I purchased a leap pad 2 and the speaker does not work. You can hear sounds when you connect headphones, but that is the only time you can hear noises. I have tried the "headphone trick", but that still isn't working. Does anyone have a solution?
  • 7,627 Answers
Return it.
Posted on Apr 20, 2013
cpenzes
  • 1102 Answers
SOURCE: headphone jack loose?broken?
You need a new one not worth fixing
how old is it when did it stop working
if you just bought it then
you need to return it and have it exchanged
there obviuosly is a defect.
Posted on Feb 12, 2009
  • 47 Answers
SOURCE: built in speakers don't work.i have sound only when i plugg the headphones
Looks like there is some problem with the stereo headphone connector. As its a hardware issue, I would recommend sending it to the service center.
You may also use external speakers temporarily.
Posted on Apr 15, 2008
  • 3940 Answers
SOURCE: sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Posted on Mar 02, 2009
SOURCE: sound does not come out of speakers but does with headphones
I have an acer aspire 4720Z laptop and the sound does not work from the speakers. It works with headphones. The sound card says it is working, and the speakers are not on mute..
Posted on Jul 27, 2009
yammy_alf
  • 666 Answers
SOURCE: aspire 3680 headphone jack recognizes any
check first you headphone jack speaker. if its working well, then the line from phone jack male to speaker continuity.
Posted on Apr 03, 2010
Hello, Could you please assist me on steps of switching speakers on my HP probook 4520s I friend on skype could see me, but still couldn`t hear. Waiting for your fast reply to my issue Thanks in...
sounds like you have built in speakers for your laptop?
you can try plugging in headphones in to the headphone jack on your laptop to see if you can hear any sound.
if you do then you can purchase a 2 speaker set from walmart or any electronics store and hook that up to your laptop for sound.
Mar 10, 2011 | Computers & Internet
Green light is on but no sound coming out of speakers but green bar is moving in control panel/speakers/playback Can't figure out what to try next
Try using headphones in the socket that the speakers are connected to. If you hear sound on the headphones then the socket is working. If no sound then check you are using the correct socket - usually coloured lght green.
Feb 24, 2011 | Logitech LS11 Speaker 2 Speakers
If I hook up a set of headphones to the slot on the side of the TV the sound goes off and you can only hear sound through the headphones, no one else in the room can hear the TV. Is there a way to hook...
The headphone jack on the TV has switch built-in to kill the TV speakers when headphne jack is used, you need to use powered PC speakers with headphone jack and connect this PC speakers to the Audio line out of the TV set (RED and WHITE RCA audio line out). Basically the powered PC speakers are being used a headphone driver. Or you can get one of those wirless headphone system instead.
Jun 27, 2010 | Televison & Video
Internal speakers do not emit sound but I can hear w/ headphones
I have a 700m, so I'm real familiar with the system. I see one of 2 possibilities. The headphone jack has a switch that disables the on-board speakers, if that is stuck or broken, then the jack/switch must be replaced. (Big hassle)
The other is easier to troubleshoot, then connection from the speakers to the MB goes through the Right hinge cover. Take the hinge cover off, check for broken wires (I has one, ***** to splice too)
Jun 05, 2009 | Dell Inspiron 700m Notebook
Leapster 2 has no sound
We got our daughter a Leapster2 for Chrstmas 08. One day the sound just stopped working. Called Leapfrog. They said to insert a cartridge, and turn the unit on. Plug headphones into the headphone jack. Then rotate the headphone plug-in 360 degrees,( It is easier to hold the heaphone plug-in and rotate the leapster2). Unplug the headphones and check to see if the sound works. Leapfrog said try it more than once, and if it does not work contact them,1-800-701-5327. We tried it and Hallelujah it worked!
Feb 15, 2009 | Nintendo Game Boy Advance Console
Headphone and mic
my presario c700 has a built in mic try just connecting headphones in and using the built i mic
Jul 23, 2008 | Compaq Presario 700 470024-192 Notebook
Can't hear sound on one of the headphone's speaker
It's less common for one of the speakers to go bad in a set of headphones. It's possible - but there are more common problems that will cause this. I assume you have tried the headphones on another device to rule our a problem with the device you are currently listening with and using the other device, you still only hear audio from the left speaker.
The wires in the cord that connect the plug to the headphones are very thin and are susceptible to breaking. The most commmon place for these wires to break is at the point where the cord is flexed or stressed the most. Those points are:
1. Right at the plug
2. Where the wire enters into the left and right speaker.
There are occasions where I have seen the wires become unsoldered from the speaker terminals within the headphones themself.
What You Can Do:
1. While listening with the headphones, try flexing the cord back & forth at the plug and where the wire goes into the right speaker. See if the audio will come back and cut out again.
2. What I have done is cut the cord about 3" back from the plug. Go to Radio Shack and purchase a new plug and install a new plug on the cord.
3. You can also take the headphones apart and cut a few inches off the cord where it connects to the right speaker and reconnect the new end of the wire to the right speaker. The goal is to cut away the bad part of the cord and re-attach the good part back.
4. You can try to replace the entire cord but I haven't been able to find replacement (THIN) cords too easily.
Good Luck,
- Jim
Jan 24, 2008 | Radio Communications
Computer stopped recognizing the speakers
Check the sound card system Can your hear through headphones for example?
Nov 15, 2006 | Logitech X-230 Computer Speakers
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
