Question about Acer TravelMate 2480 Notebook
Compaq Presario CQ50 Labtop, makes awful constant beeps
A day ago my Compaq Presario CQ50 labtop, stopped working. When i try to start it up it makes a constant awfully loud beeping noise and nothing appears on the screen, the fan doesn't run anything, Before this problem occurred i was updating it's features for something i think were along the lines of Win flash, then my screen froze except for media that was playing at the time and the keyboard and mouse sensor wouldn't respond. Before i had over heating problems but the computer simply shut itself down if it happened. I've taken out the battery and tried to reboot it but the problem still occurs. Any advice would be appreciated.
  • mewmew_nya Mar 12, 2009
    Gah, your right i called the tech support good thing too, im still on warranty soit would have cost 430$ for repairs but luckily i still have 165 days for warranty so it was free, that was a major save (-_-;) thanks for your help~! ^-^
  • 211 Answers
If you shut it down when WinFlash was running, then bad news - BIOS corrupted. This means faulty motherboard. Solution - replace motherboard.
Posted on Mar 11, 2009
  • aliokas Mar 12, 2009
    Good for you ;)
My labtop scren will not come on.. compaq presario v6000
Did you change the "DISPLAY SETTINGS" on the system ?
Jan 26, 2013 | Computers & Internet
My labtop makes a high pitched siren like noise when you initally boot it up, the mouse icon and various other icons flicker randomly from time to time, and the computer usage is over 50% constantly when...
hi
Im Kapila from Sri Lanka.
to solve the noise like a siren,
open the sound mixer (double click on the speaker icon on the task bar) and mute the mic on that, or decreas the mic level.
its OK, you can adjust it the audio settings perfectly via double click on the audio icon in control panel.
not enough the details for flickering problem.
send the message to kapilarl@yahoo.com regarding that
Nov 15, 2010 | HP Compaq Presario CQ50-110US Laptop
Black sreem on a compaq labtop cq50-215NR compaq
1 disconnect the AC adapter and remove the battery from the laptop
2. Press and hold the power button for 30 seconds
3. replace the battery and connect the ac adapter to the laptop
4. turn On the notebook and check.
If the issue persists, restart the notebook and press F10 to check if you see the BIOS screen. If you cannot see the BIOS screen then the issue could be hardware issue and your laptop needs to be repaired
Jun 16, 2010 | Compaq Computers & Internet
The display on my laptop has stopped working. All I get is a blank screen. A couple of days before lines appeared on the screen and if you moved the screen it flickered on and off....any ideas?
there is a ribbon connector that runs from the labtop to the screen .... eather it has become loose ro disconnected or the screen has shorted out the first of the two sounds like the problem
Mar 01, 2010 | HP Compaq Presario CQ50-110US Laptop
My sons compaq presario cq50 wont run
I could well be wrong, but my gut feeling is that your laptop is having memory issues. Start by accessing the memory and (carefully) removing it from its seating. Give it a quick check for dirt / dust etc and then re-seat it. If you have multiple memory modules, try swapping them round. Replace all covers and then restart the computer. Hopefully it's as simple as that. If not, you may need new memory, or alternatively the beep codes for your laptop refer to something different.
If you can get some Compaq support online, check that out for a dagnosis of the beep codes. That might point you in the right direction, assuming the above attempted solution is of no use.
Sep 30, 2009 | Computers & Internet
If a compaq presario cq50 says error 1005, what does that mean?
Error 1005 is an HP restore error which means you need to install from a standard DVD from HP. You can order this from various websites on the internet. They are about $30-$45 plus shipping.
Aug 07, 2009 | Compaq Presario CQ50-215NR Notebook
Webcam
You will need to isntall the software for your webcam. You can usually download the software / drivers from the manufacturer's website.
May 30, 2009 | HP Webcam
Pass phrases on labtop
wot dose it say when your trying to get online
Nov 16, 2008 | Compaq Presario Notebook
Compaq Presario needed a new battery was installed labtop will not charge up!
When you install a new battery and remove a battery always make sure the laptop is completely shut off and have the power cord removed so that you avoid any possible power surge.
Batteries generally don't last much longer than a year and I have found removing the power cord or battery when it is off to be a good practice.
Before you charge a battery make sure it is run most all the way down. Recharging a battery when it is not run down can give it a memory and you may only be able to charge it up to the point you started charging it.
Anyway, if the computer won't charge a new battery then you could have a bad motherboard. To be sure try another battery.
Sep 09, 2008 | Compaq Presario Notebook
Labtop lights up no work
change the battery...
another solution, try to re- install OS
Sep 24, 2007 | Compaq Presario 900 /1500 Series EVO...
Acer TravelMate 2480 Notebook Logo
646 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
