Question about Delta T17238-SS Stainless Steel Lahara Double Handle Pressure Balanced Show
Temperature lever how too change and remove lever to set temperature of water much warmer....
  • 2,984 Answers
Your water temp is controlled through your hot water heater.....
Posted on Mar 11, 2009
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
A downeast hot tub water is only 78 degrees turn up to 100 doesn't never get warmer and shows a ECn code
Check your filter cycles and switch spa into Standard Mode as you have it in Economy. (In Economy mode it will only heat during the filter cycles).
If the Ecn or Ec Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Economy Heating Mode.
If the Ecn or Ec Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Economy Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Ecn or Ec is Alternating with Temp:
The Spa is Operating in the "Economy" (Ecn or Ec) Heating Mode.
The Water Temperature is Sampled Only during Programmed Filter Cycles. The Heater will Only operate and Heat up to Set Temperature during the Filter Cycles. The Water Temperature will probably drop Below Set Temperature between Filter Cycles. Other Heating Modes are Standard, Standard in Economy, and Sleep Modes.
Ecn or Ec is ON Solid (Not Flashing):
The Current Water Temperature is "Unknown" (- - - or - -) while in Economy or Sleep Mode.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
Apr 06, 2013 | Washing Machines
How do I adjust the faucet to get the water hotter?
If you have a hot water heater there's where you turn you heat up for your water if its hot oil its on the furnace boiler
Mar 05, 2013 | Plumbing
On a jade model j-81 the lever on the top what does it adjust
Hi Michael.
The lever usually controls the set-point for that water temperature inside the water heater. Move the lever clockwise to increase the temperature and move it counter clockwise to reduce the temperature.
The lever is pointing out behind the frame at left bottom in the picture at the link:
http://www.adventurerv.net/atwood-water-heater-gas-control-valve-thermostat-91602-p-1189.html
Good luck and regards,
Fredrik
May 12, 2012 | Water Heaters
How do you lower the temperture in the refrigerator?
Letting perishables such as milk and eggs get warm doesn't just effect the taste; it can also allow bacteria to grow. It's essential to guard against this by adjusting your refrigerator temperature when necessary. Read below for how to do it.
1 Measure the temperature of you refrigerator. To measure the temperature in a fridge without a thermostat, just place a normal thermometer in a glass of water and place it inside the fridge. Check back 5 to 8 hours later to see what temperature the water is. This allows you to determine the temperature indirectly.
  • 2 Adjust the temperature. Once you've identified your refrigerator's temperature, it's time to change the settings. Turn the indicator to the left to make the temperature warmer, and to the right to make your refrigerator colder. It is important to only change the temperature gauge by one setting, regardless of how much you think it must be adjusted. This prevents freezing or thawing of food by making the change gradually.
  • 3 Check the temperature again after 6 to 8 hours. If it's the temperature you want, you're set. If not, move the dial one setting colder or warmer, depending on your needs. The ideal temperature for a refrigerator is 40 degrees. Wait at least 24 hours in between each adjustment to allow the fridge time to achieve that temperature.
  • 4 Prepare for changing seasons. Where you live can have a big influence on your fridge's temperatures. You may need to adjust the temperature lower in the summer and higher in the winter to maintain a constant 40 degrees. Those who live in moderate climates can worry less about weather effecting their refrigerator's temperature.
  • 5 Check the air vents. If you're having trouble achieving the right temperature, even after numerous adjustments, make sure the vents on the inside of the fridge aren't covered. This can prevent air flow, making it impossible to cool the refrigerator
  • Hope this would help you.
    Have a nice day!
    Jun 23, 2011 | Kenmore Refrigerators
    How can I get into the cut-on settings of refrigerator
    Purchase an appliance thermometer that is specifically made for refrigerators and freezers. These special thermometers were made to withstand cold temperatures and provide an accurate reading when exposed to such temperatures.
    2Place the appliance thermometer in a glass of water.
    3Set the glass of water with the thermometer in the refrigerator on the middle shelf.
    4Check the temperature on the appliance thermometer after 24 hours.
    The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
    Only barely above freezing -- say 34 degrees Fahrenheit (1 degree Celsius) is even better for food storage at the cost of slightly higher electricity consumption. But check that food is not slowly freezing in any part of the refrigerator, which could make it less palatable.
    5Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
    If you can't easily see the control dial, check the owner's manual for a diagram that shows the location.
    When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
    6Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
    7Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
    8Wait at least 24 hours, and then check the refrigerator temperature again.
    9Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
    10Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
    11Repeat the steps as necessary until the temperature is within the safe range.
    12Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
    Hope this help in solving the problem....
    May 12, 2011 | Refrigerators
    How to set up the temp. please
    Hope this will help out...
    May 07, 2011 | Traulsen Refrigerators
    I have a Samsung refrigerator/freezer How do I adjust the freezer temperature?
    1Place the appliance thermometer in a glass of water.
    2Set the glass of water with the thermometer in the refrigerator on the middle shelf.
    3Check the temperature on the appliance thermometer after 24 hours.
    4Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
    If you can’t easily see the control dial, check the owner’s manual for a diagram that shows the location
    5Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
    6Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
    7Wait at least 24 hours, and then check the refrigerator temperature again.
    8Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
    90Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
    10Repeat the steps as necessary until the temperature is within the safe range.
    11Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
    Hope this helpout...
    Aug 09, 2010 | Samsung Refrigerators
    GE GSS25LGMFWW side by side. Freezer will run till iced up then defrost everything in the freezer compartment. Why is it doing this?
    hi, have you try adjusting the temperature:
    To change the temperature, press and release the
    WARMER or COLDER pad. The SET light will come
    on and the display will show the set temperature.
    To change the temperature, tap either the
    WARMER or COLDER pad until the desired
    temperature is displayed. The
    freezer temperatures can be adjusted between
    –6°F and +6°F.
    Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    Water is warm not hot. How do i adjust the scorch guard?
    Here is the breakdown of the model number shown:
    Delta T13420
    The way to adjust the temperature is by this:
    1. Get a pocket thermometer.
    2. Turn on the water to the hottest setting.
    3. Remove handle.
    4. Check the temperature with the thermometer. (adjust to your liking, scald begins above 100 f)
    5. Set temperature by removing and rotating the plastic piece just below the handle left or right until the desired temperature is achieved.
    6. Replace handle.
    This should do it.
    Hope this helps and please rate this!
    Dec 07, 2008 | Delta T13420 Chrome Classic Single Handle...
    Delta T17238-SS Stainless Steel Lahara Double Handle Pressure Balanced Show Logo
    59 people viewed this question
    Top Delta Home Experts
    Mike
    john h
    Tim Whalen
    Are you a Delta Home Expert? Answer questions, earn points and help others
