Device buzy hp deskjet 2520
Device always busy can't use print and scanner operations
SOURCE: I Have a Hp Deskjet
How do I download and install the software? To download the software, do the following:
  1. Click here to go to the Software and Drivers page for your product.
  2. Click your operating system.
  3. In the Driver section, click the appropriate software driver.
  4. Follow the instructions on the page that appears to download and install the software.
How do I install from the CD? Two installation options are available when installing the software and drivers from the product CD. The recommended install installs everything your device requires to work, including a suite of software recommended for your installation. The custom install allows you to choose what software to install. The recommended install is designed to work for most users. Use the custom install only if you have one of the following reasons:
  • Low hard disk space on the computer.
  • You do not want the additional software.
  • Errors occur during the recommended installation. NOTE: If errors occur during the recommended install, fix them before doing a custom install.
Recommended install Complete the following instructions to install the software: CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Choose unblock or accept on all firewall messages or the install will fail.
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer starts automatically. NOTE: The User Account Control screen might display. Click Continue .
  2. Click Install on the Thank you for purchasing from HP! screen.
  3. Click Next on the Welcome to the Install Wizard... screen.
  4. Click Next on the Do Not Block HP Install Wizard Processes screen.
  5. Select Yes or No on the Automatically Check For Updates screen and then click Next .
    • Choose the Yes (recommended) option to check for updates through an Internet connection.
    • Choose the No option if you do not want to check for updates.
  6. Select Recommended on the Installation Options screen, and then click Next .
  7. Follow the instructions on the screen that displays to finish installing the software.
Custom install CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Select unblock or accept on all firewall messages or the install will fail.
  6. Select Custom on the Installation Options screen, and then click Next .
  7. Select which software to install by selecting or clicking to clear the check box next to each item on the Custom Installation screen. Click an item to see its description and the required disk space. NOTE: You must install the drivers and the HP Imaging Device Functions for the buttons on the front panel to be functional.
  8. Follow the instructions on the screen that displays to finish installing the software.
Posted on Aug 19, 2008
yooperbud
  • 8637 Answers
SOURCE: HP Business Inkjet 1200 printer always prints the Alignment Page
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
sys_admin
  • 829 Answers
SOURCE: HP Deskjet 4280 scanner problem
Possible causes
  • The system resources are too low to facilitate scanning.
  • The USB controller is sharing an Interrupt Request (IRQ) with another device.
  • There are multiple entries (ghost entries) of the scanner in the Device Manager.
Step 1: Open the System Information tool Windows 98, Me, and 2000 Pro Click Start , Programs , Accessories , System Tools , and then System Information . The Microsoft(R) System Information window opens. Microsoft® Windows XP Click Start , Help and Support , Tools , My Computer information , Advanced System Information ,and then Detailed System Information (msinfo32.exe) . The Microsoft System Information window opens. Step 2: Verify the available system resources If the system resources available are below 50%, the scanner may have difficulty transferring the scanned image to the computer and will stop in the middle of a scan.
NOTE: Windows XP does not give system resource information in the System information window. Skip to Step 3 if using Windows XP.
  1. Select the System Information linein the left side of the System Information window.
  2. In the right side of the System Information window, verify that System Resources are 50 percent or above.
  3. If the System Resources are lower than 50 percent, increase system resources .
Step 3: Check for IRQ sharing between USB and other devices The USB controller normally shares an IRQ with the IRQ Holder for PCI Steering device. While this device does not cause any conflicts, other devices on the same IRQ may cause a conflict.
  1. With the System Information tool open, click the plus ( + ) next to Hardware , then IRQ’s . In the screen to the right, information about will appear showing which IRQ a device is using.
