Question about GE Dishwashers
Wont drain Not draining...soap was flooding the floor half way through the cycle
  • courtneypaig Mar 12, 2009
    I did use dishwashing detergent!
  • GE Master
  • 3,361 Answers
The wrong type detergent was put in the washer.
Set it to pump out. Then pour in cold water and pump out again. Do this over and over until the suds are gone.
Cold water helps kill the sudsing and dilutes it so it will pump.
Make sure you use dishwasher detergent next time.
Posted on Mar 11, 2009
  • steve
    steve Mar 12, 2009
    What brand?
My Beko WMP601W wont drain, clothes come out soaking wet, also the draw keeps oozing with suds, all over the floor???
You need to check the drain pump is free of any obstructions, can you hear the drain pump operating?
The machine will need several short wash cycles to flush out the excess soap which is causing the suds.
Mar 26, 2017 | Beko Washing Machines
How do I fix the nd problem with my amanda front loader washing machine?
the ND stands for no drain, it means the machine will not drain the water, and its saying something wrong with the pump, not necessarily. , if you can open the door and remove the cloths do so, then use a 5 gallon bucket of hot water and bleach and poor it in the door, if its already full of water it may not open, drain out all you can with a cup or can before filling it with hot water, try to go to a wash cycle, important the sensor in the machine may be coated with soap and by doing this it will clean it,run it a while to use a few cycles then try to spin and drain, it should straighten up, only use about a half inch of soap, in the washer most people use a half cup or whole and its to much, the sensor thinks it full of water, but there is no water to drain therefore, no drain, you can also remove two screws from the back panel and you will see the pump, it could be clogged with a dime or quarter, taking this hose or hoses loose will let the water out and on the floor, unplug first,you can remove the pump easily and check it three screws two hoses and its off, make sure its unplugged,Matt
Jul 06, 2015 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Whirlpool Ultimate Care II is not draing properly and water is flooding out during spin cycle.
remove the hose up where it connects to the tub and see if there isn't anything stuck there,you could still have something stuck between the tubs and it usually will end up here or you could have a damaged pump from the piece of towel you pulled out of it or there's another piece still up in between the tubs and hopefully you'll find it at the hole where the drain hose is.
Jan 22, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Drain pump always running even after a reset
So you need to replace this flood sensor. i am thinking it is in the bottom of the machine and senses the a high water level in the wash tank beneath the wash arm.
Google
make model spares
you will end up at a site like this. Look for the part and replace it. I used 'Bosch dishwasher flood sensor' as the search query.
dishwasher Google Search
Mar 29, 2017 | Dishwashers
Floods floor when on rince cycle Program Bed andBath. Fault intermittant
If you didn't flood the floor when the washer emptied on the wash cycle, it is more likely that you have a partially plugged up drain than a malfunctioning washer!
Has you drains been cleaned lately, being the spring time you might have a root problem partially blooking the drains.
Watch you washer, if the washer flushes the water down the drain line it is working. If the water comes over the top of the drain line, then you have a slow drain.
Jun 01, 2011 | Washing Machines
I am getting a lot of suds over flowing out of my drain pipe during my rinse cycle. What is the problem?
If your drain flows well then you're using too much soap. Try about half the soap you're now using, see if it's enough. You want just enough suds to show that you have enough soap, any more than that is wasted.
lp
Dec 26, 2010 | Amana Washing Machines
If I do a small load after a large load, on the rinse cycle teh water gushed up through the drain in the floor and floods the floor. The plumber snaked 50 feet twice and poured down acid and it still
Since the plumber snaked 50 feet, one must conclude that the blockage is beyond the 50 foot mark.
Shame on the plumber who stopped at 50 feet. he should have snaked all the way to the street system if you live in a city or to the septic tank if you live in the country.
I would call him back and tell him that he needs to finish the job.
May 21, 2009 | GE WWSE5200B Top Load Washer
Water leaking from botom of Door
see if float cup is free on bottom of machine so it is not overfilling. take old toothbrush and clear any accumulated soap buildup from bottom of door and gaskets.
Feb 16, 2009 | KitchenAid Dishwashers
Cant drain and cant open the door
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Jun 26, 2008 | Creda W100FW Front Load Washer
Danby countertop dishwasher
i would think the drain hose from the unit is leaking from the description you give.let me know
Dec 24, 2007 | Danby 22 in. DDW396 Free-standing...
Dishwashers Logo
63 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
