Question about Cooper Atkins 412-0-8 Gun-Style Infrared Thermometer
How do I turn on the laser on my Cooper 412 Thermometer
On start up LO appears on screen
the LO is just saying low tempeture it will go away in a min or 2 then should be able to use or try to replace the batteries
Aug 12, 2013 | FMP Cooper-atkins Versatuff Plus 93867k...
Is there an on/off switch for the Workcentre pro 412?
there is no on/off button for this machine however for more features try THIS link for user manual
Nov 15, 2011 | Xerox WorkCentre Pro 412 All-In-One Laser...
How do I check the flow on a water pump on a 2001 buick lesabre?
Best way is with a non-contact laser thermometer, it cost about $30.00 at Harbor Freight Tool if there's one in your area, point the laser to the lower hose and then to the upper hoes, should have a reading of + or - 10 deg. between the two.You could also used a reguler thermometer, with radiator cap off and engine running, let it sit in there, temp. should go up and down as thermostat opens and closes if water is flowing through.
Dec 04, 2010 | 2001 Buick LeSabre
How do I scan a photo onto my laptop using a Xerox WorkCentre Pro Scanner?
Just attach the scanner to your laptop.Install the drivers of your scanner into your laptop and restart the laptop.
Now start scaning your documents..
Regards,
polysandy
Apr 06, 2010 | Xerox WorkCentre Pro 412 All-In-One Laser...
I have a Xerox WorkCentre Pro 412 and it will not power up.
First and most simple. Plug something else into the outlet to make sure it works. If this model has a removable power cord then try re-inserting the cord. While you are there and with the cord installed, lift up then push down slightly and see if it comes on. If the power cord is removable the receptacle where it plugs in are notorious for breaking the solder connections. If this is the case it just needs to be re-soldered. If the outlet is ok, the cord is ok or hard wired in then you may have either a blown main fuse or a bad power supply.
Good Luck
Nov 30, 2009 | Xerox WorkCentre Pro 412 All-In-One Laser...
Xerox workcentre pro 412 printer do not work
i changed the usb cable to anthor one Parallel Port
Cable so i think the adapter of usb cable is damaged so now it work.
Jul 06, 2009 | Xerox WorkCentre Pro 412 All-In-One Laser...
Describe your Xerox WorkCentre Pro 412... Problem:Scanner
Turn off the copier first.
Look under the copier, there by where the copies come out, look just above that portion of the machine. There will be a green sliding latch; one side has a picture of a pad lock for lock, the other side has a un-lock position, slide the latch to the unlock position.
Turn on the copier, and the machine should work.
That latch is for transporting the copier when being moved. It will hold the scanner in place so it does not move around.
Apr 23, 2008 | Xerox WorkCentre Pro 412 All-In-One Laser...
Cooper Atkins 412-0-8 Gun-Style Infrared Thermometer Logo
103 people viewed this question
Top Cooper Atkins Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Cooper Atkins Measuring Tool and Sensor Expert? Answer questions, earn points and help others
