Question about Toshiba 32BV700B 32 in. LCD HDTV
Need to reset tv
Blue screen showing so signal
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
I keep getting a blue screen on my Insignia TV. Cable box still shows the channel and I can change channels but nothing on screen. No sound either. This TV is not even 3 years old yet.
A blue screen indicates no video signal, if you change the video input to a DVD player is it still a blue screen? If yes then the TV is defective. If no then some how the signal is being lost to the TV from whatever source you use for watching broadcast TV
Apr 05, 2017 | Televison & Video
It has "V1.43 Pace PR150BNM SysCode Loader" Pace. Across the top of blue screen, what's up?
Element Electronics blue screen no signal Questions ... - Fixya
www.fixya.com > Forum > Tags > blue screen no signal
Blue screen with ''component 2'' in a box shows. Then it goes black.There is also a humming coming from the tv. I have unplugged everything from the tv, and ...
element tv problem - YouTube
? 2:26
https://www.youtube.com/watch?v=2FnqRRcQzNs
Feb 17, 2010 - Uploaded by pacman552sd1
... is a vid im attaching to my email to custamer support to try and fix my bad tv. ... LG LCD TV REPAIR - NO PICTURESCREEN FIX REVIEW ...
Dish Network - My element TV is saying "no signal". ' Directly
Jan 09, 2016 | Element Televison & Video
I have astron tv 14 inches. when i connect outdoor antenna the. tv screen turn black. no signal. no reception but when i disconnect the outdoor antenna it turn to blue screen.
blue screen means 'no signal' or 'signal level is too low' whereas black screen means that there's a signal. Check your antennae, do a factory reset to your unit and then try initial setup.
Feb 26, 2015 | Televison & Video
Mitsubishi 50 real projection blue screen
Turners are Bad Signal Board Call Encompass Parts 1-800-638-3328 or your nearest Repair Shop.
Dec 31, 2009 | Televison & Video
Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Oct 29, 2008 | Vizio GV42L 42 in. LCD Television
Power went out while tv & Direct TV was on
The garbage on your unused channels are not important, just artifacts from signals not strong enough to produce a picture.
The 'blue screen' on #3 is what many sets use when they sense they are connected (terminated) to 'something' but not receiving any signal.
If sounds a lot like DTV's receiver took a hit.
If you have a second set you can borrow or drag to the receiver, try it first but I don't think it is your problem unless the cable input on it was zapped.
Jul 12, 2008 | Televison & Video
No picture, blue screen only
Good Day;
It sounds like you have a lack of signal; 1. reset TV by unplugging TV & signal sources from wall for at least 5 minutes then plug back in, 2. Turn all eguipment on such as cable box, dvd & etc, then change the inputs from your TV's remote, if still no pix,only blue.
Good Luck.
May 01, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Tv monitor turns blue during forward or reverse vcr search
On some TV's the screen will go blue if there is not a strong, solid video signal present. This is to prevent the showing of very snowy or all snow channels, or garbled, mixed-up external video signals. This is normal. On some VCR's the video signal changes when the FF or REW search feature is used, and this could trigger the TV to go to blue screen. The only way around this if you can enter the TV's menu and turn off the blue screen feature.
Jun 23, 2007 | Panasonic PV-V4020 VHS VCR
Toshiba 32BV700B 32 in. LCD HDTV Logo
18 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
