Question about Wolfgang Puck Reversible Grill and Griddle
This is ridiculous. what's the best way / is it a lost cause to brown ground meat on a griddle or indoor grill? my oven and stove have quit working and i'm a little desperate.
You can use it like an electric stove; just put the fry pan on the griddle part and turn it on high.
Posted on Mar 23, 2009
Meat does not brown in gas oven
Hello - Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately two minutes and turn the range back on. Select a normal bake cycle and if issue continues then the unit may possibly have either a faulty element, bad communication error with the main control board, oven sensor, or mechanical thermostat. I strongly suggest contacting a professional to move forward accurately. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage.
Oct 28, 2012 | Frigidaire Gas & Electric Stove/Oven/Range...
Food sticks to griddle
You can either use a cooking spray like Pam on the griddle prior to heating it. Or if you're cooking steaks, rub a little olive oil on each side of the steak, before seasoning (kosher Salt & Fresh Ground Pepper) it. For meats, always allow them to come to room temperature before grilling and allow the grill to preheat until is extra hot. The hotter the grill/griddle, the less likely red meats will stick to it.
Hope this helped you and Happy Grilling!! Thanks for choosing FixYa.
Aug 12, 2011 | Coleman Roadtrip Grill LXE 9949-750
Looking for a GG-2-PR for a Cusinart GG-2
everyone knows Cuisinart products save time and now they save space, as well. The Cuisinart™ Grill & Griddle has a large reversible, nonstick plate to make it two appliances in one. An embedded heating element lets you evenly grill poultry, meats, fish and vegetables. Not in the mood to grill? Flip the cooking plate and set the electric thermostat to perfectly cook pancakes, eggs, crab cakes or fajitas!
Feb 21, 2011 | Cuisinart GG2 Indoor Grill
What is the best way to clean the flat top griddle?
Wow that is a loaded question. Everybody seems to do it differently. I will give you my two cents. Start with a medium hot grill. Throw on a little clear water and steam off the bigger gunk and scrape it down. (I have heard that sprite or 7-up or ginger ale work real well here too). After that mix together about two cups of water (some people use cooking oil instead of water) and 3/4 to 1 cup of vinegar and pour that on slowly while scrubbing the grill with a Grill Brick (Lava Brick) This is where you are really doing the work. Scrub until clean -- may take a while. When done use a rag dampened with clean cooking oil to wipe down the grill and leave a little sheen on top.
Dec 09, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Can grill be safely converted to griddle on Thermador PRG486GLUS?
try this.
If it doesnt fit your specs. then i would suggest u find a thermador parts place and begin to buy the parts for the griddle as replacement parts. find a model of the stove set up that you want and make a list of all the parts that go to the griddle attachment.
My guess is that the reason for the flat "No" on the retrofit was that griddles require a thermostat similar to the one on the oven and broilers do not. So if their is no room behind the face plate where the knob would go then you can't put in a griddle. The other issue might be that the burners for the griddle wont line up with the brackets that are holding up all the broiler burners now. The griddle burner looks exactly like the one from the over only smaller so it has to line up strait where a regular front and back burner have to line up offset. maybe since you have the broiler already that should not be an issue? Then the problem is finding the griddle top it self that is going to be spendy. I think the link i gave at the top is your best bet. good luck.
Mar 19, 2009 | Thermador PRG484GGUS Gas Kitchen Range
Oven proof ???
Hi yes all stone ware is oven proof so you should have no problems using them just remember they stay hotter to the touch for longer than other oven products they stay hotter for longer once their out of the oven let me know if you need further assistance ok
Mar 19, 2008 | Crock Pots & Slow Cookers
Vulcan 260L Gas Commerical range
I'm assuming you're speaking about a meat grill or another grill in contact with food. It is generally made of cast iron. This discoloration is normal and is caused by fats impregnating the grill. In practice, this will prevent sticking of food in the future. Grills should always be seasoned with a small amount of oil or fats and cooked on. They are cleaned with a mild soap solution after use but not scrubbed to a shine. If you do not like the look, simply wipe the grill with a small amount of cooking oil.
Dec 03, 2007 | Vulcan 260L Gas Kitchen Range
Wolfgang Puck Reversible Grill and Griddle Logo
305 people viewed this question
Top Wolfgang Puck Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Wolfgang Puck Kitchen Appliances - Other Expert? Answer questions, earn points and help others
