Question about Car Audio & Video
What did they do????
I have a 96 lincoln Continental and the previous owner had a toggle switch that goes from my front dash to the JBL system in the trunk.... they took the raido out and cut the wires behind the raido... the wire that the toggle switch goes to in the trunk is a Green wire with a purple stripe... could some one tell me wat this wire is...
  • 102 Answers
This most likely was a remote ON/OFF for the amplifiers, sometimes it is easier to do than locating the remote wire on the dash unit.
Posted on Mar 11, 2009
1994 continental. air ride. compressor starts and rear starts to lift, but after 3-4 mins. i get a beep and light on dash says ride control and then she squats in the rear?
When I got my 1994 Continental, it had already been converted back to a coil-spring suspension, and the air-ride system was GONE. You will find that is the case with most of the ones that are still on the road. The air-ride system turned out to be an unreliable, trouble-prone, nightmare for most owners....and it was cheaper to scrap it and go back to after-market coils, than what it was to have a Lincoln dealer fix it. Looks like you're destined to join the club....If you decide you want to have it fixed, and make the car driveable, be prepared to PAY for it.
Jun 08, 2014 | 1994 Lincoln Continental
1996 Lincoln Continental will front struts from a 96 taurus fit the Lincoln
If your car is front wheel drive Taurus sturts will not work. You can go on ebay and find the right sturts that are changed over for your car.
Aug 05, 2012 | 1996 Lincoln Continental
1997 Lincoln Continental Fuses... Need to know which fuses are for what in my 1997 Lincoln Continental. There are two fuse boxes. The fuse box under the hood I know what they all are, but the one under the...
go to motorcraft.com, pro center, tech info, owner manual, fuses in index.
I may have an owner manual if interested. It would be $5 plus $1.50 postage.
Please rate highly if this helps.
PS What is the issue?
Oct 11, 2011 | 1997 Lincoln Continental
I have a 96 continental, and "check ride control"
is it the front, back, or both? Check the sensors, the one in the rear may have popped off it's mounting bracket-you have 2 in the front (one each side) and the solenoid that vents them may ber stuck closed (located near the air ride compressor)-tap it with a small hammer. If it is all four corners, the air ride module (under the dash, behind the glovebox) is probably either not plugged in properly (wiggle the harness or the connector) or defective (junkyard item, cheap-$5-$10 max).
Jan 27, 2011 | 1995 Lincoln Continental
On my lincoln 96 the brake are sticking on one side front and back i got new calipers
The first thing to replace is the front rubber (flex) line that goes to the caliper from the steel brake line. They can go bad on the inside and not allow the caliper to retract when you take your foot off the brakes. If the rear brake is sticking it isn't retracting properly also, but try the front fix first and see what happens.
Oct 06, 2009 | 1996 Lincoln Continental
How do you "manually" bleed the air bags in a 96 Lincoln Cont. ?
Shut off pump switch located in drivers side panel door in trunk. Jack up car at frame and support with jack stands. This will make sure the car does not come down on you when you release the air.
Pop retaining off of solenoid valve located at top of airbag and turn valve to first stop till air starts releasing
Sep 07, 2009 | 1986 Lincoln Continental
1995 Lincoln Continental Heated Seats switch?
look in the front under the ashtray for two switches.
call a ford dealer,they will be able to help as well,probably for free.
Sep 06, 2009 | 1997 Lincoln Continental
Car Audio & Video Logo
78 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
