Question about Canon PIXMA MP287 ALL-IN-ONE INKJET PRINTER
Canon mp287 suddenly wont continue switch on
When i tried to press the power button, the green light will blink for a few times but it wont continue to turn on.
SOURCE: THE PRINTER IS BLINKING ORANGE FIVE TIMES ORANGE AND THEN ONE TIME GREEN
I have the same problem blinking orange 5 times and 1 green, please help
Posted on Oct 04, 2008
cene765
  • 787 Answers
SOURCE: Canon 1560 error - orange light blinking 5 times
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
Posted on Oct 30, 2009
pineworks
  • 4041 Answers
SOURCE: Waste Tank Counter Reset - Canon i550
Hi
Problem for Canon BubbleJet i560 InkJet
The waste ink is in the inside of your printer you need to get at it to clean out,
It may be all screwed down so you need to open all up or get a shop to do it for you.
It not an easy job but maybe you are handy with a screwdriver, it can be messy job.
But after this, you will have to reset the waist ink counter or it will still not work,
But but but but you can always try this to reset it first and clean it out again some time.
Canon Reset waste ink counter
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
pineworks
  • 4041 Answers
SOURCE: Can't get past step 2 of the Canon i550 waste tank counter reset.
Hello you can try
1. Turn off printer
  • 5 Answers
SOURCE: my printer power wont turn on when i press button
Try removing your printer cartridges and then the print head from the printer. If the printer powers up with the print head removed, then the print head is either shorted or clogged. If it's shorted out then you will need a new print head (usually cheaper to just buy a new printer). If you can clean the print head without damaging it, sometimes it will work again. Usaully a good 24 hour soak in alcohol or a cleaning solution will work.
Posted on Jun 06, 2010
How solve error p07 in canon mp287
First Step : Set The Canon PIXMA MP287 To Service Mode. To do that, follow this step, it's so easy.
  1. Turn off the printer without pulling the power cord.
  2. Press and hold the RESUME button (Green button), keep holding it and then press the power button, do not let go yet.
  3. Keep holding the power button, now release the RESUME button and then press theRESUME button for 5 times and quickly release the POWER button.
  4. When the printer entered the Service Mode, all LED will stop blinking.
Second STEP : Reset Canon PIMA MP287 Using Resetter. Open the mp287.exe, and then follow this step.
  1. Insert some A4 paper, the printer will print the result.
  2. Look for "Clear Ink Counter" section, press the "Main" button and wait for the message "A function was finished" and then press "OK" button.
  3. Press the "Platen" button located beside the "Main" button.
  4. Look for "Print" section, press the "EEPROM' button, select "Rear Tray" and pres "OK" button.
  5. The printer should printout the result. That's all, you may turn off your printer now. Sometime you need to press the POWER button several time in order to turn off the printer.
source:http://stepblogger.com/tutorial/tutorial-how-to-reset-canon-pixma-mp287-using-resetter-tool/
Jul 05, 2012 | Office Equipment & Supplies
My printer show error e07 how to solve
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
4 times Green Waste ink counter reset
Jun 01, 2012 | Office Equipment & Supplies
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
My canon ip90 does not print, continue to get 5100 error msg
you can try this method to reset the error..
First close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.), then while holding the Power button, release the Resume/Cancel button but do not release the Power button.
While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange. During initialization, the LED blinks in green. When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. Pls note each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.
Then press the Power button, the LED lights in green, and the
selected function is performed. When the operation completes, the printer returns to the menu selection mode automatically. Last just power off then back on and test.
May 28, 2010 | Canon PIXMA iP90 InkJet Printer
Re my pixma mp13o printer. message"ink waste tank almost full" how do I rectify it. tried switching on and off and unplugging for 10 seconds.
Three choices. 1. Take it in for repair. 2.Take the top off and remove and clean the pad. 3. Use the following instructions to reset the printer and continue printing. I chose number 3 and haven't had any problems.
These are the instructions which worked for me on my Canon mp470 and has work on many other Canon models:
1) Close the print2_bing.gif head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Mar 24, 2010 | Canon PIXMA MP130 All-In-One InkJet...
How to reset absober full mp198
PLEASE TRY THIS, Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter
Feb 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
For Canon MP210 absorber is full
These are the instructions which worked for me on my Canon ip470 and has work on many other Canon models:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
Feb 16, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Waste inki absober is full. The indicator orange
You can remove the top of the printer to remove and clean the pad or reset the printer and continue without cleaning.
These are the instructions which worked for me on my Canon pixma ip470 and has work on many other Canon models:
Feb 15, 2010 | Canon PIXMA iP90 Mobile Printer
When I turn on my Canon iP3000 printer the power light blinks five orange and one green light and continues to to so. It will not stay solid green.
Hello try
1. Turn off printer
Nov 02, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA MP287 ALL-IN-ONE INKJET PRINTER Logo
1,234 people viewed this question
old marine
old marine
