Question about Home Security
How do I program Sears Garage remote 139.18718
It has three buttons. One big one on the right and two smaller ones on left and middle?
  • 118 Answers
SOURCE: Garage door opener remotes
Guest- You opener is locked. Hold down the lock button on the wall control for 3 sec. and it will unlock the opener.
Posted on Jan 29, 2009
glenmann62
  • 91 Answers
SOURCE: programing garage door opener remote
ok crystal,calm down this is an easy one! first locate the smart button on your openers , next you will press and hold down the smart button until you see an indicator light above it shut off, while your holding that button the light will be solid ,Now your ready to program your remotes ,first programm one side by taking each of your four remotes and pressing the smart button on machine then pressing the button on the remote you want to program,by doing that you will notice the lightbulbs on your machine shut off and go back on , This is an indicator that your machine has accepted the code , now do it with the other three remotes , after you,ve programmed all four ,go over to the other machine and repeat the process but this time you have to choose another button on your remotes since you,ve programmed all four remotes to the same button on each remote ,just choose the bottom button on your remotes this time to keep them seperated , hope this helps you and it is as easy as 1-2-3 your owners manual will describe exactly the same ,i know because i,ve installed over 27,000 machines working as an installer for sears, please leave a nice feedback rating if i was able to help you, good luck,Sincerely Glenn Mayer
Posted on Apr 01, 2009
SOURCE: Sears garage door keypad/remote programming problem
Hi All,
I had the same issue recently and here's what I found out (through a LOT of research) and the solution (yes, there is one!):
As described by many, when you can't get both the remote and the wireless pad to work together it means your garage door opener can accept both rolling code and billing code technology, BUT not at the same time. When you reset all codes (normally by pressing a button on the opener for a period of time e.g. 6 seconds or more), you erase all codes and remote "pairings". Then when you follow the manufacturer's procedure to pair again (which could be the wireless key pad first OR the remote first), the first pairing determines the technology for all subsequent pairings. Example: if your first pairing/programming was with the wireless keypad, and if it was rolling code technology (normally the case for newer models), then the garage opener will only recognize and accept rolling code for subsequent pairings. If your remote(s) are older (billion code technology) then the opener won't even recognize the signal (e.g. led won't blink when trying to pair/program).
And vice versa if you start with your remote after erasing all programming (then your keyless pad won't work).
But here is a potential workaround! For newer wireless keypads (e.g. clicker from chamberlain), you have an option to select the type of opener you are using as you do the initial password set up (normally indicated by a number e.g. 1 for models built after 1995, 2 for models built between 1997 and 2004, etc). Each choice is associated with a technology in the background (e.g. either rolling code or billion code). If you are programming your wireless keypad first after erasing all codes / programming, if you chose the "recommended" option for garage opener, chances are it will be rolling code and that means you won't be able to program your older remotes (billion code) after that. So how can you chose the option that will match your remote???
Here's what you do: start by pairing / programming your older remote first after erasing all codes / programs. That sets the technology (e.g. billion code). Then, go ahead and program your wireless keypad, but you may have to go through the process several times by trying the different options until you find one that works!
For me, I had to try 4 options before making it work. Options 1 through 3 (mind you, options #2 was the exact match for my garage door opener model but it would cause the problem discussed here e.g. wireless keypad would work but not the remotes) would not even be recognized by the opener in this procedure (LED would not blink), but it did work once I hit option 4.
I hope this will help you with your problem. Let me know if it's not clear. Cheers!
Posted on Apr 15, 2009
  • 3197 Answers
The button you added in your car is an earlier technology that is not compatible with the rolling code technology.
Posted on Jun 01, 2009
SOURCE: Sears garage door opener
I just found the solution for my 'ancient' Sears garage door opener, model # 139.655000, and I figured I'd share it.
There's a separate radio module, wired to the main opener. This module is small, has a short wire/antenna, and plugs directly into an outlet.
There's a manual open/close button on this module (I didn't realize this until I got up on a ladder). This button is also a removable cover; underneath it is a "smart actuate" button -- this is your learn button.
What I did was: unplug the radio module. Pry off the cover. Plug the radio module back in. Hold down the button on the remote. Press the "smart actuate" button. This programmed my remote successfully!
Posted on Sep 21, 2009
Liftmaster chamberlain professional 771E-03 infrared sensor - have these on my gate system and operate it with a button system - was told sensors needed replaced - have done this but the one button keypad...
Why don't you try contacting Chamberlain? The information is below but you need to get the model number of your system. The number you give must be a part number of some kind.
support@chamberlain.com, or call toll free Technical Support Hotline at (800) 528-5880
Aug 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
On the Liftmaster remote control, there are two smaller push buttons to the left of the large button which opens the door. What are the two buttons used for?
