Iam try to find where I can down load updates for network adaptors for an advent kc550p on vista as I cant get the internet to update the drivers
  • 7,627 Answers
Advent is a bit weak on support, which I'm sure you know. Wired or Wireless Network Adapter? Try If you, uninstall the network device and reboot, Vista will try to apply a generic driver, will it not?
Posted on Apr 20, 2013
aroostookb
  • 98 Answers
SOURCE: cant open network center, cant connect to wireless
Do a restore to a previously good state.........
Posted on Jun 23, 2009
  • 101 Answers
SOURCE: no audio output device is installed
LOG ONTO HP WEBSITET, TYPE MODEL ADVENT
LOOK FOR THE AUDIO DRIVER AND DOWNLOAD.
Posted on Jul 04, 2009
  • 107 Answers
SOURCE: hp laptop internet connection problem
I would suggest going to system restore and resetting your system to a time before this started happening and see if that fixes it
Posted on Jul 25, 2009
SOURCE: Problem with Network driver (Dell Inspiron 1525)
I might be a bit late on this but I had the exact same problem just a couple of days ago. What I did was download the drivers needed fromhere (download the two drivers in the Network section). I downloaded these from a different computer then you have to copy and save them to a flash drive and transfer them to your computer and install from there. Your wireless should work after doing this.
Posted on Nov 04, 2009
  • 37 Answers
SOURCE: Need to update Network controller driver on Inspiron 1545
If you can't find it on the network card manufacturer's website, then try www.driverguide.com.
Posted on Nov 12, 2009
I have a advent 6651 on windows vista, i try and use skype and it keeps on saying 'cant start webcam', any idea's ?
Go to the manufactures website and download the webcam drivers & reinstall. Alteratively upgrade to Win7 ( vista drivers are compatible with Win7 ) and do updates
Jul 09, 2011 | Computers & Internet
My toshiba satelite won't connect to the internet and i get an error message saying its my network adaptors. does this mean its a software problem or will i have to physically remove and replace the...
Hello.
Test your laptop at a different location to see if any difference.
If still the network adapter, first try to update the driver by going to Device Manager, find the network adapter and select update. You'll actually be reinstalling the current driver software.
If still a problem, the network adapter would need to be physically removed and replaced.
Hope this helps.
May 20, 2011 | Toshiba Computers & Internet
My laptop is del inspiron 6400,i have installed a new os ,windows xp. i have downloaded drivers but i have a problem in installing network drivers . iam given the information of uncompatability of hardware...
Connect your laptop to the internet using Wifi (obviously network connection not available due to your problem) and update the drivers for the network adaptor. Can you use a free Wifi point somewhere to connect via Wifi to help with the driver issue?
There will be a yellow exclamation mark next the network adaptor problem in the WINXP System Properties. To get here right click on My Computer, then select Properties, then Hardware, then Device Manager. Find the offending network card problem, double click the device, Select Driver, then Update Driver. Let WINXP find the driver from the internet.
Alternatively, check the driver you downloaded from the Dell support webpage. Are you sure it was the correct driver for WINXP for the same model of network card fitted to your Dell 6400? A message about incompatible hardware means you are trying to use drivers on hardware which is not compatible with that driver. That is a good sign that you dont have the right drivers.
Go to Dell here: http://support.dell.com/support/ and select Drivers and Downloads.
Try this link here:
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=5&dateid=-1&impid=-1&osl=EN&typeid=DRVR&formatid=-1&servicetag=&SystemID=INSPIRONI6400%2FE1505&hidos=WW1&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
Ask me for more help.
Cheers,
Steve
May 03, 2010 | Dell Inspiron 6400 Notebook
I found I needed a USB/Ethernet adaptor in order to connect my new broadband and purchased an ASIX AX88772A vai your product A31GY from Maplins. I'm having trouble in that the Broadband set up refuses to...
I allowed Windows Update to search for the right driver. This took a long time - I'd tried earlier but evidently hadn't let it run for long enough. It located and loaded a driver and everything was then fine: the ethernet connection (via adaptor) 'went live', my new broadband set-up software recognised it and proceeded sussessfully from there.
I assume that the device manager on my PC was correctly identifying corrupt drivers on the small CD supplied with the adaptor and that I'd managed to find uncorrupted ones on the internet via Windows Update.
Robin Lovelock
Dec 09, 2009 | Computers & Internet
I am unable to set up an internet connection with my wireless neatgear router on my new dell desktop. The router, model DG834PN works fine on my old computer, but when i try to load the network adapter it...
use your other computer to goto netgear.com look for downloads and find your adaptor. you may have an older adaptor that is not suitable for vista or windows 7. it may need an updated driver. so download the appropriate driver for the operating system to the working computer, and burn it to a cd. then you should be able to run the disk on the new computer. we at charter had this issue when vista came out, our install disks didnt have the right drivers. you just need the right drivers for the adaptor vs operatin system.
Nov 17, 2009 | AbleSoft Teacher's Toolbox 4.0...
I can not get my Samsung printer drivers loaded for VISTA sp2
this time you are going to find MANUALLY your vista driver of your printer, go to device manager and update driver using an inserted CD of your printer... and even your going to update your VISTA its not reason...
Jun 19, 2009 | Samsung CLP-315W Laser Color Printer
Iam connected to the wireless network but cant access internet
right click my computer
then properties
hardware and then devices
scroll down till you find your network
click it and then update
after updating restart
let me know if that helped
Jan 18, 2009 | Acer Aspire 5315 Notebook
Network Adaptor Not Working After Windows Vista Re-installation
Go to Dell's website and go to Drivers and find your computer and download the network adapters driver and install it.
Dec 30, 2008 | Dell Inspiron 1525 Laptop Jet Black
Iam using compaq c700 notebook with windows xp. my internet is an LAN network which shows internet is connected now.It is becoz my ethernet driver is not yet updated. When i go to device manager i tryed to...
hi,
i hope this can you through this link below.
http://www.drivershq.com/Drivers/HP/Compaq-Presario-C700-Notebook/566/35317/Models.aspx
God Bless
Nov 26, 2008 | Computers & Internet
I have a FSD7051 network adaptor which worked fine until my computer was upgraded to vista now it is not recognised and despite trying to download driver updates from another computer i cant get on line or...
Since you updated the computer to Vista, the adapter will no longer work because it uses XP drivers. You need to uninstall the adapter completely and then reinstall it using the correct Vista drivers. The drivers are available on the Belkin Support site.
Jul 31, 2008 | Belkin Computers & Internet
Computers & Internet Logo
David Payne
David Payne