  2. Verify the USB controller is on an IRQ with nothing else sharing it except the IRQ Holder for PCI Steering. Examples of USB controllers are listed below:
    • Sis 7001 PCI to USB Open Host Controller
    • Intel 82371AB/EB PCI to USB Universal Host Controller
    • Intel 82801 BA/BAM USB Universal Host Controller
  3. If the USB controller is sharing an IRQ with another device besides the IRQ Holder for PCI Steering, contact the computer manufacturer for assistance in moving it to another IRQ.
Posted on May 24, 2009
cene765
  • 787 Answers
SOURCE: My HP Business Inkjet 1200 printer always prints
Some of print heads may be failed.First clean very well the contacts on the print heads and printer using piece of cotton and some alcohol.If not help look which color don't print and replace that print head.
Posted on Nov 16, 2009
  • 127 Answers
SOURCE: My HP deskjet 2050 all-in-one
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
Posted on May 31, 2011
Tip
EZ steps to install HP printer in Windows 7 without Installation software
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
on Jan 29, 2010 | Office Equipment & Supplies
How to i change my printer from scanner to print documents
you have to download and use the software provided by hp to your operating system. Then you can perform all the functions that you need.
Aug 06, 2012 | HP Deskjet 2050 All-in-One Printer
Lost disk for HP Deskjet, and I need to install the software. Help!
Access the manufacturer's web-site: http://support.hp.com
and enter the model-number, and do the search.
Select your Operating System (XP? 7?)
Select the device-driver.
Download it.
Install it.
Print a test-page.
Jun 06, 2011 | HP DeskJet F380 All-In-One Printer
I have installed HP 1220c printer on windows 7 in several ways. Printer seems istalled OK, when I try to print test page or other, the printer doesn't react. Although the print appears and dissapears...
Unistall any previous you have installed for your device.
The Driver for Your Product Is Included in the Windows 7 Operating System (i.e. Win 7-32bit & 64bit).
Simply connect the printer to your computer with a USB cable, and Windows Update automatically installs the driver for your product.
Hope it helps.
May 30, 2011 | HP DeskJet 1220c InkJet Printer
My printer is hp deskjet 2050 j510 It's always printing page including error code 00000000 And error code 0299c2ed
My printer is Hp Deskjet 2050 J510 Series. It prints well the first line but the last lines, it does not print. The after a while it send a message like this.
Error Code: 00000000. Please help me to solve the problem.
May 22, 2011 | HP Office Equipment & Supplies
I am having HP F-4288 Deskjet Printer All purpose. I have lost the Installer CD How can I download the drivers & the printer? I need to scan,copy & print regularly. Kindly help for Installation
Steps in downloading the driver
1. go to www.support.hp.com 2. enter your product name which is f-4288 then click next 3. click 'software and driver downloads' 4. choose your operating system then click next = to know your operating system just click start then right click on my computer or computer then click properties 5. click driver (1) 6. click 'HP deskjet full feature software and driver 7. click download then run
May 16, 2011 | HP DeskJet F4280 All In One Printer InkJet
My HP Deskjet D1341 printer won't print. Says it is offline. I go in and right-click to put it on-line, but it still won't print,,,goes back off-line. I posed this problem last Thursday and paid $$ to...
Goto the below mentioned link and select your operating system now click on the next button.
Expand the Utility - Diagnostic Utility and download the print diagnostic utility and this will show you what the problem is with the printer or with the computer
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=1839855#N672
Oct 05, 2010 | HP Deskjet Printer
The scanner won't scan to the computer, but when I test it in scanners & cameras it says it is working.
This is my solution :
1st step : Turn on your *HP Deskjet F4185*.
2nd step : Click the Start menu.
3rd step : Click Devices and printers. A new window will appear.
4th step : Then, click the "Fax button ".The window Fax and Scan window will appear.
5th step : On the lower left corner , click "Scan" below the "Fax" button.Scanned documents (if there's any) will appear.
6th step : Click "New scan" button below the "File" button. And your printer will start! Glad to help..
Mar 29, 2010 | HP DeskJet F380 All-In-One Printer
101 people viewed this question
jasbo
jasbo
