Try to print-message no paper. there is paper then message paper jam. there is no paper jam hit ok then it prints. copy attempt same messages spits out two pages of blank paper then nothing un plug machine and re plug - says aligning -error alignment failed
This means one of the cartridges is defective, they cant align if they cant print. What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center. When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in. I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black. Basically you align the cartridges and then swap them so the printer thinks they are still aligned. The color still doesnt work and it is probably a defective color cartridge.
Testimonial: "thanks for all the replys, But nothing works. it prints a test page fine. I assume print cartriges are fine .On initializing it says error in aligning. after two steps .out of paper then paper jam it prints on the third try. But will not do likewise on the copy attempt. I can't think there is much of a problem when it prints a test page, But I have tried everything except purchasing a new printer."
SOURCE: align cartridges error
SOURCE: Print Cartridge Alignment Failure
two option:-
1. cartridge is not proper. or
2. not proper installed.
SOURCE: HP OfficeJet 6110 All-In-One
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
812
SOURCE: hp officejet 6110
If machine does not print the colors it cannot align. Try changing the color and try again
Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
High speed 250mm/s Easy loading
en.sprinter.com.cn
Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
