Question about Everest Refrigeration ESF3 Reach-In Freezer
Freezer want stay on,cut off-showing error 3 - Everest Refrigeration ESF3 Reach-In Freezer
Www managemyhome com
I would suggest you have it serviced, sounds like the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. To repair an engineer will first cut the coolant pipe and drain the existing gas and then recharge, re-pressurise and seal.
Jan 04, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frost build up especially on top shelf all other shelves except one gets a 3 inch layer of ice in approx 4 months. The freezer is kept in a mod temp basement room and the freezer door is opened less than...
Things you can do to cut down on frost.
1.make sure all seals fit flush to frame.
2.use a thermometer and set freezer to -18c(beef will keep upto 12months).
3.wrap all food as airtight as poss.
3.do not overfill,leave space for air flow through drawers/shelves.
4.defrost every 2/3 months in humid conditions using clorine bleach to clean interior,and dry thoroughly.(leave door open to dissipate clorine gas.)
Aug 18, 2010 | Woods Upright Freezer V1613RW3
Red light on, tripping the fuse box
Need to know if it's tripping a breaker or an RCD.
sound like an earth fault and tripping the protection.
you need a qualified professional.
Mar 27, 2010 | Freezers
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Ice keeps melting in the freezer side of the fridge periodically and leeking water everywhere. Temperature seems to randomly drop to the point where it melts.
Sounds like it's the defrost thermostat gone bad. It's located on the evaporator coils behind the back cover inside the freezer. It may be mishapenned or you can test it. It should show continuity with an ohm meter when it's above 35 degrees. It cuts the defrost heater off to prevent overheating.
Jul 08, 2009 | Freezers
Running non stop!
Sadly these old freezers use way too much electricity. You will be better off junking this one and purchasing a good used or brand new one.
Apr 02, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
The red light is on, and stays on?
on the side of the compressor you will see 2-3 wires running into an electrical connection reseat this first. if still no operation replace teh relay. you can purchase thru any reputable appliance parts dealer. after replacing the relay if you have no operation then likely problem is seized comp.
Jan 28, 2009 | Freezers
Shelves that wont stay
I had the same problem. With the basket install empty I notice there was about ¼" gap from the bar the far most side of the side rail. SO I removed the left side rail and found a peice of laminate flooring and cut it to the same size of the the bracket (also predrill the holes so the screw holes match up). I had to buy 3 new screws that were ½" longer the orginal. I reassembled the wood and rail bracket . I then slid the basket in the rail, then started the load the backet up with frozen items. It works perfectly. The basket does not fall any more! Total cost... 3 screws ($0.15).
Nov 18, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Fridge Freezer very noisy!
cycling every 30 mins is normal. bear in mind that frost free are more noisy as there are fans running as well.
you appear to have temp in freezer too high - should be -18degC
Oct 11, 2008 | Freezers
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Everest Refrigeration ESF3 Reach-In Freezer Logo
Top Everest Refrigeration Freezers Experts
christian nielsen
Roger Paull III
Bill Boyd
Are you an Everest Refrigeration Freezer Expert? Answer questions, earn points and help others
