Question about Radio Shack Pro-2052 Scanner
Pro-2052 volume control
The volume control seems to be in the loud position, it will not turn down. Sometimes it does adjust softer but then it creeps up in volume?
any ideas?
Thanks, Jeff
2 Suggested Answers
  • 99 Answers
SOURCE: i sometimes get static noise on my pro-2052 after
You most lilley live where there is a cable TV system. Most installers don't understand the concept of termination when they disconnect someone's cable, so the cable "leaks" signal all over the place. There are enough birdies generated by cable systems, especially now that there are digital broadcasts on these systems.
Try moving the radio to another location. If the problem persists, tighten the squelch..
Posted on Aug 31, 2010
How do I change silent from on to off so phone rings when I get a call?
On the D1680, D1481, and similar phones,
the three levels of ringer loudness plus
"off " are set at the base using the same
[ - ] Volume [ + ] buttons used to adjust
the answering machine message volume.
Pushing the [ + ] and [ - ] keys will
set the ringer to be louder or softer. A
number in the "message counter display"
will report the relative loudness...pushing
[ - ] below level-1 loudness will show
"0" loudness and an announcement of
"Ringer off" will be spoken. From here,
a single push of [ + ] will turn the ringer
on to level-1 and play a ~10 second
sample of the ringer at that volume:
while it is playing the sample ring,
subsequent pushes of [ + ] or [ - ]
will toggle the loudness levels of
( off, 1, 2, 3 ).
Jan 05, 2016 | Uniden DECT 6.0 Cordless Phone ID
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
MY 2004 EXPEDITION SEEMS TO HAVE ELECTRICAL ISSUES....sometimes when i put the key in the ignition the memory seat moves forward to the memorized position but sometimes it does not.... likewise, when i...
the convenienc module is probly fried-its a sort of semicomputer that controls accesories etc---go to a private mechanic and ask if he has xperienc in this area--may b able to get one in a salvage yard-but new or used they need flashing to work w the main computer--napa store can help u
Jan 25, 2014 | 2004 Ford Expedition
HOW DO I TURN UP THE VOLUME
Users will continually need to quickly change the volume on a TOMTOM units, depending on the loudness of traffic noise, the radio or conversations. Although there are no external volume controls, the volume on the ONE can be easily accessed on screen by touching the bottom left corner of the map display. Once the volume controller appears you just slide your finger to increase or decrease volume. We found the audio levels a little softer on this unit and had to set the volume to around 60% or 70% in order to clearly hear it.
Please rate my help++++Thanks for using Fixya
Dec 12, 2009 | Tomtom One XL GPS Receiver
Sound adjustment doesn't work to get louder, only softer
take it apart.on the back of the push buttons there is a graphite coating.sometimes oil gets on it and it won't work properly.clean the pc board gold contact areas and the back of the carbon buttons.if the carbon is worn off,cut a small piece of foil 1/8 inch in diameter,and glue it to the back of the button. that will make contact with the pc board foil to make it work.
Jul 03, 2009 | Logitech Harmony 880 LCD Remote Control
POLAROID 37" TV - VOLUME STUCK ON LOUD - CAN'T TURN UP OR DOWN
sound like the volume is locked out you can access this in the main menu to unlock it
May 29, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Volume Control
I had the same issue, there is a Late night mode on the remote that minimizes the volume of a loud scene so you don't have the constantly adjust the volume. Works great if you are trying to watch a movie while others are trying to sleep.
Dec 15, 2008 | Onkyo HTR500 Receiver
SA-AK95 volume control problem
This volume controls is actually what is called an encoder. The control itself needs to be replaced. Figure on $5-$10 for the part plus the local labor rate for the total repair cost.
Dan
May 01, 2008 | Panasonic SC-AK75 Shelf System
Volume goes up and down by itself
  • i think the problem is due to dust
  • using a vaccum cleaner or use a painting brush for clean the IC legs and ciruit
  • check loose conection of the control
  • the dust mis function the chip inside
wish you all the best
Jan 17, 2008 | Creative Labs Inspire T2900 Computer...
Volume Control
How do you have it hooked up to speakers (are you using a center channel)? What listening mode are you in (dolby digital, stereo, pro-logic...)? It sounds as though you're not getting center channel info....
Jan 09, 2008 | Onkyo TX-SR605 Receiver
Radio Shack Pro-2052 Scanner Logo
43 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
