Question about Kenmore 41389 Electric Double Oven
F-1 showing when the power is on i get an F-1 and a constant beeping...i have it turned off at the breakers to keep my sanity...whats the problem? I have had the same -F1- alarming problem. What did you do to remedy this problem? I am sitting here listening to the alarm while chicken baking in lower oven.
  • 2,984 Answers
You nneed to change the clock or ECR. You can get this from Sears Parts center....
Posted on Mar 11, 2009
    Top Expert:
  • Kenmore Master
  • 77,544 Answers
F1 indicates a problem in the electronic control, its keypad (which may only be available with the control) or sometimes even the oven sensor.
The first thing you can try is disconnecting the appliance from power for several minutes to see if that clears the problem. If not, some investigating will likely be necessary.
  • 275 Answers
It is a pretty common annoyance for many, some are able to disconnect the power and it seems to go away, but if it continues f-1 means EOC (Electronic Oven Control) Failure so if it persists it needs to be replaced.
    Brigadier General:
  • 8,619 Answers
Hi!
Please turn off your oven and unplug it from the power supply and plug it back after 2-5min.s and check.
My de dietrich DOP770X4 oven won't stop beeping and it keeps turning on and off randomly
Try resetting it by the outlet it is plugged into, shut power off at the breaker/fuse box wait a few seconds then turn breaker back on.
Oct 11, 2014 | Ovens
Got F9 on Amana range model ACS3350 while trying to clean oven. The door is locked and got constant beeping with F9 error code. Powered off oven for 10 minutes and powered on, still getting the door...
Shut off the circuit breaker to it for FIVE minutes, then back on. If the problem persists then do the following:
A latch locks the center top INSIDE of the door during cleaning.
Run a piece of semi-stiff, flat object, like a cardboard strip that is in L shape behind the top lip of the door from RIGHT TO LEFT. You may need to push it along with your finger jambed in there when it reaches the latch. With a little push the latch should open.
Try to run the oven, if F9 shows again, press cancel Oven to quiet it. The Lock state is still in place. Move the latch hook manually all the way to RIGHT. Then shut off the circuit breaker for FIVE minutes, then back on. The oven should work ok.
If this fails again try the five minute shut off with the latch in other starting positions.
If none of these work then the latch mechanism, or it's motor is really broken. Replace or ditch and never buy Amana again!
Sep 01, 2011 | Amana AOCS3040SS Electric Single Oven
I have a bosch oven and the power in my house went out during a storm and when it came back my oven started beeping and has not stopped since... what do i do???
Hello- You may have done this already, to save your sanity, but I would turn off the breaker for a few minutes. It is most likely beeping to tell you there was a power failure (as if you didn't notice). Once it is back on you will need to reset the clock, it may not stop beeping until you do this or press cancel. If this does not remedy the beeping there may have been a power surge that caused damage to the control board in which case you should call a Tech out to have a look. Good luck, best regards.
Sep 28, 2010 | Ovens
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Frigidaire double oven beeping and showing f8 code
there is a problem with the lock for one of the doors do they both close all the way or does one hit the latch. could be bent linkage or bad switch on lock or the control board has a bad relay on it.i need a model # to help any ferther
Dec 31, 2009 | Frigidaire 27 in. Electric Double...
I have an in the maytag gas oven that keeps beep and show f-1 when its shut off
This simple test will help determine whether the ERC (Electronic Range/oven Control or Clock) or the touch pad is defective when this error code is present.
1. Disconnect power to the range/oven (unplug the range/oven power cord or turn the power off to the range/oven at the circuit breaker). It is very important that the power to the range/oven has been disconnected, so please double check before continuing.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC/EOC.
6. Wait for at least one hour to see if the code comes back (usually accompanied by a beeping sound).
7. If the code comes back and the beeping as well, replace the ERC(control board). If it does not, replace the touch pad.
Nov 02, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Oven W279U Serial No. 790191BD keeps beeping.
I turned off the power to the oven at the breaker box and left it off for several days. I restored the power this afternoon and there have been no more beeps. Spells and incantations may have played a part as well.
Aug 20, 2009 | Jenn-Air Ovens
F-1 showing
It is a pretty common annoyance for many, some are able to disconnect the power and it seems to go away, but if it continues f-1 means EOC (Electronic Oven Control) Failure so if it persists it needs to be replaced. Maybe you had a powersurge recently or it could be just worn out
Sears is a department store. They do not build their own appliances. They contract with many different manufacturers to build all of their appliances.
Sep 24, 2008 | Kenmore 41389 Electric Double Oven
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Kenmore 41389 Electric Double Oven Logo
59 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
