Question about Garden
The motor is not on full throttle
Where do you adjust the speed of the blades turning on this hand propelled mower?
  • Garden Master
  • 2,478 Answers
Looks like your throttle cable needs adjust. Your owner's manual should show you.
Posted on Apr 20, 2013
  • 22 Answers
SOURCE: Electric mower will not work
the shear pin has broke on the drive shaft put a new one in.
Posted on May 02, 2009
  • 33 Answers
SOURCE: motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
wilsodfarm
  • 986 Answers
SOURCE: Smoking Craftsman Riding Mower
I think the old girl has a broke ring,
Posted on Sep 15, 2009
bargainbin2
  • 123 Answers
SOURCE: I have a DYT400 with a Briggs and Straton Intek plus 19.5 ovh. When I move the speed lever to full speed, the mower wants to choke out. Also, when I put the lever on stop, it just keeps running. the
You have governor with a missing spring or it could be in the wrong place. If the springs are all OK then you may have a bad governor gear in the crankcase. This engine is bad about the governor gears bending the governor gear shaft.
Posted on Oct 03, 2009
  • 36 Answers
SOURCE: i have a grazer zero turn lawnmower with a 20 hp
carburator needs a good cleaning out get all the sludge out with a good quality carb cleaner take the carb apart to do a good job!
Posted on Jun 07, 2010
How can I slow down the speed at wich u can walk with the machine it is a propelled mower. Thanks
If the mower motor speed cannot be controlled, then you cannot control the walking speed.
And most transmissions are directly connected to the motor pulley so that if you slow down down the mower's motor, you also slow down the blade speed and cutting power.
Apr 05, 2015 | Garden
2008 yardman lawn mower 13.5 hp. has a high idle speed and does not slow down, need diagram for throttle control
Throttle cable should pull a SPRING, which pulls the governor, which pushes/pulls the carburetor butterfly valve.
Aug 12, 2014 | Yard Machines Garden
How do i adjust carb?
With the screw all the way in unscrew it 1 and a half turns start it and adjust in or out at full speed to get the best running. Their might be a screw on the throttle for idle speed,
Aug 17, 2012 | Mtd 22" White Outdoor Self Propelled High...
Husqvarna too slow when mowing
Some self-propelled mowers include a speed control, but sometimes it may seem that no matter how you adjust it, the mower just creeps along at a snail's pace. Most likely this isn't a mechanical malfunction, but an adjustment is probably needed.
Very tall or thick grass can bog down a self-propelled mower, but adjusting the height of the blade may allow it to roll through and cut the grass at normal speeds. If the blade is low, the amount of cutting required may slow down the movement of the entire mower. The frame of the mower may also stick in the high grass. Raise the blade little by little until the mower rolls at the appropriate speed. Going up hills may cause a similar response.
It's possible the drive belt on the mower can slip. Inspect this part to see if it is loose or cracked, and replace the belt to restore power.
May 08, 2012 | Garden
I have a self propelled Toro walk behind that does not have a throttle control. Stalls out if grass is just a bit high. How/ where do I adjust throttle
Most new mowers do not have a throttle adjustment, the motor has a govnor that helps the motor speed up when the load requires it. The first thing you should check is that the blade is sharp which makes it easier to cut the grass. If the grass is still too high for the motor to keep up, it's usually easier to raise the deck (lower the wheels) so you are not cutting as much grass on each pass. Then lower the deck to where you want the grass height to be and make a second pass.
Jun 06, 2011 | Toro Power Lawn Mower
When engaging mower blades speed drops or stops
Check throttle cable at carb and make sure you have full travel. Sounds like rpm is little to low. Throttle cables are usually held in place with 1 screw and a washer. Put cable at full throttle loosen screwand pull back until throttle at carb in at full then tighten screw.
Mar 07, 2010 | Garden
Need instructions how to install belt on self propelled craftsman push mower
raise the front of your mower up and support it with something safe like a jack stand
take the blade off
when your blade is off locate the plastic cover covering the belt and remove
now remove the belt but first remove the plastic cover on top of the mower to uncover the gearbox that turns the wheels your belt goes from the engine pulley to the gearbox pulley
you will have to work the belt off the pulley while turning the motor by hand or the same when installing the belt.
to install belt reverse the procedure.
hope this helps some
Jun 06, 2009 | Mtd 22" White Outdoor Self Propelled High...
Problem mowing my lawn.
I had the same problem and I already found those recommended solutions\ causes on the web:
1. The motor isn't on full throttle.
2. The blade is upside down.
3. The grass is too high when cutting it.
4. Overlap your cuts.
It helped my problem/ I hope it will help yours too!
Sep 01, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
