Sony tv model kp53h30 won't power up
Hit the power button and it blinks six times
Shuttle83
  • 1139 Answers
SOURCE: Sony Big Screen TV Not Powering On
This looks like a problem with the High Voltage or switching power supply section of the TV set. What you need to do is to measure the voltage from the HV transformer to the Anodes of the CRTs with a high voltage probe, and check the voltage output of the switching power supply. What may have happened is a component may have shorted out causing an over-current condition with is triggering the shutdown circuit (These are the relays you are hearing). I would check the Horizontal Output transistor, and the components in that section of the TV.
In addition check the voltage test points on the HV / Horizontal and switching power supply board. This will determine if the section is working or not (most likely not). Make sure you have a schematic, and multimeter and a high voltage probe.
I hope this helps,
Thank you,
Shuttle83
Posted on Oct 26, 2007
SOURCE: Blinking red standby light flashes
blinkig red stand by stay on when powr button hit
Posted on Feb 01, 2009
welcomejee
  • 10594 Answers
SOURCE: Tv shuts off and green light blinks 5 times and repeats 5 blinks.
Please buy new Lamp for KDF-55WF655 from Sony Accessories Store with following part number..
" A1085447A " LAMP BLOCK ASSY XL-2200U
(type model number in search box and click)
Always buy Sony original lamp for safety of your TV.
Posted on Feb 06, 2009
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
tvtek
  • 1284 Answers
SOURCE: Sony Tv 42
The 9 flash error usually means an issue with one of the power supply boards in the TV. You can verify this by bypassing the shutdown. To do this with the set off and in the standby mode point the Sony remote at the TV and press these buttons in sequence within 5 seconds of each other, DISPLAY 5 VOLUME DOWN and then POWER. The set should turn on with no issues. Once it comes on there will be a diagnosis screen and the bottom entry on the screen should be ZCD. That entry should have a zero in the fail column. If it has anything besides zero then the power supply board is at fault. There are two power boards in this TV so I don't remember which one causes the issue whether its the G1 or G2 board. At this point if this is the issue then I would have a technician do the repair since replacing either board isn't that easy. Please take a few moments to rate my answer. Thank you....
Posted on Nov 19, 2009
Testimonial: "it really worked! Now how do I turn the diagosis window off?"
My tv kv-xr29m50 won'to on.stand-byl light blinks 8 time
Count the number of blinks occur at one time switch ON. These blinks are fault indications. After counting it, check this link for more details. There are details about Sony blinking codes. Search the site by brand name and model number to your TV in its search box.
Jan 29, 2013 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Phillips 27PT5445/37 TV won't turn on
Sounds like a power supply issue possibly bad caps. You can get replacement power supplies from www.tvrepairworld.com just hit the contact us button on their website to leave a email with your model number if you dont see your model listed.
Aug 05, 2012 | Televison & Video
I have a 2003 sony kp51ws500 television and there's a timer on the tv and it won't turn on. A red light blinks 6 times then nothing happens. I unplugged, I hit the reset button, nothing happen
read the instruction manual and see how to operate.
if the timer is for to sleep, the problem will be the IC associates with him, you must see the block diagram and w.diagram. and tracking the signal.
go to www. retrevo.com and download the diagram. God bless you
Jul 31, 2012 | Sony Televison & Video
Sony kdl46ex500 red power light blinks six times
Most probably there is a problem in the power supply and it is going on standby protection mode. You may have to search for a service manual from open websites and look through for the error code indicated by the led blinking, to be very sure. Unfortunately I do not have one with me.
Jul 07, 2012 | Sony KDL46EX500 46 in. HD-Ready TV
Sony Trinitron KV-27FV310 won't stay on, standby button flashes around 10 times, help please?
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board
Jun 18, 2012 | Sony FD Trinitron WEGA KV-27FV310 27" TV
My sony lcd tv model kdl40ex400 red light blinks six times and does not come on .what is the solution.
My TV did the same thing. According to Sony the Bulb or lighting mechanism is bad when 6 red lights blink and your TV fails to turn itself on properly.
If you have a warranty they'll likely replace the television set as they said "it isn't cost efficient to fix this issue."
Nov 03, 2011 | Sony KDL40EX400 40 in. HD-Ready TV
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
My kp-57/65wv600 flashes SIX TIMES, PAUSED ABOUT 3 SECONDS AND BLINKS SIX TIMES OVER AND OVER! WE PUSH THE POWER BUTTON AND WE CAN HEAR WHEN TURN ON AND OFF, BUT NO IMAGE/PICTURE APPEAR. THANKS!
First off I would check your lamp to make sure it isn't burnt out. Usually the lamp door is on the backside of the TV. On my 2006 SXRD its on the right side of the TV just behind the buttons. Here is a link to a diagnosis page
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Jun 30, 2011 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
