the elbow, and one midway at the front under the lifter wheels. remove the screws, and there should be two tabs on the sides to remove the top cover. OR 2 tabs at the back of the unit near the screws to remove the top cover.
2) and this is the more common powerhead...
remove the light cover for the powerhead by pressing at the two sides and pulling the cover up. sometimes a screwdriver to pry open a little will help.
Remove the light bulb.
Remove the two screws.
Turn the head over and pry at both sides to pull the top cover off.
Good luck with either one.
Nov 18, 2010 | Kenmore Vacuums
We have a Kenmore canister vacuum cleaner. the carpet cleaning attachment, I think is called the power mate has a beater that is intermittently working now
Your hose could be bad. The wires frequently go bad up by the handle switch. also could possibly be the wand, those go bad. You can check that by attaching your powermate directly to the nozzle without the wand and see if the same problem is there. Do you have the mini powermate also? the one that is usually mounted on the wand. If so plug that in directly to the hose and see if you have the same problem. If that tool works fine then the problem is in the powerhead.
Jan 03, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
Need to know if a replacement part can be purchased and where
Kenmore canisters are privately labeled Panasonic canisters and sometimes panasonic parts will fit them. Any reputable independent dealer should be able to tell you if the part you're looking for is intercharngable with a Panasonic, but he/she will probably need to actually see the unit.
Your other option is to take it to the Sears service dept. They are the only ones who have access to the schematics and "Kenmore" parts. It'll probably be more expensive through them though.
Dec 02, 2008 | Kenmore 22812 Bagged Canister Vacuum
Roller brush isn't spinning
Depending on which powerhead this is, if you removed the light cover, then removed the 2 screws, from the bottom edge, you will see a slot where you can insert a flat blade and pry out to release the tab, there is one on each side. If this one where the 2 screws are removed form the bottom, then there are 4 locking tabs, 2 on the back and one on each side.
May 26, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Can't get the case off the beater bar assembly
Wish I had the complete model number, but you can go to sears.com and click on the parts link and enter your model number, a parts list and a picture diagram showing the breakdown will come up.
On some of the powerheads, you take out 2 screws, then there are tabs holding it together on the back and on each side, release them and the top comes off.
On some othere, the cover over the light comes off, depress te sides and back to release it, then there will be 2 screws to take out. Then using a flat blade, you will see slots from the bottom edge of the top cover, pry out from these slots and the top will come off.
May 18, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
560 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
