Question about Dryers
My kenmore gas dryer (super capacity mod. 417 98042701) won't turn the gas on to get heat. This started with all the lights on the front flashing. This went on for a couple of weeks. The dryer
For the last 2 or 3 weeks the lights on the front would flash at random. The dryer would shut off before the clothes were dry. We would turn it back on and it would finish drying the clothes. Now it won't even turn the the heat on. The dryer runs and the blower works but it won't ignite the gas.
SOURCE: Intermitten Heat up
I would like to thank the ones who responded to giving me a 'hand' in repairing my dryer. I did like you said & changed out the coils & now the dryer is working like it should.
Posted on Apr 12, 2008
SOURCE: No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Posted on Nov 11, 2008
  • 1028 Answers
SOURCE: Kenmore gas dryer not heating up
ck/replace the 2 black coils on valve they will sometimes fail after 1st start up slight chance it may be flame sensor mounted on side of burner to ck remove the 2 wires and short together temporaily if flame stays on and reignites ckd vent system first bad flame may cause sensor to shut it off if flame/vent ok replace sensor
Posted on Nov 27, 2008
aborcass
  • 2651 Answers
SOURCE: gas dryer runs, cleaned hose, get warm does not heat up to dry
with a gas dryer in which your assured te hventing is free and clear of any obstructions, i would look to replace the coil pack located atop the gas valve itself, probably about $25 part number 279834... 2 coils simply mount atop the valvle
Posted on Feb 12, 2009
SOURCE: Maytag Neptune MDG 5500 AWQ heats sporatically
GAS DRYER WORK FOR MINUTES AND THAN STOPS!
Posted on Apr 19, 2009
Kenmore 110.97561602 gas dryer won't start
The dryer may not be detecting that the door is closed.
Jul 17, 2014 | Kenmore HE2 6.7 cu. ft. Gas Super Capacity...
My gas dryer runs but with no heat
Most likely you need to replace the heating element that ignites the gas.just turn off the gas line unplug the dryer and remove the front cover then you will see on the bottom right there Is a heating element bolted to the gas valve with one single quarter inch bolt.You can either remove it and inspect it for little hairline cracks or check for continuity with a multimeter.If you see a crack or have no continuity replace the ignighet
Apr 15, 2014 | Kenmore HE5 Steam 7.5 cu. ft. Electric...
No heat
make sure that the gas is turned on. if it is the next step is to check the fire chamber. it is a tube about 3in round. there is an igniter toward the front of the tube that when it calls for heat it glows bright red and then gas comes in the tube and it lights it up. if the igniter is not hot enough it will not light the gas. that means u need to replace the igniter.
Apr 15, 2014 | Kenmore HE5 7.0 cu. ft. Super Capacity Gas...
No heat in EH5 dryier
do you get heat when you first start the dryer ? if you do i would replace the coils and check venting , if not i would check the igniter to see if it is broken
Feb 17, 2013 | Kenmore HE5 7.0 cu. ft. Super Capacity Gas...
Gas dryer will heat sometimes and not heat other times kenmore model 72802
sounds like bad gas coils,you have to send the whole model number,it will start with 110. or similar,if the bottom panel comes off,remove it,start the dryer, or in the front panel down near the bottom pop off the cover and look in,if the flame lights and then after 10 to 20 minutes the flame doesn't light you have bad gas coils.when the coils are starting to fail they will work correctly until they heat up and then they won't work until they cool down,the coils are what opens the gas valve.the coils are on top of the gas valve,remove the two phillips screws,pull off the cover,remove the wires from the coils and install the new coils,put it back together and you'll be fine,also while you're in there,get a shop vac and vac out the cabinet,stick it on blow and blow all the lint off of the motor and out of the gas tube,then clean out the duct that the lint filter slides into.if your vent line is a long run from the back of the dryer to the outside,i use a leaf blower remove the vent line from the back of the dryer and blow all the lint outside out of the line,do this once a year,you won't have any fires,your clothes will dry on time and your motor and parts will last longer
Oct 28, 2011 | Kenmore 72802 Gas Dryer
My Whirlpool Cabrio dryer Mod. WED 6600 VWO won't
When I turn the dryer on say to 40min,it shows does not come on and it goes to a F1 on the daily
Jun 26, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Hi, I have a Kenmore gas dryer model 417. I can't
Sounds like the coils on the gas valve are bad.
May 26, 2011 | Kenmore Dryers
I have a RCA dryer and it makes a humming sound when I try to turn the switch to start the dryer. The dryer will not start.
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 03, 2010 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer
Dryer timer is not working and won't heat but runs fine
check the ignitor. That's a very common cause for no heat in a gas dryer. other possibilities are the coils, or it could be that you have a bad fuse in the dryer.
Dec 26, 2008 | Kenmore 73952 Gas Dryer
How to light the pilot light on a Kenmore gas dryer.
no pilot light has glow bar ignition ..ck to see if bar glows when start button is pressed should be small plastic cap on bottom of dryer front remove it to ckd for glow and burner operation
Aug 29, 2008 | Kenmore 75962 Gas Dryer
Dryers Logo
62 people viewed this question
Top Dryers Experts
