Picture was showing scrambled pixels for a few days, then picture went black
SOURCE: - Picture scrambled when set is
The TV has a bad board. It's called the Hyper board. It has been discontinued by Toshiba years ago so it is not an option to replace it. There are some TV repair shops that can rebuild this board by replacing most or all of the capacitors in it. You may want to call your local shop and see if they can do.
SOURCE: power led blinks but no picture or sound
Had the same problem myself. Took some doing but I managed to find a service bulletin that I downloaded. The problem is with the siene module and all you need to do is unplug connector JP63A from the main board and your TV will work again.
Take the back off the TV (there are a lot of screws) and look on the left hand side of the main circuit board that is mounted in the center of the TV. You will see a small white connector that is labelled JP63A, simply unplug it. Plug the TV back in and let it reboot. That's it, should be able to watch immediately.
SOURCE: I have a 32
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. [email protected]
SOURCE: My Toshiba 32AV500U - the picture went blank.
This problem usually happens when the lamp runs out, verify how old is your TV, lamps have a life spend of aprox. 3 years, most likely you would have to replace the bulb so your TV can start running again!!
SOURCE: 42 inch flat screen shows black screen with sound only no picture
That sounds like the backlight system or its powersupply has failed. If you can see an ghost like image when close and at an angle near the dge (depends on the light) then this confirms the backlight being the problem.
Repair cost should be about $100. You should be able to get this fixed under warrenty if you have any. If not get repair estimates before doing anything. It should be worth fixing but it never hurts to know if it is getting close to what a new replacment tv is worth.
