Need command prompt for Acer Aspire
Reading error0x80070003
  • Computers & ... Master
  • 27,725 Answers
The Windows Backup and Restore feature allows you to save files and system images to external backup devices such as hard drives and flash drives. However, backing up files become problematic if the directory your backing up files from isn't configured properly, or if you're having issues with the devices you're backing files to. There are ways to solve or work around backup problems quickly and safely.
Hard Drive b> A backup will not complete if the files you're backing up exceed the amount of space left on the external hard drive. If you're backing up large system files, Microsoft recommends saving the backup to an external hard drive that can hold at least 200 GB. If you're running out of space, you must delete content to create space for others or use another hard drive. Error Codes In some cases, Windows displays the following error codes when it's unable to complete a backup: "0x80070001 (Invalid Function)" or "0x81000037: Windows Backup failed while trying to read from the shadow copy on one of the volumes being backed up." These error messages usually appear if Windows is unable to backup a specific library or if you opt out of adjusting your backup settings and settle for the default settings in the Windows Backup and Restore Feature. Reparse Point b> If you're unable to backup a specific library and run into error code messages, removing the reparse point allows you to complete the backup. A reparse point is a file that contains information about the user on a computer. If it doesn't point to a location that contains some of the data you want to backup, error messages appear when you try to back up your files. Type "CMD" in the Start Search box to open the Command Prompt. In the Command Prompt, typing "DIR /AL /S" and pressing Enter lists the reparse points. Each entry says "JUNCTION," which also means reparse point. The entries also tell you the location of the reparse points in Windows Explorer. If you locate a specific reparse point in Windows Explorer, delete its mounted volume from the device's Properties. Once deleted, you should be able to back up your files. Discs b> If you're backing up files to a disc, you'll run into problems if the discs are non-rewritable and already contain data, or if they are severely scratched or damaged. Non-rewritable discs can only be used once, while rewritable discs can be used to read and write data several times. If the CD or DVD you're using is severely scratched, the optical disc drive spins harder than usual in an attempt to read it. If it's incapable of reading the disc, the backup feature may freeze or display an error.
Windows backup or restore errors 0x80070001, 0x81000037, or 0x80070003
http://support.microsoft.com/kb/973455 - workaroundissue12
Posted on Apr 21, 2013
How do i recover acer aspire one windows 7 starter with command prompts. Missing or corrupt NLS file
You can try the procedure at this link. Be advised that if it works, you will get the PC back, but you will have lost all personal data.
How to Reset the Acer Aspire One to Factory Settings
Nov 29, 2015 | Acer Computers & Internet
Acer Aspire One, connects to my wireless network ok, but none of my browsers connect to any website.
Open the command prompt (you can do this by holding down the start button and pressing the letter r, then type cmd and click ok)
In the command prompt, type this:
ping google.com
It will tell you if it gets replies. If it does not, there is a problem with the network connection. If it does not, you may have a virus. Try running a virus scan (for example: Microsoft Security Essentials).
Mar 23, 2013 | Acer Aspire One Netbook
Forget password acer aspire 3610
Acer laptops are equipped with a BIOS utility. The BIOS (which stands for "Basic Input Output System") acts as an interface between the hardware and software installed on the computer. On some computers, a BIOS password may be required in order to boot the computer and make changes to the BIOS settings. If you are unable to access the BIOS settings and do not know how to reset the BIOS password, you might be tempted to send the computer back to the manufacturer for repair. Fortunately, that's not necessary as there is a simple way to do this on your own.
Go to "Start," then perform a search for "Command Prompt." The Windows Start button is located in the lower-left corner of your computer screen. Double-click on "Command Prompt" to open the application. You will need to use MS-DOS commands to reset the BIOS password. Type the following commands one by one in the order shown: debug o 70 2E o 71 FF quit Make sure that you are typing the letter "o" and not a zero at the beginning of the second and third commands. Reboot your computer by clicking "Start," "Shutdown," and then "Restart." The BIOS password will now be reset to default. or To get into your computer's Basic Input-Output System (BIOS), your computer must be on, but your operating system cannot be running. If the Microsoft Windows operating system has even started to load, you will not be able to access your BIOS. This is why getting into the BIOS on an Acer Aspire netbook computer must be done specifically during your computer's initial boot-up sequence, which happens immediately after pressing the power button on the device.
Turn on your Acer Aspire. Press and hold the "Ctrl" key. Press and hold the "Alt" key. Press and hold the "Esc" key. This key combination will open the BIOS on your Acer Aspire.
Feb 03, 2013 | Acer Aspire 3610 Notebook
How do i wipe and clean my acer with command prompt
you open command prompt and type: format C then press enter. This should work. if not, my email is chucklestheeviltroll@gmail.com
Jan 24, 2011 | Acer Aspire 5315-2153 Notebook
Bootmgr missing press any key to restart on an acer aspire one
Sounds like your boot up file is corrupted. You will need your operating system CD and be able to boot from it. After it boots up you will need to select the repair option. At the command prompt try the following commands
fixmbr and hit enter
fixboot and hit enter
type exit. Your computer will reboot
If you need me to take you through step by step please leave a message and I will do what I can to help you.
Good Luck!
Dec 10, 2010 | Acer Aspire One PC Notebook
How do you find the Mac Address on the Aspire One????
In windows XP click on the start menu and click run, type cmd in the box and it should open up a black window which is called command prompt, in command prompt type `ipconfig /all` without the commas which should then list all the network conections and addresses on your comp.
Hope this helps
John
Dec 02, 2010 | Acer Aspire One PC Notebook
How do I find the exact model number of a Acer Aspire One computer?
To retrieve model name of the computer run the following command in Command prompt
wmic csproduct get name
Mar 27, 2010 | Acer Aspire One PC Notebook
The Numeric keypad on my Acer Aspire 7720 doesn't work. When I press Num Lock key the indicator light doesn't come on. The main keyboard works fine. I am using Vista.
try to access command prompt outside of windows using the operating system disc. (by booting to cd and go to repair your computer options then select command prompt) if the keyboard works fine on command prompt, there's no issue with the hardware. but if it still doesnt work, you will need to replace the keyboard.
Dec 03, 2009 | Acer Aspire 7720 Notebook
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
