Question about Cyberhome CH-DVD 300 DVD Player
Cyberhome 300 DVD Player: pal to ntsc mode?
I have cyberhome 300 dvd player. I hear the sound but donot see any image on the screen. I think there is a problem with the pal to ntsc mode but i cant change it as when i put the dvd in and press SETUP nothing appears and the screen is blank. I cant access the setup of the dvd player and, therefore, cant change it from pal to ntsc mode. I also tried putting it on standby and then opening the disc case and pressing stop for 5 secs. It didnt work. How can i change the mode? Help!!!!!
  • ladybug5050 Apr 25, 2008
    my cyberhome dvd player just stays on loading when you insert a disk it will not show a picture or sound
  • Anonymous Nov 26, 2008
    i have the same problem with my new laptop which i bought frm canada....
    it doesnt work with any cds or dvds.
    and i found that bcoz of the change of the pal and ntsc mode which are different in both countries.......so if anyone can solve that prb plz send me the mail to my email [email protected]
    Problem Solver:
  • 13 Answers
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Posted on Oct 27, 2008
    Novelist:
  • 135 Answers
Have you put new batteries in the remote? It sounds as though it simply isn't working. If the original remote just doesn't work, I found a universal remote which works on the Cyberhome CH-DVD 320 (and should work on the Cyberhome CH-DVD 300). The Radioshack "4-in-1 Family Favorites Remote Control", model 15-2142. Available at your local Radio Shack, or probably on ebay.
Posted on Aug 02, 2007
  • Kevin Omel
    Kevin Omel Aug 10, 2007
    I don't know what you mean by standby, but the directions for that procedure as I found them describe it differently.
    "If you select Progressive Scan and your television doesn?t support it, you may end up with a blank screen and be unable to view the menu in order to fix it. If that happens, fix it by turning the DVD player off then back on. Open the disc tray, then press and hold the STOP button for five seconds."
    Another reason you could end up with sound and no video is having the component video cables plugged into the wrong set of plugs in the back of the player or the TV. Make sure that the plug colors on the back of the player that your cables are plugged into exactly match the plug colors on the back of the TV.
    Hope that helps, but write back with more detail if it doesn't.
  • 54 Answers
Turn on your dvd player then press continuesly the stop buttom in the panel 10-15 seconds til the screen appears.
Posted on Apr 15, 2008
SOURCE:
How do i convert the source from PAL to NTSC
Press and hold stop button on the front panel.more than 10 sec the player will be resetting factory setting
Mar 01, 2010 | Cyberhome CH-DVD 300 DVD Player
Cyberhome dvd ch dvd 300 changed ntsc to pal by accident
I have done it! All I did was take the yellow video cord and plug it in those progressive scan plug in until I could see a blurry screen enough to be able to see to do a reset, which is under system and did a factory reset. I DID IT AND DAMN PROUD OF IT SINCE THE EXPERTS DIDN'T EVEN KNOW [email protected] Jennifer pc, fl
Jun 05, 2009 | Cyberhome CH-DVD 300 DVD Player
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
NTSC SYSTEM SELECTED IN TV & DVD PLAYER PLAY PERFECT NTSC CDS & DVDS, BUT IF PAL CD OR DVD IS INSERTED SUCH PROBLEM COMES.
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
Think i mistakendly changed dvd player from ntsc to pal on remote
Try this.
1. make sure you dont have a dvd in the player
2. close player and press menu,1,9 you should see a menu; line 3 from the bottom it will say region selection then put your region or (0 for free zone)
3. now insert disk and press close and your movie should play.
Please rate this solution.
Jan 17, 2009 | Cyberhome CH-DVD 300 DVD Player
Cyberhome 402 DVD "rolls"
I think I had switched to the PAL format by mistake. Fixed the problem by buying a new DVD player, was cheaper than the factory fix.
Jul 30, 2008 | Cyberhome CH-DVD 300 DVD Player
No picture how do i re set nothing works
This might be a case of the player being in the PAL system. Your player is supposed to employ both PAL and NTSC systems. Just look for a key listed N/P on the remote.Press that key once, and you are supposed to be ok.
Jul 23, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome Ch- DVD 300
Your advice was very helpful. After two+ months of tooling around and navigating around the menu blind I was on the brink of trashing it.
At first I tried the stop button with a dvd in the player with no success. After taking the dvd out, turning in off/on then pressing the stop button for 20 seconds the screen turned blue as said.
This help saved me a great amount of fustation.
Thank You!
May 27, 2008 | Cyberhome CH-DVD 300 DVD Player
How to reset dvd recorder to ntsc from pal
After checking today to see no one offered any suggestions - I solved the problem the hard way - I went into settings and although the screen rolled, I was finally able to click onto the ntsc setting after about a half hour of tries and once I clicked it, my screen returned to normal -- i was then able to enter the code that made the player an all region player and was happily able to play a pal dvd I received recently. The procedure was simple -- offered by a European Cyberhome user -- the company is in bankruptcy so you cannot gt help from them. Note - my Cyberhome dvr is 1500- not 1600 as you listed it.
Feb 11, 2008 | Cyberhome DVD Recorder - DVR1600
Screen role
Switch it back from PAL to NTSC.
Mar 29, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
659 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
