Central ac compressor fan doesn't turn
Model ye036g
  • David Koss
    David Koss May 11, 2010
    Have you checked to see if the motor is good?  Might need replacing.
    Have you checked to see if the start capacitor is good?
    If your not familiar with the unit you probably should get repairman to take a look at it.  Let me know if this help?
    Thankyou for your question and hope that it's just a capacitor. Need more help let us know.
    Problem Solver:
  • 8 Answers
If it is the capacitor, on the top of it it may look swollen instead of flat.
Posted on Mar 12, 2009
Tip
Replacing a condenser fan in centralized A/C
On of the common problem with centralized A/C unit is a bad condenser fan. I have known people who called an ac technician to fix their ac because of a bad condenser fan and suggested replacing the whole unit! Costing them a lot of money when all it needed was a 50 dollars condenser fan! If the condenser fan do not run or it runs only when you give it a push, it'sbad. You will also notice that it is vey hot. When replacing a condenser fan you may want to replace the starting capacitor too. Replacing a condenser fan is not very hard, just make sure that the power to the ac unit is turned off at the breaker box. Confirm that the wires are not live by using a meter or an ac tester. The fan motor are held with brakets sometimes just screws. Most fan you can buy that has reversible rotation by just reversing the plug. Make sure it is blowing upwards. If not reverse the rotation. So if you notice that the unit is not putting out cold enough air and you went outside and noticed the compressor running but not the fan, turn off the AC right away and do not use it untill the fan is replaced. Running the unit with a defective fan can damage the compressor caused by overheating.
on Jul 10, 2010 | Heating & Cooling
Compressor fails to restart
indicates that the compressor is not communicating with the program board in the inside unit
could be a relay problem
call in the service technicians for a proper diaganosis
Sep 12, 2017 | Honeywell Heating & Cooling
Ac compressor doesn't turn on
make sure that the fan is on as well as the ac switch. There are other switches that turn the compressor clutch off when something goes wrong. There is a high head pressure switch that turns off if there is excessive pressure generated from blockage or excess gas and another switch that closes of when there is insufficient gas in the system. Have a ac mechanic check the system for leaks as that is the most common problem.
Jul 23, 2013 | 2001 Pontiac Grand Am SE
Could cluster fuse be prob why ac blowing hot? fan blows but hot air
Does the Compressor kick in when you turn on the AC? If it doesn't, the AC compressor is governed by the ECU. My AC went out along with an acceleration problem. hard starting, and unburnt fuel. I had my ECU rebuilt, and upon installation of the rebuilt unit, all worked perfectly again, including the AC.
Nov 08, 2012 | 1993 Lexus Ls 400
1998 Lexus when you turn ac on,control panel shows its working.You hear compressor turn on but fan doesn't. One time I hit the defrost front and air went on?
it can be the thermal visco coupling between compressor and belt that are dammaged . or maby the electrical fan motor check the electric fuses and rellays
Aug 05, 2011 | pepboys.com
Kenmore central air conditioning unit tripping breaker each time we turn it on.
The breaker tripping when you turn the unit on indicates a 'direct short' and 99 out of a 100 times the short will be either the outside fan motor or the compressor itself. Either way - you will need a qualified serviceperson to diagnose this problem correctly and make the needed repairs.
Best solution is to call AC person.
However, here's a good way you can get it down to either the fan motor or the compressor.
(1) With all power OFF - disconnect the wires to the fan motor
(2) turn on AC unit (a) if breaker trips it means the compressor is probably the shorted component. (b) if breaker DOES NOT trip and the compressor runs - it means the fan motor is shorted.
(3) If breaker tripped with the fan motor disconnected meaning the compressor is probably shorted you can then (with ALL POWER OFF) 'disconnect the wires going to the compressor' and re-connect the fan motor wires. Turn on power - and if fan motor runs (with compressor wires off) you know it's the compressor that is shorted.
After all this you will now know which of the two (compressor or fan motor) is shorted.
If it's the fan motor you can with 'limited mechanical experience' change the motor yourself, but if it's the compressor you will need to call a serviceperson because of the expertise needed to replace the compressor.
Jun 05, 2011 | Kenmore Heating & Cooling
1993 CORVETTE AC PROBLEM
Are you fully charged though? If you don't have a full charge the clutch will not kick in.
Aug 18, 2009 | 1993 Chevrolet Corvette
Carrier central ac model 38EN036300
If you have an electronic thermostat, they can short out, leaving the compressor running. Also, the big relay that runs the compressor can get its contacts welded together. See if the contacts are stuck closed.
Jul 27, 2008 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
542 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
