Your belt is burning and will eventually wear down and break. The green light comes from copper brushes on your roller creating an electrical current that lights the little green light. As long as the roller is turning, the light will stay on. There may be something jamming the roller (hair, string, paper, etc). Clean the roller off and replace your belt. If you don't replace the belt it will break soon enough. Once you start smelling the "rubber burning" smell it's and indication that your belt has deteriorated at some point and has a weak spot in it. Clean the roller and replace the belt and it should be fine.
SOURCE: kirby G5 vacuum
Here is a link to the help you need,,,
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
The G5 manual is out of print, but the G6 and Ultimate G models are exactly the same and wil work perfectly for your questions.
Marci
SOURCE: Help on kirby G4D
here is a link to taking the fan off of the kirby...all the Generation Series Kirbys are the same :)
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
Hope that helps!!!
SOURCE: how do you install the belt on the kirby vacuum
Step 1:
UNPLUG YOUR KIRBY VACUUM CLEANER. Before you go any further, take your time with this belt change. It's not that difficult, just a little different than most other vacuums. These belts are very easy to find on the internet.
Step 2:
You should be facing the front of your Kirby vacuum. The height adjustment lever will be on your right. Push the lever all the way down. Lift the light hood with your left hand. Turn theKirby vacuum belt lifter counter-clockwise with your right hand. Unlock the accessory lock. The accessory lock is located under the light hood. Move the lock to the left to disengage it. Remove the front of the vacuum cleaner.
Step 3:
Turn the vacuum belt lifter all the way clockwise until the belt drops down. Unlock the roller plate by releasing the two latches on the rear. Pull the roller plate up slightly and then off.
Step 4:
Bend one end of the roller bracket just enough to remove the roller. Remove this end of the roller. If you need to replace the roller take it all the way out. Remove any carpet fiber, string, or hair from the roller with a scissor.
Step 5:
After you have removed the old belt, slide the new one back on the middle of the roller. If you're Kirby vacuum cleaner has a belt indicator light, the roller will have a magnet built onto one end of it. It's very important to install to install a roller with a magnet on the same side as the indicator light. The roller actually will only fit into the roller plate one way.
Step 6:
Place the roller back in the roller bracket. Place the roller bracket back and lock it into place with the 2 latches. Rotate the vacuum cleaner belt lifter counter-clockwise. You should feel the the belt catch. Look inside to make sure the belt is being stretched onto the vacuum belt lifter. Reassemble the machine. After you have reassembled your Kirby, turn the belt lifter cockwise, releasing the vacuum belt onto the vacuum motor shaft.
SOURCE: my kirby ulitimate G series will not turn on
HELLO,
PLEASE SEE MY TROUBLESHOOTING GUIDE...
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
MANY OTHERS HAVE HAD SUCCESS WITH DIAGNOSING AND FIXING THEIR OWN KIRBY USING MY GUIDE. I HOPE THAT YOU ARE ONE OF THEM... :0)
MARCI
SOURCE: Green light on power nozzle of Kirby vacuum, Model G7D
The green light is just to inform you that the brushroll is spinning. there is a magnet on the brushroll that makes the green light come on every time it rotates. also why it looks like the light flickers because the magnet only makes contact once per rotation of your brushroll. Let me know if you have any other questions.