You could program these buttons to operate other garage door openers or to control other devices that work on the same frequency. http://www.liftmaster.com/consumerweb/products/pflHomeConvenience.htm has light controllers that let you turn on or off a light in your home with the garage door opener. You can easily program one of the small buttons to control the lighting system instead of the main button. (Thus the light would be controlled independently of the door opening and closing.)
Single button remotes can be purchased but currently most garage door openers are sold with the 3 button versions. http://www.liftmaster.com/consumerweb/products/pflRemoteControl.htm
I hope this helps.
(In my household, there are 4 garage door openers installed. When three of the door openers were on the same frequency, we could have had each one respond to a different button on a three-button remote. Now two are on a separate frequency so only two buttons have been programmed on the various remotes. (One group opens the house and workshop; the other opens the house and barn.))
Apr 30, 2011 | liftmaster 83lm Billion Code 3-button...
My husband and I are separated. How can I reprogram my car's remote button (not an actual Sear's control)...so he can no longer use it, that is programed in his car as well. We have a three car garage,...
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and hold this for 6 seconds. This will erase all programming from memory and you will now need to program your remotes and keypad if you have one. Do this for each opener.
To program your remotes hold the button down on the remote while you press and immediately release the smart/learn button. Do this for each remote.
To program your keypad, press and immediately release the smart/learn button and then walk over to your keypad and key in any 4 digit code you like and press enter.
Sep 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote control unit does not open the door. we
You can try reprogramming the remotes to the opener that is not working. Sometimes they get a brain freeze and drop the codes and reprogramming can fix it. Next to where the wire hangs down will be a colored square button (the learn button) press once and release, you have 30 seconds to try and program a remote, you don't need to do all in the 30 seconds. Press and hold the button on your remote that you want to use until you see the light on the opener blink or hear a click sound from opener, let go of the button. it should now be programmed. If you can't get any of them to work then the logic board is bad.This repair can cost as much as a new opener + install. Sears sells a "remote control conversion kit" it comes with 1 remote and a plug in receiver you attach to your existing opener. 2 wires come off it and hooks up where your wall control hooks up at the openr.It's pretty easy to install. FYI the remote controls are color coordinated meaning the buttons on the remotes have to be the same color or they won't work, so if existing remotes are not the same color as the one in the kit they will most likely have to be replaced. good luck!
Jul 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Factory garage door opener
If this is the 3 button HomeLink Transmitter usually centered overhead above the rear-view mirror, this should work:
While the engine is turned off follow these steps to program up to three channels:
1. Decide which one of the 3 channels (one of the 3 HomeLink buttons) you want to program.
2. Press & hold the desired button through step 3.
3. When the HomeLink indicator light begins to blink slowly(this may take up to 30 seconds), hold your hand-held garage door remote about 1 to 3 inches away from the buttons & then press and hold the button on your garage door remote. Continue to hold both buttons until the indicator light on the HomeLink begins to flash rapidly(this may take up to 90 seconds).
If it still doesn't work, make sure the batteries in your garage remote are not weak, and try again moving the remote back & forth and left & right or turning it upside down while programming.
Also note HomeLink will not work with older garage door openers, especially not with ones manufactured before April 1st 1982.
Feb 18, 2010 | 2005 Buick Rendezvous
Re-program Chamberlain garage door openere.
Try programming your opener this way. Locate the smart/learn button which is just to the left of all those white wires. Press and hold the button on your remote while you press and immediately release the smart/learn button. Do this for each remote. Do not hold the smart/learn button in as it will erase the memory and your remotes will not work.
Sep 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do i program the garage door transmitter that's found on the 2001 chrysler town and country
If you have a hand book that comes with the van the instructions are in there. on the top panel you have one two or three dots on a switch you have to hold the garage opener next to the switch in the van press both together until it flashes .
Apr 23, 2009 | 2001 Chrysler Town & Country
How can I program a craftsman remote for my door
THE OTHER BUTTONS ARE FOR ADDITIONAL DOORS.
CHECK THE FREQ. (FREQUENCY) IF YOUR NEW REMOTE IS NOT THE SAME FREQ. IT WILL NOT WORK - YOU WILL NEED TO GET ONE THAT HAS THE SAME FREQ.. - THEY ARE AVAILABLE FROM YOU LOCAL GARAGE DOOR DEALER.
HOPE THIS HELPS
NOTE: THE FREQ. IS ON THE BACK OF THE REMOTE AND NEAR THE PROGRAM BUTTON ON THE POWERHEAD - THEY CHANGED FREQ A COUPLE OF YEARS AGO.
Apr 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programing garage door opener remote
Mar 12, 2008 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
427 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
