Question about GE 30 in. Profile JP350 Electric Cooktop
How do I disassemble a GE radiant cooktop model JP350 to replace the burner switch
I have a GE model JP350 cooktop and the main burner works on low but when you move it to the high setting the breaker trips. I have removed the cooktop but not sure how to open up the unit to check the burner and switch. Any suggestions?
  • 4 Answers
SOURCE: GE JP350 wiring problems
a to black one
b to red one
d to orange
e to grey
a-e to red two
a-d to black two
a-c to orange two
a-b to grey two
a-a to white
Posted on Jan 20, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Cooktop radiant heat element problem
Sounds like you need to replace the burner control (part # WB23K5053)
Posted on Mar 02, 2009
jmgldsmth
  • 1869 Answers
SOURCE: Radiant cooktop blew a fuse?
Call the service tech it;s under warranty and, this model is notorious for this fault
Posted on Apr 21, 2009
Daniel S
  • 4323 Answers
SOURCE: GE radiant cooktop model JP350.
Hi
Test the switch for continuity, if it tests open then replace it however, replacing both of them is always a better option. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 19, 2011
SOURCE: I have a GE 36" Profile Gas Cooktop JGP963 and when i light one of the burners, it trips the GFCI , main breaker and a little fire ball comes from under the knob. what could cause this?
IT SOUNDS LIKE YOU HAVE A SHORT IN THE IGNITER. YOUR COOKTOP SHOULD BE ON A DEDICATED CIRCUIT AND NOT A GFCI. YOU MIGHT HAVE TWO CIRCUITS TIED INTO THE SAME RUN. POPPING THE GFCI AND THE MAIN BREAKER IS SUSPECT. THE GFCI SHOULD SHUT DOWN THE CIRCUIT WITHOUT POPPING THE MAIN. THIS IS PROBLEM THAT SHOULD BE LOOKED AT BY AND ELECTRITION.
Posted on Apr 04, 2013
JP350.. Large burner (front right) only the inner circle lights up no matter where the switch is set (large or small). Bill wjgibbon@syr.edu
Sorry to read about your problem, I hope this helps you out.
you have a defective control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
ewrwer
werwer
Dec 23, 2010 | GE 30 in. Profile JP350 Electric Cooktop
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Radiant cooktop stays on at low settings. fix?
it is the burner switch that needs to be replaced.the thermocouple function is built in the switch.
Aug 17, 2009 | Cooktops
Mar 02, 2009 | GE Cooktops
Burner not working
try to clean the injector if no gas came out.or try to use matches to have a flame, i think there a problem in ur spark igniter if the gas is going out.tnx
Nov 22, 2008 | GE 30 in. Profile JP350 Electric Cooktop
a to black one
b to red one
d to orange
e to grey
a-e to red two
a-d to black two
a-c to orange two
a-b to grey two
a-a to white
Jan 19, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Burner always on high
I have had this same problem on the JP350.
I have replaced the switch several times, and am now tempted to replace the heating element and the switch the next time it becomes constant (currently, it is intermittent... which has led to some burnt food).
Nov 10, 2007 | GE 30 in. JP340 Electric Cooktop
GE 30 in. Profile JP350 Electric Cooktop Logo
105 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
