A fully charged Toshiba Satellite M305D-4831 has a nasty tendency of running the battery down when it is put to sleep and hibernation. It is worse when in sleep, as I lose nearly half of the charge in about two hours between charging and arriving at my office. When in Hibernation the loss of charge is much lower, but worse than my old Dell Inspiron 6400 on sleep.
  • Anonymous Mar 13, 2009
    My laptop is less than a month old. I fully charged and depleted the battery twice out of the box to condition the battery. The battery itself is on the small side, and is rated as a 4 cell unit.
    One thing I notice is that the laptop tends to be warm when I pull it out of the neoprene sleeve - leading me to suspect that it may be coming out of sleep mode in transit.
    The laptop powers up and the CPU cooling fan kicks in right from the get go, which is something I have not witnessed with Intel powered units. I wonder if there is something inherently less efficient about Turion powered laptops.
  • Bill Kindle May 11, 2010
    How old is this laptop and have you changed any power management settings?
    Problem Solver:
  • 14 Answers
If you go to control panel + power settings you can configure and adjust how your power gets distributed when in sleep mode etc. This may not totally fix your issue as it will alleviate the loss of power. I would first see what type of life the battery is supposed to have and if you are not satisfied your best bet is to replace the battery with a longer life. Goof luck and please let me know if you need any assistance with that.
Posted on Mar 13, 2009
Battery light flashes
Well, if you are using the laptop it is using the power it needs. Any surplus power supplied by the adapter will go towards charging the battery. If you want to charge the battery fast do not use the computer.
You can also use the laptop but not at full power. It is your choice, but you cannot have your cake and eat it too.
Nov 27, 2013 | Toshiba Satellite P755S5215 PC Notebook
Toshiba satellite pro does not fully shutdown
In Control Panel, select Power Options, you didn't post your OS?, set to High Performance, open Change Plan settings, set Computer Sleep Never, open Change Advanced power settings, scroll through the settings, set Sleep and Hibernate to Never, open Power Buttons and Lid, set to shut down. Now the red X on the Battery Icon usually means the battery needs replacing, it's not charging. Shut down the Laptop unplug, remove battery, plug in , reboot.
May 12, 2013 | Toshiba Satellite Computers & Internet
Toshiba Satellite won't start up when AC plugged in
Try another Cord/Charger to verify the Cord, AC jack. If you plug in the AC cord after starting on battery, does the battery charge? Open Control Panel, Power Options, set to High Performance, Advanced power settings, set Sleep and Hibernate to Never, Adjust Advanced power setting to your preference.
Feb 06, 2013 | Toshiba Satellite L300D-ST3501 Notebook
How to calibrate battery laptop toshiba satellite m45-s359
Calibrate laptop battery pack under the following conditions:
? When the battery status display seems inaccurate.
? When you observe a significant change in normal batteryrun time.
? When the battery pack has not been used for one monthor more.
How to Calibrate laptop battery
To Calibrate laptop battery pack, you must fully charge, fullydischarge, and then fully recharge the battery pack.
Discharging the Battery Pack Disabling Hibernation
To fully discharge the battery pack, disable Hibernation temporarily.
To disable Hibernation:
? Select the Power Meter icon on the taskbar or access Power Options > Hibernate, and clear the Enable Hibernate support check box.
    To fully discharge the battery pack:
  1. Select the Power Meter icon on the taskbar, or select Start > Control Panel > Performance and Maintenance > Power Options > Power Schemes.
  2. Write down the 3 settings in the Plugged In column and the
  3. settings in the Running on Batteries column, so you can reset them after calibration.
  4. Select the drop-down lists and set all 6 options in both columns to Never.
  5. Select the OK button.
  6. Disconnect the notebook from the external power source, but do not turn off the notebook.
  7. Run the notebook on battery power until the battery pack is fully discharged. The battery light begins to blink when the battery pack has discharged to a low-battery condition. When the battery pack is fully discharged, the power/Standby light turns off and the notebook shuts down.
Dec 13, 2010 | Toshiba Satellite M45-S359 Notebook
My toshiba doesn't start anymore
Try removing the battery from the notebook and starting it just from the power. If it operates, you need a new battery.
Mar 05, 2010 | Toshiba Satellite M305D Notebook
Why does my toshiba satellite m305d beep problem during boot up.
when i start my toshiba m305d-s4831 it doesn't start and there is no beep to. but it permanently goes on stand-by like it on sleep. can you help me
Feb 25, 2010 | Toshiba Satellite A135-S2276 Notebook
Plug in my toshiba satellite m305d s4829 hit power, battery light blinks, no start up. Was working just fine 20 minutes ago
try to remove battery and plug only ac adapter see if helps , can also remove battery and unplug ac adapter for few min. put it back together make sure that battery is inserted all the way and locked
Dec 30, 2009 | Toshiba Satellite M305D Notebook
My toshiba satellite m305ds4831 laptop will not
It's a motherboard hardware issue in all likelihood.
There is NOTHING you can do but update the firmware bios. The problem is that most bios firmware update programs require both ac and battery power at the same time :(
You can try to do it anyways by visiting Toshiba's support page for your model and downloading the firmware from there.
It probably won't fix the problem but it's still worth a shot....sometimes it works ;)
Nov 21, 2009 | Toshiba Satellite M305D Notebook
Computer was in hibernate or sleep mode when the battery drained. Now, will not boot, appears to come out of sleep mode but only shows TOSHIBA splash screen and the hard drive lights do not activate. F8...
Dear! take display properties use tab ans select screen saver then click on power and use tab again select hibernate if it is enable check again it and disable now. After that your computer will not go in sleep or hibernate mode.
Thank You
Jul 26, 2009 | Toshiba Satellite M100 Notebook
Computers & Internet Logo
226 people viewed this question
David Payne
David Payne
