Question about Yard Man Yardman Riding Lawn Mower 38in Deck 12 12 Hp
Cut off when dropping blade
Motor cut off when blade is dropped
    Sergeant:
    Champion:
  • 320 Answers
Check the safety switches for proper operation.
Posted on Nov 10, 2013
The cutting height adjustor pedal drops to low cut setting? Why?
the adjustment rod screws into a threaded receiver raise the tractor and screw the threaded screw back in then make the adjustment. Good luck
Feb 11, 2016 | Husqvarna Garden
I have a Wahl 9877-500 Beard Trimmer that doesn't seem to be cutting my goatee anymore. What could be the problem?
Blades on the trimmer are worn, or it may simply need a few drops of oil at the cutting blade.
May 15, 2015 | Wahl Health & Beauty
Put new belt on 42 inch poulan pro, now one side cuts lower than other
Spindle is most likely wore out allowing on blade to drop down lower than the other.( most likely )?? 25+ years small engine mechanic as well as motorsports.(solution buy mew bearings replace or sometimes cheaper to just replace whole spinde with bearings already in it. Hope this helped.Ofcorse could b bent blades ect but most likely the bearings have allowed blade to drop down.
Jun 30, 2012 | Garden
Blade slows down when cutting
there are a few factors that can affect blade turning, first is the type of wood and its thickness, how fast you are tyring to push it through, they type of blade and weather or not it is sharp and that the "kurf" is set properly, if it is not set correctly the blade will bind and slow down, it can hurt the motor too. one other thing is the voltage. if you are running the saw on an extension cord rather than plugged in directly to an outlet, you may experience a voltage drop, Never use an extension cord longer than 80 feet as you will see a voltage drop of 20 volts, (depending on the size and quality of the extension cord). If this is an old saw, the motor may just be wearing out and especially if the saw has been used in a commercial environment and for many hours without cooling down. If I think of anyting else I'll add a comment later, good luck
Mar 22, 2011 | Saws
Table saw stopped when cutting a dense piece of wood. Now just hums when turn it on. Not locked up, the pully will move by hand. Do you think replacing the capacitor will work. No restart button. ...
One thing you might try is to raise blade to highest setting possible and spin blade as rapidly as you can by hand and turn on while blade is still moving. see If motor will go ahead and come up to speed or try to I would replace start capactor. Also check brushes and make sure motor is clean and free from saw dust. Lube motor if equipped with oil ports. I would just use 3-4 drops and wipe off excess. Blow out with compressed air and also make sure belt is not to tight. I hopes this helps you, Thanks
Nov 17, 2010 | Craftsman 10" Table Saw
My drop saw runs at 5000 rpm .most 14" discs are only rated to 4400 rpm. Are there 14"discs rated at over 5000rpms
go 2 home depot and buy Norton brand blades a lot of blade suppliers are putting a pic of cutoff saw on the blade itself 2 tell u its 5400 rated home depot and Norton r the cheapest and lasting
Jun 29, 2010 | RTO 20 14" Abrasive Chop Saw Blades Metal...
Brother 1034D serger is not cutting and is binding up
This problem is usually when the lower blade drops below the sewing plate. Look at the blade in relation to the plate and see if it has dropped below the plate, then you can reset the blade. If it is not the upper blade may be too dull to cut so it will need to be replaced.
Jul 03, 2009 | Brother 1034D Mechanical Sewing Machine
Globe Meat Slicer Model # 500 motor runs blade not turning
Fiber gear on blade hub stripped. deep socket required to remove hub. DON'T CUT YOURSELF!! remove motor, used food safe solvent to clean grease out of housing. Fiber gear held on with snap ring. Replace gear, repack housing, put hub and motor back and start slicing. Routinely check to make sure gear is lubed.
Oct 30, 2008 | Berkel 827E Gravity Feed Deli Meat Slicer
Yard Man Yardman Riding Lawn Mower 38in Deck 12 12 Hp Logo
Top Yard Man Garden Experts
Richard Schanie ...
Phil Walker
Phil Walker
itsman
Are you a Yard Man Garden Expert? Answer questions, earn points and help others
