Question about Price Pfister 548E0BK Catalina Double-Handle Centerset Lavatory Faucet with
Need pages 5&6 of manual for Delton 35 series kitchen faucet
Faucet has low pressure both hot and cold and sprayer.
arealplumber
  • 33 Answers
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Posted on Dec 05, 2008
  • 659 Answers
SOURCE: ''poor pressure hot water only on new 531 series''
If you remove the supply line from the faucet and open the valve into a bucket, do you have adequate pressure? If you do, you will need to remove the hot water stem to see if something washed up into the faucet when you first turned the water on.
Posted on Apr 11, 2009
  • 92 Answers
SOURCE: no water out of kitchen faucet or sprayer
sounds like the little device on end of spout is clogged remove and clean or replace
Posted on May 06, 2009
  • 349 Answers
SOURCE: kitchen sprayer/diverter
http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/marielle/mar026-4n/26548-0500.pdf
Page 2 on this web site has the diverter listed. Sounds like the diverter is sticking or hanging up and not working right. The link below has information on the faucet you have so I hope this will be helpful for you.
First you could take it off and clean it and check it out for any blockage.
http://www.pricepfister.com/product_catalog/document_search_results.aspx?doctype=15&room=kitchen&collection=Marielle
Posted on Jun 06, 2010
  • 24 Answers
SOURCE: My kitchen faucet has low
If you have pressure to the shut off valves then most likely your shut off valves are not fully opening, I would recommend you replace both valves, they build up water deposits in them a lot of the times. The other possibility is the faucet itself has a water saver filter built into it. A lot of the new faucets have water savers built into them now.
Posted on Mar 16, 2011
NEW faucet! Low stream from both hot AND cold. Sprayer works well with both hot and cold. Doesn't make sense.
unscrew the end of the faucet and clean the filter and screen is probably stopped up
Nov 29, 2015 | Plumbing
New kitchen faucet worked for 4 weeks, now the water flow is very low
Check the inside of the faucet for debris blocking the cartridge or the inlets.
Sep 29, 2014 | Kohler Kitchen Faucets. Elate Pull-Out...
Low water pressure from hansgrohe faucet
Low flow is a debris driven issue. If the flow is lower on the hot or cold side then you will most likely find the debris in the hot or cold supply line leading up to the faucet. If the flow is the same between hot and cold you will find the debris in the faucet between the cartridge and the spout or sprayer. The actions you will need to take to get to the debris will vary depending on model and type of faucet. I would need to identify the faucet before I can give instructions on clearing the debris and restoring the flow of the unit. If you need help in identifying the faucet feel free to contact me at Hansgrohe Technical Services 1-800-334-0455 press 2 for Tech and ask for David.
Mar 06, 2013 | Plumbing
My Kohler Fairfax faucet pressure /flow has dropped (cold)
Verify the cold water outlet has equal pressure as the hot side outlet at the wall. Check the inlet screen on the cold side water line where it attatches to cold water pipe. The screen could be plugged. Then check the cold side hose for any restrictions. Also check if there is a screen on the outlet side of the cold water hose and see if it is plugged. Otherwise the faucet valve is mis-aligned and will need to be rotated and re-tightened to align the valve to the center so both sides have equal water flow.
Nov 08, 2009 | Kohler K-12176-PB Fairfax Single Handle...
The hot water side has low water pressure. The
start by making sure the valve that supplies hot water to the sink and dish washer is fully open. If there is low hot water pressure in any of the other kitchen/bathrooms, then trace the line to see where the pressure drops. If it is only in the kitchen, it should be an old valve, (causes restriction)Good Luck.
Oct 10, 2009 | Whitehaus Kitchen Single Handle Faucet...
Water runs slow
Three possible reasons for low pressure. 1. faucet cartridge has debris in valve body. 2. aerator has debris ,just unscrew and clean out. 3. Water valves under sink are not opened up. hope this helps
Jul 30, 2009 | Price Pfister Marielle Kitchen Faucet with...
Water volumn is very low, hot or cold. Barely a
take the aerator off the outlet or spout, it's clogged.
Jun 26, 2009 | Price Pfister Marielle Kitchen Faucet with...
I have a tankles hot water heater. The problem is
this is a problem they didn;t tell any one about, there is a min of 1 gpm that you have to run for it to sence for the unit to come on, if not the unit will not detect the water is even runnig there for will not come on,, as for the kit faucet, it might have a temp control and it may need to have a cartridge change, the water comming from the tankless is nothing like the old tank heater, the water only losses aprox 1 or 2 degree where a tank heater losses almost 5 or more because of the way the cold water is fed into the unit,, thats whay the sprayer works and the faucet doesn't ,, you have control on the sprayer unlike turning the faucet on,,
Jun 17, 2009 | RTO Chronomite S-90I 277v Instant-Flow SR...
No water flow in kitchen sink
Sorry to say, you will need to replace that faucet, and also when you are shopping for a replacement, inquire about a rosette to cover the hole left by the voided sprayer.
Good luck...
Feb 24, 2009 | Home
Price Pfister 548E0BK Catalina Double-Handle Centerset Lavatory Faucet with Logo
37 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
