Question about Sole Fitness Sole F85 Treadmill
Sole F85 Error E2, Incline Failure
My F85 powers up with an E2 Error, indicating that the incline is failing. I ran the Calibration routine and it failed in that as well. Any ideas of how to resolve this?
5 Suggested Answers
  • 218 Answers
SOURCE: my treadmill does not incline
incline motor has failed and needs replaced
Posted on Aug 14, 2010
ercupa190
  • 12223 Answers
SOURCE: F63 sole treadmill, low speed error when inclined
If the calibration does not pass you may need to check the speed sensoralignment. You must understand the instruction for calibration is under the hood for motor.
1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
2) if the problem persist you must Test the main motor for open, ground 3) the main control board faulty. See the block diagram that I did as person like you that understand that 90% of functions the main motor controller board has effect.
good luck. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Posted on Dec 01, 2011
ercupa190
  • 12223 Answers
SOURCE: treadmill will incline but not stay up. incline # stays after bed lowers
incline Motor is not working it can be a few different things.
1) may not be any signal from the console which could be a damaged cable(tight the flexible cable from keypanel vs display board)
2) Tight the connector from display board vs lower board ( main motor controller board the console itself has failed.
3) The motor control board may have failed from a worn treadmill belt and deck measure 120VAC input for the board
5) the motor may have burnt out Test try to measure 120VAC.
6) potentiometer geared to the motor adjust it so the console knows what height the incline is at.
7) the gearing can slip, giving the console false information which can cause chassis damage.
Now see the block diagaram that I did , for person like you, for to know how the main motor board has aprox 90% of functions of any treadmills. sincerely. Good luck, G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Dec 07, 2011
ercupa190
  • 12223 Answers
SOURCE: error message and no incline on my sole f63
1) Run the software calibration for diagnose, and troubleshooting and fix it.
2) lube the gear and shift from elevation motor
3) adjust pot from elevation motor
4) tight the wires connector
5) Test the elevation motor for defective, measure the input voltage see my personal TIPS.
God bless you
Posted on Jul 09, 2012
I have a Sole f63 treadmill and I am getting an E7 error
This is an incline motor issue. Your manual should have the steps to get the treadmill into calibration mode. Follow the steps and the treadmill will calibrate itself. If it fails the calibration then it’s most likely that the incline motor needs to be replaced.
Nov 29, 2017 | Exercise & Fitness
Sole f60 incline error E2
does the incline work at all. if not try to calibrate the incline. if this fails something could be wrong with the incline motor
Oct 20, 2014 | Sole Fitness Sole F63 Treadmill
How to recalibrate 8600 incline trainer
To initiate the calibration routine, hold down the SPEED +
button and the SPEED - button simultaneously for three seconds. During the calibration routine, the INCLINE
TRAINER will automatically rise to the highest incline level and then return to the lowest incline level.
P.S. This is listed in your user manual in the "Troubleshooting" section if you don't have a user manual then you can get a pdf copy of it here
http://www.ereplacementparts.com/images/nordictrack/CTK59020.pdf
Aug 31, 2014 | Nordic Track NordicTrack Treadmill, A2550
Sole F63 Treadmill Incline Error
http://electro-medical.blogspot.com/. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience
Jun 26, 2014 | Sole Fitness F63 Treadmill
Sole F85 Hand Rail Incline Adjustment Switch is not working
The hand rail switch contacts can be worn out. The more likely problem is a broken wire by the arm. Remove the cosmetic covers by the hand rails and check for broken wire. If wires are not broken replace the switch.
Aug 12, 2013 | Sole Fitness Sole F85 Treadmill
E3 error on sole E95 elliptical
The E95 incline motor is out of calibration. Recalibrate the incline by holding the UP INCLINE button and the START button simultaneously for 5 seconds. This will put the machine into incline calibration mode. Press ENTER to start the calibration and let it run. It will take a minute or two.
Refer to page 25 (the last page) of the user manual, hidden right at the bottom.
Sep 20, 2012 | Exercise & Fitness
Error 7
Incline calibration is necessary when: the display shows ERR7, the drive board incline error LED ( LED5) lights or the incline has extended beyond its normal rangeThe goal of calibration is to synchronize the incline set mechanically and electronically. Mechanical calibration sets the incline motor pipe to the 0% position. This happens when the red line on the thin pipe is even with the end of the thick pipe. Electronic calibration sets the variable resistor (VR) value to the 0% position. This happens when the voltage across the VR blue and green wires is 1.20 VDC.
Readings of VR voltage (blue and green wires) should show around 1.20 VDC at the lowest position and around 3.80 VDC at the highest position. If the VR looses calibration or cannot be set to 1.20 VDC, replace the VR. If the incline motor gets voltage from the drive board but fails to operate, replace the incline motor set. If the incline fuse blows again and again, replace the incline motor set.
Jan 19, 2012 | Sportsart 6300 Treadmill
SOLE E95 "Ramp Error" Message
Thanks! It was the calibration!
But in order to get to calibration mode I had to press "Resistance Up" and "Start", not "Incline Up" and "Start"
Aug 07, 2011 | Exercise & Fitness
Sole Fitness Sole F85 Treadmill Logo
689 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
