Question about Garden
PowerMac 310 has no spark
Replaced the spark module on the chain saw and still have no spark.
    Sergeant:
  • 458 Answers
Try a new spark plug. If the insulator on the plug is cracked you will get no spark. You may not be able to see the crack.
Posted on Apr 11, 2014
  • 334 Answers
SOURCE: husqvarna small chain saw won't stay on and now won't start
check your pick up coil . i had one it done the same thing to and that what it was
Posted on Apr 02, 2009
SOURCE: Chain Saw, Stihl Model 011, cutting off
I've been messin with my poulan 2150 that was doing the same thing. Good, fresh gas, good spark,etc. I noticed whenever I loosened the fuel cap it would literally spray gas out! alas, I removed the muiffler assy and the darn thing fired up the first pull! I've got the muffler parts soaking in gas right now and I'm sure this the problem. It just makes sense especially if you use the same 'mixed fuel' can for weed eater, blower,etc. Check your's out, it could very well be your problem too! GOOD LUCK
Posted on Apr 29, 2009
  • 23 Answers
SOURCE: 4 y/o oulan chain saw hard to start and quit running, no spark.
TRY RUNNING AT HALF OR FULL WHEN IT DOES POSSLBY BAD GAS/MIX IF YOU CHANGED THAT ALREADY CARB PROBALY NEED TO BE CLEAN
Posted on May 17, 2009
  • 4088 Answers
SOURCE: poulan saw wont start has spark and fuel
Look for a pinched/bare stop-switch wire (I assume that you don't have spark now). Also, check the ignition coil core gap to the flywheel magnets (I use card stock to set the gap). Make sure the plug wire was not damaged again.
Posted on Sep 01, 2009
dontbother10
  • 2220 Answers
SOURCE: Looking for a Primer Blub for a Mcculloch PowerMAC
Hello Winston;
Even the new number you provided does not cross. Could your saw be a PM3216, model 11-600032-33? That does cross here:
McCulloch MTD
Chainsaws 32cc-35cc
and with better detail here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/MCC/11-600032-33-Mac-3216-06%2F93-IPL-211229/139.11-600032-33-Mac-3216-06%2F93-IPL-211229.1.59.1.html
See the "General Assembly" print; item 23; pn 224242-02.
M & D Mower
http://www.m-and-d.com/index.html
Has the above item available through arinet reasonably.
It follows:
http://arinet.lookupparts.com/AddToBasket.aspx?Qualifier=MCH&Name=224242-02&Quantity=0&SellerId=1017594&Username=Default
I am going to close this. We can continue to converse as before.
http://www.fixya.com/support/r3558917-mcculloch_chain_saw_ipl_illustrated_par
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 18, 2010
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
Powermac 310 no spark
How do I test the ignition module out off the chainsaw? Or how do I know an ingnition module is working properly prior to instalation?
Apr 20, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Stihl 066 does not start. Replaced ignition module. Weak or no spark.
Are the poles on your flywheel blue? Are you using an open-air inline spark tester, or holding the plug against the cylinder and turning it over?
Jul 14, 2012 | Stihl Chainsaw 051 075 076 Drum Chain Saw...
Chainbrake spring broke need new one
Parts Catalogs Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04511001001 - C04511999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04612001001 - C04612999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04713001001 - C04713999999 Language: English
Jan 05, 2011 | Echo CS310 14" Bar Length Fully Assembled...
Poulan 2375le chain saw. just replaced primer bulb, gas lines and diaphram. also has new gas and spark plug. will fire up but wont stay cranked especially when I mash the throttle. please help..
Check the fuel filter, air cleaner and muffler for plugging. Be sure the fuel and oil mix is thoroughly shaken just before filling the tank each time to prevent oil starvation. Set the plug gap to 0.020" and test the spark for being blue and snappy. If weak looking, remove the left side engine cover to expose the flywheel and ignition module. Turn the flywheel so that the magnets are just under the module poles, insert a thin business card into the gaps, loosen the module screws to allow the poles to contact the magnets. Tighten the screws, turn the flywheel somewhat to remove the card, then turn the flywheel one full turn to make sure the gaps don't close up further. Replace the cover and retest spark--if ok, try for start. Hope this helps!
Nov 11, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
350 16" inc. chain saw want crank with new plug or starter fluid
Check for spark at the plug (gapped at 0.020"). If nothing, remove the left side case and starter--this exposes the ignition module. Check the pole gap with a thin business card for a gauge. Turn the flywheel until the magnets are under the module poles, insert the card into the gap, loosen the module screws and let the module contact the magnets. Tighten the screws, rotate the flywheel somewhat to release the card and recheck for spark. If still nothing, try removing the stop-switch wire from the module and try for spark again. If nothing again, replace the module. Install as above. Hope this helps!
Sep 21, 2010 | Husqvarna Chain Saw 20" Bar
ZR10926 16 Chain Saw: chain saw not working...
Remove the spark plug, lay the base on engine metal, and test for spark which should be blue and snappy. If nothing, try a new plug and retest. If still nothing, remove the left engine cover to expose the flywheel and ignition module. Check the module pole gap by using a thin business card for a gauge--turn the flywheel magnets under the module while holding the gauge in place, loosen the module screws and allow the module to snap to the magnets. Tighten the screws again and rotate the flywheel while turning the card to get it free. Turn the flywheel one turn to check that the gap doesn't get closer at any time. Recheck for spark. If still nothing, remove the grounding wire that goes to the ignition switch from the module and retry again. If still nothing, replace the ignition module. If you got spark in the first test, squirt some fuel into the plug hole and attempt start--if you get a few pops, concentrate on the fuel system. Check the fuel filter, air cleaner, and muffler for plugging. Check the condition of the fuel lines and primer button (if equipped). Make sure the carburetor is tight to the engine and all fasteners are tight. Hope this helps!
May 17, 2010 | Homelite ZR10926 16 Chain Saw
Doesn't want to start. Replace carb and ran for few seconds, Make you think that it is not getting gas, but pouring gas into spark plug does not help and drying spark plug dose not help. Spark appears...
The spark should be blue and snappy. Try a new plug--any help? If not, it may need a new ignition module. Check the flywheel magnets--they should be quite strong. The module gap with the magnets underneath the poles should be about business card thickness. Check the air cleaner and muffler for plugging. Hope this gets it running!
Apr 07, 2010 | Poulan 1630 16" Chain Saw
Chainsaw will not run, there is no spark detected
Homelite 330 – no points
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/baf9791bfc773f1a88256c2600142688?OpenDocument
Please try this
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
Oct 27, 2009 | Remington Electric Chain Saw
Poulan saw wont start has spark and fuel
Aug 25, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
