Question about HP Compaq Presario SR1215CL (82916052980) PC Desktop
RAM capacity ?
What is the RAM capacity for a Compaq SR1215CL ?
  • HP Master
  • 27,725 Answers
Memory Upgrade Specs for HewlettPackard Compaq Presario SR1215CL Computer. The HewlettPackard Compaq Presario SR1215CL Computer takes the PC3200 DDR SDRAM 184-pin DIMM Memory Type, and comes installed with 512MB (Removable) of Memory. You can upgrade your HewlettPackard Compaq Presario SR1215CL Computer to up to a maximum memory capacity of 2 GB Memory, the system has 2 Sockets to install Memory, already with 512MB (Removable) standard Memory installed. For best Compaq Presario SR1215CL Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible http://www.memorystock.com/memory/HewlettPackardCompaqPresarioSR1215CL.html
Posted on Apr 20, 2013
How much ram can i upgrade my compaq presario? I keep getting conflicting info. The tech at Office Depot said I was maxed out 2Gigs and upgrading any more would shut it down. But I'm reading forums...
One good and easy way to find out for sure how much RAM your computer can hold is to go to WWW.CRUCIAL.COM and run their SCAN MY COMPUTER feature.
This handy utility will scan your hardware configuration and tell you exactly how much RAM you currently have installed and what type it is.
It will also tell you how many RAM slots are fitted on your motherboard and what the maximum memory capacity is for each slot and the total capacity for that motherboard.
If your computer does have room to add more RAM, it will provide you with specific recommendations as to exactly what type and size of RAM stick to get to maximize the memory capacity and performance of your computer.
I hope that was helpful to you, good luck.
Joe.
Nov 05, 2011 | HP Compaq Presario SR5350F Desktop PC...
Runing out for hardrive, can I just add more hard drive. 120gb and want to go to 3-500 gb. Can my model handle it? sr1215cl
According to the specifications, the motherboard supports two PATA hard drives and two SATA hard drives.
You can install SATA hard drives to any capacity you want.
Nov 07, 2010 | HP Compaq Presario SR1215CL (82916052980)...
Adding an RAM to a Compaq PC
The laptop supports upto 4 Gb RAM.
Following is the user manual on how to replace the RAM
http://h10032.www1.hp.com/ctg/Manual/c01118662.pdf
Thanks
proton
Jan 10, 2009 | Compaq Presario C700T Notebook
Increasing the capacity of RAM.
According to what I found here, you can increase up to 384 MB RAM.
Jan 03, 2009 | Compaq Presario 700 470024-192 Notebook
RAM UPGRADE FOR HP COMPAQ 6720s
The speed of your computer is determined by the memory capacity, the hdd storage capacity (that means that if the hard drive is full of data your computer becomes low - not about the size of your hard drive) and your processor speed.
In your case I recommend:
1) A good cleaning,
2) Be sure that your computer is not virus or spyware infected
3) Get rid of those programs that you are not using.
4) Disable the programs that are running on the background
Sure after that your computer will become faster.
Your memory capacity is good enough to your normal duties (above described)
Oct 03, 2008 | Compaq Computers & Internet
Ram capacity?
256-MB SODIMM in slot 1)
1024 MB (133 MHz) SDRAM
512-MB SODIMMs in slots 1 and 2
Jan 05, 2008 | Compaq Evo N600c Notebook
Presario will not start
Hi, remove the left side of your case, turn on power and see if you can see a red or green led light on the board, if its not showing then your power supply is faulty. If the light is on then with the power off check the RAM chips are tight. if that does'nt work Then trace the cables from the front of the case, locate which is the pwr switch and unplug that, turn the poweron and then use a small screw driver and bridge the pins of the pwr switch. If this does not work you have either a dead CPU or a dead motherboard. Regards mistyman
Oct 07, 2007 | Generic Memory Compaq Presario SR1215CL by...
HP Compaq Presario SR1215CL (82916052980) PC Desktop Logo
89 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
